Question about Honda Electrical Supplies
I have a honda em 1500 runs great but no power
Unit has no 110 output or does have 12 volt dc power,will start and run how do i fix it?
protek480
  • 1723 Answers
SOURCE: ENGINE RUNS BUT NO POWER TO OUTLETS
When you flash the field, are you going + 12 volts to the top or right side brush? Negative to the other brush? Try three times for 2 seconds?
Posted on Sep 26, 2009
SOURCE: Honda ems 4000 generator starts and runs great, but no power
At the controller, you need to see if it is actually sending electricity out of the Generator/Alternator, have a look where the leads from the power making unit mates, (Think of it as a motor in reverse) onto the board. There should be an AC Voltage there, then, work back, or out from there, trace the Voltage until it stops, thats the problem... Check the Breaker isn't tripped or faulty too.
Posted on Mar 22, 2010
kel1guy2002
  • 3740 Answers
SOURCE: Generac 5250 with a 8 hp Honda engine. Runs fine, no output
Take a resistance reading across the brushes with and Ohm meter. (not running) You should read a low resistance. If you have no resistance across the brushes then then either the brushes are not mating with the armature or the the armature is open.
IF you have resistance then the AVR (Automatic Voltage Regulator) in the endcap has failed. With the engine running and the Brush block disconnected you should have 4 - 12 VDC on the two wires going to the brush block. No voltage = bad AVR.
Thanks for choosing FixYa.
Kelly
Posted on Jul 30, 2010
ROMOAS
  • 97 Answers
SOURCE: I have a honda ex1000
if it is in fact made for the country's you stated then that's common do to they don't use 110 but unlikely do to there sales are international in reading the manual the rating is
120volt 60 Hz rated 900va max 1000va
the 12volt section 12volts 8.3 amp current
i am attaching 3 pix's of the wiring diag so you can trace the wires hope this helpsb34e74f.jpgb589d04.jpg1eb189d.jpg
Posted on Aug 31, 2010
  • 13 Answers
The plunger is stuck where the governor rod which is spring attached to the frame is. If you locate the governor metal rod on the lower level of the unit. zrock it to a higher rpm as you would a car carburator from under the hood.
This will free the plunger and the green light will go on and your current meter will register 120 volts.
When you lay up the generator for quite some time it often sticks closed. With monthly start up you will no have this problem reoccurr.
Posted on Oct 05, 2010
Honda eu3000is generator surges
Inverter Generator Benefits
  • The EU3000 series generators are inverter generators. The generator features an alternator, which produced high-voltage, multi-phase AC power. This power is converted to DC power and then converted back to AC. This process is controlled by a microprocessor and is necessary to provide stable, consistent power capable of running equipment sensitive to power surges. This type of generator provides higher fuel efficiency and lower operational noise ratings in a lighter model than home and work generators produced by Honda.
EU3000i Handi Specifications
  • The Honda EU3000i Handi is a 3,000-watt inverter generator that features wheels, folding handle and a recessed convenience light. The engine is a Honda GX160, which features a 163-cc displacement. The AC output is 120 volts, with an average rating of 2,600 watts and a maximum production of 3,000 watts. There are three receptacles to include a 20A, 125-volt duplex and a 30A, 125-volt locking plug. The DC output is 12 volts and 100 watts. The EU3000i can hold 1.56 gallons of unleaded fuel, which will provide consumers with 3.6 hours of run time at 25 percent load for 7.7 hours.
performance chips of BMW.
May 31, 2012 | Honda Eu3000is
Need to know the output power from my cigarette lighter port
Hi, you have a 15 amp fuse to run all 3 sockets. Total peak power available without burning the fuse is 15x12=180 watts peak. Please let me know if you have more questions.
May 23, 2011 | 2006 Honda Accord
Why would my new 1500 watt inverter readout show overload 13.8 volts entering
It would show overload if you're drawing more power than it can supply. 1500 Watts is a very high output for an inverter but that is the maximum it's capable of. As with any electrical supply you should not draw the maximum power it's capable of as this can cause it to burn out. Around 1200 would be the max you should draw continuously. You need to check the power requirements of whatever you're running on it. Also you need to check that it's capable of taking 13.8 volts. If 12 volts is the recommended input, putting in 13.8 will increase the voltage output which could damage appliances being run on it.
Jan 10, 2011 | PowerBright New 1500 Watt 12V DC to AC...
I have a honda ex1000 generator. The owners manual gives specs of 120vac at 3600rpm. Also 12 volt dc to charge a battery. It starts and runs great but measures 240 vac at both receptacles. There is no...
Aug 28, 2010 | Electrical Supplies
May 13, 2010 | Cars & Trucks
My battery is good and i road it for bout 2 hrs then came to stop and now it wont stay running unless i jump start it
You may need to clean connectors on battery wires ,or replace a fuse. The charge depleating could also be caused by a bad stator, stator wire conection or voltage regulator. after battery is charged test volts at battery while running, they should raise when rpms are increased to 1500 or 2000 or so, idle voltage may be 12 volts with rpms raised volts should go up to as much as 14.8 or so if all is well.if not keep looking for the problem from volt reg. back to stator .also stator output is AC and regulator output is DC.
Mar 25, 2010 | 1996 Honda CBR 600 F(3)T
Yesterday I bought an STP-120 SIMA power inverter
you inverter was not fully charged because it requires a 110/220 v ac as specified in the manual; to charge it so it is impossible for the aircraft 15vdc to charge it
Jan 27, 2010 | APC DC to AC power inverter ( external ) -...
B&D 400W Inverter won`t run my laptop
even the smallest inverter can run a laptop, something is wrong with this unit
Jul 25, 2009 | Black & Decker 1000w Power Inverter
Power supply
if you are in usa, you need 1-468-809-11 POWER UNIT input ac 110 volt and output 8.5volt dc
and if you are in uk, then
1-468-811-11 POWER UNIT input ac 220 volt and output 8.5 volt dc
bye.
Sep 08, 2008 | Sony ICF-CD855VSIL Clock Radio
Electrical Supplies Logo
26 people viewed this question
Top Honda Electrical Supplies Experts
John Trevino
Are you a Honda Electrical Supply Expert? Answer questions, earn points and help others
