Question about Bell & Howell 254 Ra 8mm Movie Projector 7425
How to put film in?
How to load the film..
Loading film into it.
You pull down on the clip on the side of the camera. That will open the back of the camera. Pull out a little of the film from the canister. Put the canister into the side with the spindle. Put the end of the film that you pulled out over the roller on the opposite side of the camera then shut the lid and turn on the camera.
Jul 19, 2010 | Minolta F10 BF 35mm Point and Shoot Camera
I have no idea how to put my film in the "Pentax mz-m" camera? Someone help me. I'm new to this as I am just doing photography at school!
Pull up on the rewind knob ( left side ) to open the film door. put film cassette in chamber then lower rewind knob and pull enough film leader to the take up spool. attach film to spool. close the film door then advance the film to #1 on the counter.
Jun 06, 2009 | Pentax MZ-M 35mm SLR Camera
Can't load the film
Turn the camera on. Open the back. Insert film, pull it across to the red mark. Close the back.
Camera should load automatically.
You can get the manual at http://www.butkus.org/chinon/nikon.htm
May 22, 2009 | Nikon N75 35mm SLR Camera
Film won't load on Minolta 400si Maxxum Camera
My daughter took the camera to her photography teacher he was able to load the film by wrapping more film around the roller. It's not as easy to load as my Canon. I thought we had put plenty of film around it already. Oh well, it's working anyway.
Feb 18, 2009 | Minolta Maxxum 400si 35mm SLR Camera
Film will not load
Took out the battery, then put it back in. The film then loaded properly.
Jul 21, 2008 | Kodak Vivitar KV270 Film Camera
How to put film in the camera
Hey buddy5000,
The process to load film into your camera is as follows
1. Turn the camera on and make sure the frame counter reads 0 if it doesn't there is probably film in the camera.
2. Press the film door release button and slide the release downward.
3. Place the new film cartridge in the film cartridge chamber and pull out the film leader until it reaches the red dot on the bottom right side of the film chamber. Make sure the holes on the lower edge of the film engage the teeth on the sprocket.
4. Now close the back door and the film should load automatically and# 1 should appear in the frame counter, and if it does not then the film is not loaded properly.
I hope this helps!
Sincerely,
Allan
Go Ahead. Use Us.
Jun 10, 2008 | Minolta Maxxum 5000 35mm SLR Camera
Film not loading properly
The lines could be scratches in the negatives.
Have you looked CLOSELY at your negatives with a magnifier to see if the scratches are on your film?
And when you say "Serviced", do you mean "cleaned" also?
If you have scratched film, then return it to the place you got it serviced/cleaned and let the owner/manager know that you just had it serviced there and it's scratching your negatives.
If you have an automatic camera, this bit below will be of no help.
Assuming that your camera is a manual loader, it may be that you aren't putting enough film into the take up spool for it to catch.
Try putting a little more film into the take up spool when you are loading the camera, and MAKE SURE that the holes in the film LINE UP with the film sprockets.
Then after you close the film door and start advancing your film, look at the film rewind knob, if it isn't turning while you are winding in film, then your film hasn't caught in the take up spool.
Another way to tell if your film is advancing is to shoot a test shot, and then advance the film, and then lightly turn the rewind knob a bit.
You should be able to feel the tension of the film if it is loaded correctly.
Feb 13, 2008 | Nikon FM10 35mm SLR Camera
The film automatically loads then rewinds when a new film canister is added
Hm. Well, the way this camera works is actually very clever. When you first load a film into it, it winds the entire film out of the cassette and into the camer. As each shot is taken, the film is rewound back into the film cassette. The advantage of this is that if the back of the camera is accidentally opened, the shots which have already been taken are already safely back in the film cassette and will not be damaged by the light ingress. However, your camera is behaving strangely. I would check that the electrical contacts where the film cassette goes in are clean. You can clean them using a cotton bud moistened with methylated spirits.
Apr 13, 2007 | Canon EOS Rebel G 35mm SLR Camera
WHERE IS THE REWIND BUTTON TO LOAD THE FILM.
OK, U will see the hole that have arrow. Pull up and then open the inside film. Put ur film and close. Then push down the arrow. Then u can takin picture.
Jan 27, 2007 | Vivitar V3800N 35mm SLR Camera
Bell & Howell 254 Ra 8mm Movie Projector 7425 Logo
23 people viewed this question
Top Bell & Howell Office Equipment & Supplies Experts
jasbo
jasbo
Are you a Bell & Howell Office Equipment and Supply Expert? Answer questions, earn points and help others
