Question about Evenflo ExerSaucer SmartSteps ABC Stroller
How to change smart steps batteries - Evenflo ExerSaucer SmartSteps ABC Stroller
An 08 prius keyless entry doesn't work, changed the batteries, pushed the disable button and reset it, still no go. Any ideas?
1. Start with the key out of the ignition, drivers door is open all others closed and
drivers door is unlocked.
2. Perform these steps within 5 seconds.
A. Insert the key into the ignition and Pull key out twice (Do NOT Turn)
3. Perform these steps within 40 seconds.
A. Close then open the drivers door twice.
B. Insert the key into the ignition(Do NOT Turn) Pull key out.
4. Perform these steps within 40 seconds.
B. Insert the key into ignition and leave it in ignition.
C. Close the drivers door.
D. Turn the ignition to ON (Do NOT Start) then back to OFF.
E. Remove the key from the ignition.
5. Within 3 seconds, the power door locks should lock then unlock automatically
indicating successful entry into programming mode.
Return to step 1 if the locks do not cycle at this point.
6. Perform these steps within 40 seconds.
A. Press the lock and unlock buttons on the remtoe simutaneously for 1.5 seconds.
B. Immediately after letting go of the lock and unlock buttons,
Press the lock button by itself and hold for 2 seconds. Within 3 seconds, the door
locks should lock and then unlock once indicating successful programming. If
the door locks cycle twice, repeat steps A and B in step 6 as the remote was
not accepted.
C. Repeat steps A and B in step 6 for each new remote.
7. Open drivers door.
Jul 17, 2014 | 2008 Toyota Prius
Hi my APC smart 3000 UPS THE AVR boost LED IN ALWAYS ON. DO I NEED TO CHANGE THE BATTERY?
How many years the batteries working?
Usually every 4 years change the batteries.
Do you have power down often?
Feb 24, 2014 | APC Smart-UPS RT 3000VA UPS System
APC Smart-UPS 1500RM (sua1500rm) UPS System - charge lights flashing after changed battery
For APC smart-ups models, you need to do a UPS calibration after you change the battery. You need to change the UPS parameters to removed the flashing lights on the front panel of the UPS, usually you need to change the 0 parameter to its default state to remove the flashing lights.
Mar 16, 2012 | APC Smart-UPS 1500RM (sua1500rm) UPS...
The red light is on the SMART Board 580 and we need to fix the connection so it shows green but don't know how to do this.
Find "SMART Board Tools" or "SMART Board Tools 2011" on your computer. Select Control Panel > About Software and Product Support > Tools > Diagnostics. From the menu select Service and then Start.
If the red light does not change to green, try the following steps located located here: http://preview.tinyurl.com/3qggntc
Ian Berg
Technical Support Specialist
SMART Technologies
http://www.smarttech.com/tcea
Aug 17, 2011 | Smart Technologies SMART Board 580 (SB580)
How to reset and change the code
Go to this page:
http://s7d5.scene7.com/is/content/BDHHI/kwikset-smartcode
which is a PDF file of showing the installation instructions for the 909-15 lock. Starting at Step7 is how to change the battery (a really good idea at this time), followed by the programming instructions. Follow the steps carefully--very important!
Jun 05, 2011 | Kwikset 909 909-15 Satin Nickel Smart...
How do I change the code?
Here's a link to the installation and programming instructions:
I think I'd pull/replace the batteries (step 7) first of all. Pay close attention to step 8, where you determine how to program for the direction that your door opens, and the actual programming, step 9.
Feb 23, 2011 | Kwikset 909 909-15 Satin Nickel Smart...
Smart key remote is slow acting and will not allow starting up the vehicle. Can the battery in the Smart key be replaced; and how? Does it have to be re-programmed?
Hello. Great question.
Yes, the battery can be the culprit, and it is easily changed.
Remove the metal key from the side of the smart key, and then split the casing of the smart key, via the slot. There is a small circular battery that you can remove and replace. Use the exact same battery.
No Re-programming is necessary. The smart key frequency is coded to the car. Changing the battery does not change the frequency.
Thanks for such a good question.
Dec 31, 2009 | 2006 Toyota Prius
Is there a way disable smart key on the outside of the motorola razr v9m phone? Settings change from Vibrate to Silent often so I miss my calls
Try to find "personalize" setting of some kind, and then change the smart key to perform something else, so it doesn't go set silent mode. I am not familiar with your phone, but on RAZR v3 smart key activates camera. However you can change it to do something else. The steps would be different for your phone I assume, but if you need an example of the general steps, there are videos on www.HandBookLive.com under Electronics category on Motorola RAZR v3 and there is a chapter on "Chaging Shortcuts"
Hope it gives you some ideas
Mar 04, 2009 | Motorola Cell Phones
Lock access code
Just follow the steps carefully and you should be up and running again. Thanks for the model number.
1) To reset/change the SMART LOCK code, follow these steps.
Press the MENU button on the remote to display the on-screen menu.
Press the Cursor Up (also known as CH + button, above menu button) or Cursor Down (CH - below the menu button) to highlight SMART LOCK. Then press the Cursor Right (VOL + button to right of menu button) to display the SmartLock ACCESS CODE screen.
Using the numbers on the remote keypad, enter 0 7 1 1. " INCORRECT CODE" will appear on the screen. Enter the code 0 7 1 1 again.
Cursor Down to CHANGE CODE and enter 0 7 1 1 and then CONFIRM CODE and enter 0 7 1 1.
Press the STATUS / EXIT button (left of CH +) to save the new code in memory.
2) If the grandkids have locked out any channels, then you will have to perform the following steps:
Press MENU, highlight SMART LOCK, right arrow, enter 0 7 1 1, confirm by entering 0 7 1 1 again.
Cursor to BLOCKING OPTIONS, right arrow, and highlight CLEAR ALL, right arrow.
You should then see CHANNEL....ALL, LOCK....YES, ALL UNLOCKED.
3) To turn SMART LOCK off, follow these steps.
Cursor to BLOCKING OPTIONS, right arrow, and highlight BLOCKING OPTIONS, right arrow,
Aug 19, 2008 | Hitachi 51F500 51" Rear Projection...
Evenflo ExerSaucer SmartSteps ABC Stroller Logo
26 people viewed this question
Top Evenflo Baby Gear Experts
Joyce Nokleby
Shehu Pro
Shehu Pro
Rick Moore
Rick Moore
Are you an Evenflo Baby Gear Expert? Answer questions, earn points and help others
