Question about Haier Top Load Washer
My Haier portable washer is leaking from sides
2 Suggested Answers
hawk127311
  • 350 Answers
SOURCE: My portable haier dryer (HLP140E) has a bad odor.
No any smell coming from a dryer is not "normal," no matter what anyone tries to tell you. I would seek a replacement model immediately. You are not the first to complain about this model. Likewise, I would seriously consider a replacement for the washer as well, even though the smell has diminished. I hope this helps and good luck!
Posted on Nov 11, 2009
Where do I check the freon gas level in my Haier CPRB08XCJ
There are generally no fitting to connect to the sealed systems of portable air conditioners. You can buy a 'saddle valve' that will pierce the suction side and allow you to check low side pressure, but they will allow a very slow leak in most cases.
It likely uses R134a instead of Freon.
Jul 23, 2014 | Haier Commercial Cool 8,000 BTU Portable...
Drip water from bottom of dryer
Not sure what all you did already. But you may want to check your washer machine and see if it is spinning the clothes out. You may have problems with your washer machine. Loose belt, clogged up water pump. If your clothes are that wet and water is leaking from your dryer, the problem is not the dryer. Check your hose connection on your washer also.
Aug 05, 2012 | Haier HLP140E Electric Portable Dryer
How to drain water from haier 8000bt portable ac
There is a drain plug on the rear of the unit, just above floor level. Before draining into a low sided pan of bowl, capable of holding 1 quart of water, turn the unit OFF & unplug it.
Another draining option is to disconnect the exhaust hose(s) and roll the unit to a floor drain or outside to drain it.
Hope this helped you and thanks for choosing FixYa.
Sep 22, 2011 | Haier Heating & Cooling
My portable haier dryer (HLP140E) has a bad odor. I got it brand new from Walmart. It was happening with the portable washer (Haier HLP21E) too but that has seem to have faded. I've used the dryer a few...
Nov 11, 2009 | Haier HLP140E Electric Portable Dryer
Replacing drain hose of Haier portable dishwasher HDP18PA
how do i get to the hoses on maytag portable dishwasher
Jul 27, 2009 | Haier HDP18PA Stainless Steel...
9000btu Haier portable air conditioner HPAC99ER doesnt blow cold air. What do I need to do?
I own the Haier 9,000-BTU Portable Air Conditioner - White. This is the second day that my unit has blow out air that smells really bad. I went to check my unit to find that there was a leak of some sort of chemical that smells like what is blowing from my unit. What should I do?
Jun 06, 2008 | Haier Heating & Cooling
Haier Top Load Washer Logo
Top Haier Washing Machines Experts
Gerry Harvey
Gerry Harvey
Owen Barnes
Are you a Haier Washing Machine Expert? Answer questions, earn points and help others
