Question about Toro Titan ZX4800 23HP Zero Turning Radius Lawn Mower 74830
How to replace a pto switch
I had a pto switch melt and it popped out and smoke rolled out. Replaced the switch and now it will not start What is wrong with it
Replaced battery and solenoid, not it wont start and smoke rolls out from under the tank/console area, what should I check?
The startr motor is fried or u hav worn cables w alot of resistenc. Fixit bfor car fire
Oct 23, 2015 | Polaris ATV
I have a Toro 42 zero turn mower and the blades stop turning while mowing. The PTO switch knob melted. I replaced the PTO switch and the blades turned for 5 min. and then the PTO switch melted again.
Elertric blade drive clutches are a real pain when they go wrong
It sounds like a electrical short is causing the wires inside the switch to heat up beyond the safe melting point thereafter five mins the circuit gets between the fault gets broken as the switch fails the blades stop and the switch melts a bad eaRth corroded may cause this check the deck safety switches are not exposed e.g. they been damaged and the decks metal is shorting them out
a wire has been stripped of protective covering and is touching some metal shorting out something that vital to the blade controls operation the switch is getting a overload and subsequently melting your might need an lawnmower engineer to diagnose to the fault fully and repair
Apr 23, 2015 | Toro 42 In Deck 19 Hp Kohler Courage Twin...
I have a Toro Zero Turn 50" mower with a Kohler 16HP engine. My PTO switch melted
pull the wires of of the pto in case it is shorted check charge at battery tomake sure wires havnt rubbed through
Feb 10, 2013 | Toro Garden
Not receiving power to the PTO Clutch connector.
It may well have burnt out the pto switch itself if there was that much power draw.
May 01, 2012 | Garden
JD STX38 PTO disengages and melts the PTO switch? As I'm mowing along the blades disengage and then I push the PTO switch down and back up and the yellow button comes out and shows the bottom of it...
Electric Blade Clutch is shorted or if you are lucky the wiring to the clutch is grounded. Many times the wiring to the clutch is caught in debris or twigs etc. and pulls the wiring out and cuts and grounds it.
Aug 25, 2017 | Garden
GTH2548 drive spring broke and I replaced it. Tractor would not start. Replaced battery, start switch, seat switch and PTO switch. Tractor will now start and runs well. However, when PTO switch is...
yes when the belt broke it grabe the wires that goto the cluch frome the pto switch and thay have bar spots on them and are grounding out i just done one that was doing the sam thing all you have to do is fix the wires and that should fix ya up thanks for your time mickey
Sep 08, 2010 | Husqvarna 25HP Hydrostatic 54"Cut Garden...
Eletric PTO is not working
The PTO draws a pretty good current, so a weak or loose contact in the switch, or in the connections on the back of the switch, could cause this overheating. But it could also happen if the PTO clutch itself or the wiring to it has a short. If the mower's still under warranty, get the dealer to diagnose and fix it. If not, then I'd measure the resistance of the PTO clutch - should be about 2 ohms - and make sure the wiring to it isn't shorted. If all that is OK, then just replace the PTO switch and any melted connectors and wiring. Good luck!
Jul 07, 2010 | John Deere 420,1020,2010,2020,2510,2520...
Blades won't engage when the engage knob is pulled
there is no adjustment drop deck all the way down spray all moving parts with wd40 mash clutch all the way down release quickly several times crank and try
Sep 01, 2009 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Toro Titan ZX4800 23HP Zero Turning Radius Lawn Mower 74830 Logo
21 people viewed this question
Top Toro Garden Experts
Joseph Mueller
Joseph Mueller
lnbn1975
Mike Squire
Are you a Toro Garden Expert? Answer questions, earn points and help others
