Question about Star Logic 17" LCD Monitor
Starlogic 17" monitor not working with Vista
Is it a driver that I need to download or a setting I need to change?
  • 51 Answers
May need to download some drivers for it. Your operating system has nothing to do with it. Try www.driverguide.com . It also may be a hard ware fault. make sure all your connections are secure. Hope this helped.
Posted on Jun 23, 2009
I just bought a new PC and the Vista on screen is very large I tryed to make it smaller but was not sucsessful can you help The monitor is a starlogic
The only way to change the 'size' of objects on the screen is tro play with screen resolution. On an empty place on your desktop, right-click then click on "Personalize". There are things in Display Settings, Screen Saver and Window Color and Appearance that can be used to modify how things fit together on your screen. Without more info on exactly what it is you want made smaller, this is intentionally vague.
Oct 28, 2009 | Star Logic 17" LCD Monitor
StarLogic- Out of range
The computer needs its screen resolution reducing or changing in aspect ratio to suit the StarLogic monitor. Use a previously-working monitor and reduce the resolution on the computer to 1024 x 768 pixels or less (right-click an unused part of the desktop, click Properties and select Settings; slide the resolution slider to the left to adjust). The StarLogic monitor will now work; plug it in - do the resolution adjustment again as above, but increasing the resolution until you are happy. Going this way around, your computer will failsafe back to the previous (lower) resolution if the monitor says Out Of Range again, so you cannot lose the display along the way..
Sep 07, 2009 | Star Logic 17" LCD Monitor
Starlogic 17'' as dual display not clear
Check and see if your NVIDIA drivers are up to date. Then try changing the resolution on your laptop to match the native resolution on the monitor and see if it works. If it does then you will need to look for the option to set custom resolutions on each monitor so that you can have both devices working at diferent resolutions if 1 is wide screen and the other is not.
Let me know if this does not work and you need more help.
Apr 20, 2009 | Computers & Internet
17" starlogic monitor model M19BNK serial M9B49CKVoo4584
blown capacitors on the vga board or the resolution for the display adapter is set too high for the monitor reduce the resolution in safe mode and you should be ok, if not then the bad capacitors are in need of being repalced
Sep 17, 2008 | Star Logic 17" LCD Monitor
17'' monitor whte screen power light on
have a 17'' starlogic flatscreen monitor and i opened a game and it went to white screen and stayed there.
Jun 19, 2008 | Star Logic 17" LCD Monitor
19" starlogic monitor
If you are getting a "No Signal" message, someone may have inadvertantly pressed the wrong button on the monitor. Use up arrow of button #5 below to cycle through RGB (normal VGA connection) and DVI sources. Down arrow will result in "No Signal" message.
There are five buttons at the bottom of the screen on this monitor. From the left:
1 - sound volume
2 - degausser
3 - power on/off
4 - monitor set-up
5 - RGB/DVI source
Nov 20, 2007 | Star Logic 17" LCD Monitor
Star Logic 17" LCD Monitor Logo
176 people viewed this question
Top Star Logic Computers & Internet Experts
Jerry Greenberg
Jerry Greenberg
ray gallant
jd83854
Are you a Star Logic Computer and Internet Expert? Answer questions, earn points and help others
