Question about Dometic Rooftop RV Air Conditioner
Compressor not kicking in when i turn the air conditioning on.
Fan will run and compressor tries to kick in for about a second but then it kicks off. You can hear the compressor try to kick back in about every minute and a half or so, but still the same result it kicks out but the fan will still run.
    Problem Solver:
  • 6 Answers
What is the make and model? how long has it been switched on? is the compressor top hot?
Posted on Jun 23, 2009
  • 3 Answers
Could be a few things, bad capacitor, compressor locked up, contactor bad
Fan will come on but compressor wont kick in on wall unit ac
The start capacitor on the compressor is bad. Replace it and the compressor will run.
Jun 30, 2013 | Heating & Cooling
Air conditioning system takes a charge, but the
high pressure switch is kicking out on overload, replace it or you might have too much freon
Jun 27, 2010 | 2000 GMC Jimmy
Compressor appears to kick in, runs for short time
It sounds like your unit may have a bad run capacitor or start capacitor and relay. Low voltage will also cause this problem. First you need to make sure that you have the full rated voltages at the unit, if you do, then, have the run and start capacitors checked out and the start relay.
May 31, 2010 | Dometic Rooftop RV Air Conditioner
I turn it on (montana 5th wheel) and it sounds like it's tryin to kick in the compresor that is and the fan comes on and the compressor tries to kick in about every 30 seconds but cannot?? it's about 4...
The compressor is trying to start and cannot because it is broken inside and will need to be replaced. The compressor can be replaced by most anyone that is familiar with working on home central air conditioning units. I have replaced a few compressors for units like yours. Have a professional check it out. It could just be the start capacitor, but usually it is not.
Nov 15, 2009 | Dometic Rooftop RV Air Conditioner
Kenmore Coldspot compressor kicking on and off
It sounds like you may have toasted one of the starting componets. Either the start relay or the start capacitor has probably failed, causing the compressor to try to start, and then kick off on overload. Hope this helps
Sep 10, 2009 | Kenmore 50522 / 50524 Side by Side...
Compressor on my RV coleman ac unit bogging down
Take a look at your start capacitor. This the capacitor that kicks the compressor over when it tries to start. If the capacitor is bad, it cannot kick the compressor back over after the first cycle because the head pressure has not evened out yet. It is located in the upper unit on the side panel in a small box. Be careful, highly charged capacitors can zap you if you are not careful. Disconnect power and touch across the terminals with a meter or a screwdriver to discharge the capacitor.
Hope this helps,
Jeff
Jun 29, 2009 | Coleman Mach 15 Air Conditioner
Kenmore AC Model 25370156000 keeps shutting off and on by itself
If you have just installed this unit in your window for the season, you may want to wait a day or so, for everything in the unit to settle, and try again. You make have shaken it up a bit too much. If not.....sounds to me like it is kicking out on high head pressure. This happens when refrigerant gets too low, or there is air in the refrigerant system. There is nothing you can do to solve this problem, except take it to a repair shop. If I am correct what happens is you turn the unit on, and the fan and compressor start simultaneously, then after a few seconds (maybe up to a minute) the compressor kicks off, and the air gets warm, then the compressor kicks on for a few seconds, and we repeat. This is actually a safety mechanism for the compressor motor so it does not run without refrigerant. (That would destroy the pump.)
Jun 04, 2009 | Kenmore 76129 Air Conditioner
Dometic Rooftop RV Air Conditioner Logo
737 people viewed this question
Top Dometic Heating & Cooling Experts
Bill Long
Tim Whalen
Are you a Dometic Heating and Cooling Expert? Answer questions, earn points and help others
