Question about Paini Spa Rubinetterie LaToscana Ducale Thermostatic Shower Faucuet With Shower Head, Bronze
How do you stop a Paini shower valve diverter from chattering
When we try to disengage the shower and run a bath, the shower diverter just chatters and won't stay engaged.
2 Suggested Answers
jyackle5
  • 8197 Answers
SOURCE: Where can I download an installation manual for a
May I get the model # to help more
Posted on Apr 05, 2010
I have a 93 ford escort lx. it has started to have a rough idle and a valve chatter. have replaced timing belt and the coil pack and starter. checked for a blocked catalydic converter. nothing is help
Valve chatter sounds pretty serious. Replacing coil pack won't help. I would check compression, if low, squirt a little oil in the plug holes, and if compression doesn't come up, bad valves.
You might need to check/set valve timing again, too.
Oct 26, 2014 | Cars & Trucks
Shower faucet chatter
it probably needs a air hammer addition. you could buy one or make one buy adding a inline "T" a short piece of pipe and a cap. which help balance pressure.
Dec 22, 2013 | Delta Home
Water won't stay on
If you will make contact with George at M-One-Specialites he can track that down for you and help you get that fixed.
He has a very extensive list of repair parts for faucets.
Rod
US Parts Center
Jan 25, 2013 | Kohler K-14677-BN Loure bath- or...
We have installed a moen 82490 one handle tub & shower unit. When we turn on the water you could shower and bath at the same time. If you pull the plug for just a shower the water to the spout stops...
If you pull the silver knob on the tub spout up, the diverter located located inside will redirect water up to the shower head and when lowered it will return the water to the tub spout. It sounds as thought the diverter is not working properly. Hope this helps..
Mar 08, 2011 | Moen & One Handle Tub & Shower Faucet
Moen Shower Valve Model L82839 installed: Water comes out of shower head when running bath. Thanks.
Only two possibilities here the diverter tub spout is not open all the way to let water to the tub only or the shower valve is installed up-side-down.
http://www.moen.com/shared/pdf/l82691pt.pdf
Mar 06, 2011 | Moen & Posi-Temp Single Handle Shower Or...
Installed new tub/shower valve, water comes out of showerhead when water is turned on even though spout is open
the diverter valve is probably bad. put a new one in. the valve cuts off the water to shower, while running bath water.
Nov 23, 2010 | Delta Faucet Plumbing
Shower/Tub Diverter Value Low Water Pressure
I had the same problem. I discovered that an O ring was missing (or I lost it without noticing) from a new diverter that I installed. Just got an O ring that fits on the threaded part of the collar where it meets the pipe. Worked fine. Amazing how a little plastic piece could make such a difference.
Jan 25, 2010 | Eljer Arlington Non-Jetted Acrylic Bath...
Pull down shower diverted works, but allows bypass into tub
The diverter is supposed to leak a little bit, so it will disengage after you turn off the water. If the water is leaking out a little, that's normal. But if it is really leaking out you may need to replace the entire spout.
Aug 11, 2009 | Delta RP17453SS Standard Diverter Tub...
Kohler bath/shower diverter stem stuck on shower
Probably has water deposit minerals build up on it. Push and or pull with pliers until freely moves,soak in Lime away solvent ,toothbrush on.
Mar 14, 2009 | Kohler Plumbing
Open Questions:
See all Paini Spa Rubinetterie LaToscana Ducale Questions
Paini Spa Rubinetterie LaToscana Ducale Thermostatic Shower Faucuet With Shower Head, Bronze Logo
Top Paini Spa Rubinetterie Home Experts
Donni Steen
Tom Chichester
Are you a Paini Spa Rubinetterie Home Expert? Answer questions, earn points and help others
