Question about Rowenta Compact DA35 Iron
How do I repair Handle on Rowenta DA1560 ? - Rowenta Compact DA35 Iron
Rowenta steam iron fell down and top part is broken can it be replaced
Rowenta Iron Parts - eReplacementParts.com
www.ereplacementparts.com/rowenta-iron-parts-c-180639_180647.html Fix your Rowenta Iron today with parts, diagrams, accessories and repair advice from eReplacement Parts! Worldwide ... DE0554 Rowenta Steam Iron Parts.
Aug 08, 2015 | Rowenta Irons
My rowenta steam iron fell down and top part has broken any chance it can be replaced
Parts for Model DG8030
Google Rowenta repair. They have stations all over the US.
Jul 25, 2014 | Rowenta DG8030 Expert Pressure Steam Iron
Rowemta DA1560 won't turn on
1) No voltage to receptacle
2) defective cord or terminal connection
3)open thermostat
4) open heating element
4a) the heating fuse blown
5) test the outlet wal with lamp desk, if work, the iron is the problem follow the steps before mentioned. reset the c.breaker or change the blown fuse is necessary.SEE the diagram
God bless you
Sep 09, 2012 | Rowenta DA1560 Iron
I own a Rowenta Steamium DW9080 steam iron. I need a replacement plastic door for the water reservoir. The iron is functional and I do not feel it necessary to purchase the entire handle and cord...
Not familiar with that newer model, but here is the local dealer who is most helpful in California:
California Electric Service in Concord CA (it is the only Rowenta repair station in California) go to either of the following addresses:
their website is: http://www.californiaelectricservice.com/
or tech service: service@californiaelectricservice.com
Aug 29, 2011 | Rowenta DG-980 Iron
I have a few Rowenta DG980's that won't stop steaming
I would be more inclined to believe the trigger steam switch is jammed or hung up in the housing. It is a small micro-switch inside the handle under the trigger actuator. You can pry up the blue cushion from the handle from the front towards the back cord using an orange stick or screwdriver but not damage stuff. The button nib may be jammed against the switch hole/housing. Look here for getting parts...
Apr 15, 2010 | Rowenta DG-980 Iron
The electrical cord is seperating from the base of the iron and exposing the cord. The plastic covering is in parts. Can this be repaired?
You can repair this yourself but you will have to take the handle apart to access the power cord inside the handle. Just pull the cord inside and wrap with electrical tape to hold in place. Hope this helps
Jul 31, 2009 | Rowenta Irons
Rowenta Powerglide 2 INOX vertical steam, no steam, just water leakage
replace the o-ring gasket on the tank fill cap. It is a simple neoprene "O" ring you can buy at your local hardware or NAPA aauto parts store for less than $3.00.
st. louis mo Ralf
Sep 09, 2008 | Rowenta Steam Generator DG050 Iron
Rowenta Compact DA35 Iron Logo
Top Rowenta Irons Experts
Henry  Thomas
Henry Thomas
Shehu Pro
Shehu Pro
Are you a Rowenta Iron Expert? Answer questions, earn points and help others
