Question about Samsung HP-T4254 42 in. Plasma Television
Why ps3 not supported mode samsung hpt4254? - Samsung HP-T4254 42 in. Plasma Television
Hdmi for playstation is not supported
Do a hard reset on your ps3. Hold down power button until it turns off or unplug the unit. Leave off for several minutes. Restart PS3 and set HDMI setting on TV to 720p.
Oct 19, 2012 | Samsung LE32R73BD 32 in. HD-Ready LCD...
Trying to connect PS3 to Samsung HL-S4676S tv using HDMI cable. I get message saying mode not supported
So I had this same problem. I found that when I hooked to a 1080p TV my PS3 was working, however when I hooked to my 1080i it said Not Supported Mode. So I then hooked to the 1080p and told my PS3 to limit it's self to 1080i mode and hooked it to my Samsung TV and it worked just fine. Give that a try and it should solve the problem. Hope this helps.
Oct 09, 2010 | Samsung HLS4676S Television
Mode Not Supported
Set the PS3 to 1080i for your HL-P5663W. I verified the owners manual and this TV does not support 1080p even by PC input.
Mar 14, 2010 | Samsung DLP HL-P5663W 56" TV
Samsung LN-T4042h to PS3 "Not Supported Mode"
i fixed it, on the PS3 u hold the power Button while holding then Switch the power button on on the back for like 10 sec and it resets the picture settings to default
Oct 24, 2009 | Samsung LN-T4042H 40 in. LCD HDTV
PS3 will not work on new tv using HDMI cable ?
you have to re sync your playstation when you go from HDMI to regular wires.
after you connect ps3 to tv.
hold down the power buttondown on the ps3 for like 5 seconds (1 beep then another ),
after you hear a second beep the ps3 automoatically adjusts itself to whatever it's connected to.
Feb 26, 2009 | Samsung Televison & Video
Samsung hpt4254
Are you using a cable box,directv,dishnetwork?High Definition?
I need more data to assist you.
solutiondoct
Nov 02, 2008 | Samsung SPN4235 42 in. Plasma HDTV
Ps3 problem
Change the resolution on the ps3 to accept 480p, 720p, 1080i, 1080p.
Jun 14, 2008 | Sony Playstation 3 (PS3) Console
Ps3 not playing blu ray on my samsung LCD
Change the frame rate on your tv to 60hd, that should solve it. Basically, your tv might be set to theater mode which is playing 24hd..
May 14, 2008 | Sony Playstation 3 (PS3) Console
SAMSUNG PLASMA TV HPT4254
Replace the Main board of your tv.
Dec 30, 2007 | Samsung SPN4235 42 in. Plasma HDTV
Samsung LCD tv
same problem.. i always get the screen: "not supported mode". whatever the hell that means. so the issue is definately with the tv and not the playstation. has anyone tried contacting Samsung?
Nov 03, 2007 | Sony Playstation 3 (PS3) Console
Samsung HP-T4254 42 in. Plasma Television Logo
22 people viewed this question
Henry  Thomas
Henry Thomas
