Question about Xerox WorkCentre 6605/DN Color Laser Multifunction Printer
How to quiet a noisy workcentre 6605dn
There is an intermitent grinding noise when printing. what is the cause and how can I fix it
2 Suggested Answers
  • 30 Answers
SOURCE: Xerox 6360dn, Tray 2 makes loud grinding noise
In my experience, it was the registration roller causing the grinding noise. See http://my.brainshark.com/Phaser-6300-6350-6360-Grinding-Noise-795590408 for troubleshooting video.
Posted on Dec 15, 2010
What is the cause and solution of a grinding noise when printing from a xerox workcentre 6605dn color laser
Defiantly a main drive issue, slipping belt can make the noise you described, sometimes the pulley gets tight or the tensioner binds causing the belt to slip
May 17, 2014 | Xerox WorkCentre 6605/DN Color Laser...
Xerox grinding noise
the bearing on the motor or the rotating path must have damaged..
replace them
Jun 02, 2008 | Xerox WorkCentre Pro 215 Printer & Copier...
What is the cause and solution of a loud grinding noise coming from a xerox workcentre 6605 when printing
Sometimes when the toners get low on toner you will hear the gears grinding, or if there is an obstruction in the waste toner auger. Also check the drum units to make sure they are turning freely.
May 16, 2014 | Xerox WorkCentre 6605/DN Color Laser...
Noisy printer
The printer or the drum/toner unit may cause the grinding or clicking noise.
  1. Power off the printer and open the front cover.
  2. Remove the drum/toner unit and close the front cover.
  3. Power the printer back on.
If the grinding or clicking noise dose not occur when the drum/toner unit is removed from the printer, then the drum/toner unit is the cause of the noise. Install a brand new drum unit and/or toner cartridge may be necessary to stop the noise.
Still having Problem Then follow Us For
Brother Printer Support
Feb 25, 2014 | Brother DCP Office Equipment & Supplies
Xerox 6360dn, Tray 2 makes loud grinding noise when printing. Tray 1 is as quiet as a mouse. Replaced tray 2 with a known good tray and it still makes grinding noise.
Oct 18, 2010 | Xerox Phaser 6360DN Printer
Noisy dishwasher
It is the wah motor. contact Frigidaire for a replacement motor that has been redesigned to eliminate that noise
Feb 26, 2010 | Frigidaire Dishwashers
Makes growling noises throughout the cycle.
HI. here are the most common issues that will cause a noise during the wash.
* Check the spray arm for damage and obstructions
* Check the inlet filter screens
* Test the water inlet valve(see below for test procedure)
* Check the motor and mounts- The motor may e loose or one of the mounts may have separated form the housing. this will cause mis-alignment.
* Check the fan motor and blade
* Check the drain for obstructions
NOTE
If all checks out above, the culprit will be a cracked pump impeller. this will occur if the drive stud becomes unstable, allowing the impeller to partially separate form the motor spin drive stud. this will cause the impeller to rub or grind during the wash cycle. If this is the case, there are impeller repair kits available for purchase that will correct this issue.
Sep 25, 2009 | GE Dishwashers
Xerox workcentre pro 416dc
You may have over packed the toner....take it outside and empty it onto newspaper carefully! Shake the unit the loosen any hard pack, then try it in the machine ..if it is now quiet put HALF thetoner back.....if it is still noisy you might have busted the toner drive auger it's made of the 20th Century wonder material plastic
Jun 20, 2008 | Xerox WorkCentre Pro 423 Copier
Noisy Amana ABB2227DEB
The motor is an "auto damper" that opens/closes to let cold air from the freezer comp. into the refer comp. depending on the temp. There is nothing you can do for maintenance, the little motor runs the damper when needed automatically. Some motors are quiet, some are noisy (grind grind grind) as the open and close. Sort of the nature of the beast, if you're lucky you get one that stays quiet.
Feb 26, 2007 | Amana ABB2227DE Bottom Freezer...
Xerox WorkCentre 6605/DN Color Laser Multifunction Printer Logo
82 people viewed this question
Top Xerox Office Equipment & Supplies Experts
Michel
Xeroxrep
Level 1 Expert
Philip Hughes
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
