Question about Casio Watches
How to set the time of edb 310d
Set the tim
How do i set both times i cant fugure out how to sync the digital to the clock
Here is what it says to do if the hands don't match up with the display time (usually happens after you change the battery).
First, you must locate the buttons on the watch.
The "A" button is at the 2 o'clock position (upper right). The "B" button is at the 10 o'clock position (upper left) The "C" button is at the 8 o'clock position (lower left) The "M" (mode) button is at the 4 o'clock position (lower right), and is the only button you can pull out to set the times, calendar and programming.
To RESET the watch and do the ZERO POSITIONING after changing a battery or having a display error, do the following.
RESET 1. Pull the "M" button out to the setting position. 2. hold down the "A", "B", and "C" buttons simultaneously for 3 seconds, then release them. All digit segments will turn on and display completely.
ZERO POSITIONING 1. Press the "B" button and all the segments in the digital time will reset to zero, with "UTC" showing in the main digital window. 2. Zero the "UTC" minute and hour hand (located in 12 o'clock sub-dial) to the 24 o'clock maker (straight up). Button "A" will move the hands clockwise, and button "C" will move the hands counter clockwise. 3. Press button "B" - "HR" shows in the main digital window. Adjust the main (large) hour hand to the 12 o'clock (midnight) position using "A" and "C" buttons. At the same time, observe the synchronized 24 hour hand (small dial to the left of the main dial), to insure that it also moves to point to "24". 4. Press button "B". "MIN" shows in the display window. Adjust the large minute hand to also point to the 12 using the "A" and "C" buttons. 5. Push the "M" (mode) button back in to its normal position. The watch beeps and at the same time the hands jump slightly. ALL RESET and ZERO POSITIONING are now complete. 6. Reset the time, calendar and other modes.
To set the time. Note that changing the time in any of the cities will automatically update the time for all the cities. 1. Press the "M" button to move the mode hand to (TME) 2. Press either the "A" or "C" button to move to the desired city. 3. Pull the "M" button out to the setting position. 4. Press the "A" button. SECONDS will blink. Set them with "C". 5. Press the "A" button again, and MINUTES will blink. Set them with the "C" button. 6. Press the "A" button again, and HOURS will blink. Set with the "C" button. 7. Press the "A" button again, and 12 or 24 hours tim format will appear. 8. Push in the "M" button to its normal position.
To set the calender 1. push the "M" button to move the mode hand to (CAL) 2. Set the city using the "A" or "C" buttons. 3. Pull out the "M" button to the "setting" position. The numbers of the "month" starts to blink. this is an "american" date system with the month first, day second, and year third. Use "C" button to adjust the month. 4. Push the "A" button. The date (day) will flash. Adjust with the "C" button. 5. Push the "A" button. The YEAR flashes. Adjust with the "C" button. 6. Push the "M" button back in. The calender is simultaneously adjusted for all cities.
Couple of other "tips".
Switching the time on the digital display with the time shown on the hands: 1. Press the "M" button until the mode hand is in (TME) or (CAL) mode. 2. Pressing the "A" and "C" button together. The time will switch the between the main hands (analog) and the digital display.
Temporary Hand Retraction Pressing and holding the "B" button will move the hands out of the way of the display. Repressing the "B" button will put the hands back at the correct time.
hope this helps. Source: how to set time on a bulova marine star 96C30
This solution is from fixya member ropickym Fixya
Jul 03, 2014 | Bulova Marine Star 96C30 watch
Instructions for Bowflex WR30M?
In time mode, hold set (bottom right button) to change date and time. The selected (flashing) item can be changed in one direction only using the up (top right) button. Press set again to cycle through each item until desired settings are chosen.
In stop watch mode, the up button starts and stops the stopwatch, the set button will take a split time while the time is running. To reset the stopwatch, press set once while the time is stopped.
In alarm mode, the up button turns the alarm on and off. There are three alarms available. To cycle though alarm times, press set. To set an alarm, press and hold set until the time flashes, then set the alarm time using the up button, cycle through hour and minutes using the set button. When finished, press set again.
Timer mode. To set the timer time, press and hold set until the time flashes. The timer goes up to 23h:59m:00s. You cannot set seconds. Once set, the timer can be started and stopped using the up button. There is no reset for the timer, to start a new timer the time must be manual changed again.
To check heart rate, press and hold mode until PUL is shown, place two fingers, one each on the top and bottom metal contacts for 6-10 seconds to get reading (This works best when not in motion).
Apr 13, 2012 | Watches
I want to set the timming
1-Goto this link http://www.citizenwatch.com/COA/English/settings.asp
2-follow the instructions and get the user's manual for your watch
Jan 26, 2011 | Citizen 8700 BL8000-54L Wrist Watch
Just bought a Lacoste watch,and I am puzzled why they stress the importance of not changing the date between the hours of 11.45pm and 2.00am?.
If you change the date between those hours, and the watch is set for the correct time, it may automatically roll the date forward yet again. It could mess up the internal mechanism for changing the date. The date starts to change around 11:45 PM and can take a good long while for it to fully "engage" the new date, which is why they say to wait til 2:00 AM. The internal mechanics that change the date are very sensitive. If you force it to change the date while it is automatically trying to change it, it can off-set the little gears and they may not function correctly in the future. So just make sure the time on the watch is not between 11:45 PM and 2:00 AM when you change it. The best thing to do is to change the date to the day PRIOR to the day you want (for example today is the 21st, set it to the 20th, then advance the hour / minute hands past midnight so it automatically rolls into the 21st, and then you will know if you are on AM or PM).....
But just avoid setting it between 11:45 PM and 2:00 AM as they mention.
Please make sure you rate my answer 4 thumbs up, it is extremely important to me. I would be forever grateful if you could do so. If you need more help on this question please just respond to my answer here and I will get right back to you.
Thanks
Tim
Oct 21, 2010 | Watches
Tipsy clock programming lost leaflet. would like to down load leaflet. bought this inexpensive clock at BB&B.
Hi I was having a hard time with this too, but luckily I found my leaflet.
To set time:
Press Mode 1 time
Press Set 2 times/ press up or down for hour
Press Set again for minute
Continue Pressing Set (up to 6 times) until everything is set
Back to normal mode- Press Mode 4 times
To toggle between 12 hr and 24 hr, press Mode 1 time
To Set an Alarm:
Press Mode 2 times
Press Set 1 times for hour, continue pressing set like you did for the clock.
Back to normal mode Press Mode 3 times
To cancel Alarm Press Mode 2 times and Set 5 times
Jan 16, 2010 | Watches
Can not set the Digital tim on the Diesel DZ7101..WHAT TO DO??
I have the same issue, by pressing the bottom right button I get the numbers to blink but I can not change them. Someoen please help!
Thanks
May 31, 2009 | Diesel Watch DZ7071
User manual
Try this link:
http://world.casio.com/wat/download/en/manual/
Rate, please.
Mar 28, 2009 | Casio E-Databank EDB6101C Wrist Watch
How to set time on a bulova marine star 96C30
For some reason you cannot find the manuals on the Bulova web site any longer. But don't worry....
I have the manual for the Bulova Marine Star 96C30 Watch. This is easily fixable.
Below, I have typed the instruction on how to fix this issue as well as reset the time and calendar and a few extra tips in case you forgot....
hope this helps.
Feb 23, 2009 | Bulova Marine Star 96C30 watch
Military Time
Hello I have the same watch and had the same problem. You press the mode button till you get to the point to change the main time, you then press the reset button (bottom button on right side of the watch)to toggle to the hour place, you then cycle thru the time untill the "h" in the top right hand corners disappears and then the watch will be back on regular time.
Chris
Jun 17, 2008 | Bulova Men's Watch
Watches Logo
15 people viewed this question
Top Casio Watches Experts
Kazim ERGUNEY
Kazim ERGUNEY
Jimmy Accardi
Are you a Casio Watch Expert? Answer questions, earn points and help others
