Question about Intermatic Inc. ST01C Digital In-Wall Timer
I have installed a utilitech #0141224 in wall timer and it turns on lights but i can't get them off. they stay on in all settings. help please
  • Intermatic Master
  • 5,245 Answers
5 Suggested Answers
SOURCE: Utilitech model 0141224 wall switch
As luck would have it I'm 60, and learned how to program your 0141224 wall switch timer.
You can see instructions with big print and pictures on following page.
Press CTRL key on keyboard and use scroll wheel on mouse to make web print bigger.
http://waterheatertimer.org/Program-wire-Utilitec-LW60418.html
Add a comment any time.
You have wired your timer correctly and the lights turn on when you push on-off button.
If lights do not turn on, we need to review the wiring.
Your timer looks like photo below.
I'm going to parrot back the manual with some extra words.
To start, press the reset button and clear any programming
Programing overview:
Each program has ON time ... and OFF time
So you set program1 ON and then set program1 OFF
When you set program1 ON, you choose the Day, hour and minute you want program1 to turn ON.
And then you set program1 OFF, and choose Day, hour and minute for program1 to turn OFF.
Your ON-OFF times for program1 should be on same days.
For example program1 ON for all-days-of-the-week, but program1 OFF is for TU Tuesday, then timer will not work.
IN this case, program1 OFF should also be set for all-days-of-the-week.
Let's start.
Setting the clock:
Press and hold CLOCK button
Keep holding CLOCK button and press DAY button until display shows current day (MO TU WE TH FR SA SU)
Press Hour button until current hour with am pm displays
Press MIN button until current minute displays.
Release clock button and current day and time show on display
At no other part of instructions do you press and hold one button while pressing other button.
Setting programs:
Press PROG button until "1" and 'ON' show on display
This is program1 ON
Press DAY button to choose which days for program1 ON.
You can choose: all-days-of-the-week and MO TU WE TH FR SA SU show on display
Choose individual days and MO or TU etc shows in display
Choose weekdays MO TU WED TH FR
Weekends SA SU show in display
Next step
Press HOUR button to select hour for program1 ON
Press MIN to select minute for program1 ON
Now program1 ON is ready, next, you will set program1 OFF
Press PROG button until "1" and 'OFF' shows on display
This is program1 OFF
Press DAY button to choose which days for program1 OFF.
( Remember, you want same days for ON and OFF)
Press HOUR button to select hour for program1 OFF
Press MIN to select minute for program1 OFF
Now program1 ON and OFF are ready, next, you will set program2 ON by repeating same steps above.
You can set up to 7 programs.
If you don't want to set program2, or any more programs, that's fine.
To exit programming and save your program, press CLOCK.
Now current time shows in display.
Final step: set MODE
Press MODE button until AUTO shows in display. You want AUTO for programming to operate lights. That's it, timer is ready.
If you're going on vacation, press MODE button until RDM shows in display, and then timer turns lights on-off at random
Copy and save these instructions to your computer so you have them next year.
Posted on Dec 05, 2010
SOURCE: RE: Utilitech 7-day in wall
1) Utilitec timers cannot be used for multiple switch replacement.
They replace only single-pole switch.
2) Open following link to see specific timers that can be used for 3-way.
http://waterheatertimer.org/GE-timers-and-manuals.html#15071
3) In your case you have 3 different switches that control outside lights: so you have two 3-way switches and one 4-way switch.
Open following link to see typical 4-way wiring.
http://waterheatertimer.org/images/Typical-3-Way-switches-450.jpg
4) 3-way timer will replace one of the 3-way, but not the 4-way.
The timer can be used in place of the 4-way switch.
Identify 4-way because it has 4 screws and 4 wires (excluding ground wire)
5) Keep in mind that 3-way timers replace one of the 3-way switches.
But wiring has to be changed at the remaining 3-way switch.
Open following link to read why wiring is changed at remaining 3-way:
http://waterheatertimer.org/ST01C-program.html#3way
Wiring at the 4-way switch is left the same.
When you buy the timer, read manual carefully for correct wiring, or add a comment to this thread, and I will help more.
Add a comment for more free help.
Also take advantage of fixya expert assistance live.
For a price, expert works with you while you work on timer or any do-it-yourself project.
Fixya is always less expensive than a service call.
Posted on Mar 24, 2011
SOURCE: I have installed a Utilitech
You are replacing single-pole switch, then 0141224 is correct choice.
It sounds like your have wiring wrong.
No jumper is needed from other switch, all you need are two wires from replaced switch plus a neutral wire.
Open following link for detailed wiring instructions and online manual.
http://waterheatertimer.org/Program-wire-Utilitec-0141224.html
Add a comment and ask about particular part of manual or wiring if needed.
Posted on Apr 20, 2011
SOURCE: Hi,
Wiring is wrong, timer is defective, or power is off.
If power is ON, then push reset button for several seconds.
Open following page for correct wiring of Utilitec timers.
http://waterheatertimer.org/Program-wire-Utilitec-0192773.html
If you have different timer, add a comment with in-focus photo of your timer for correct identification and possible assistance.
http://www.fixya.com/support/r6568559-post_photograph_fixya_questions_answers
Posted on Apr 22, 2011
I have a Utilitech #0141224 installed, but the display doesn't light up. How do I change or replace the internal rechargeable battery?
Modern timer batteries are built into the circuit board and not replaceable ... sounds like a different problem since battery is back up carryover for power outage.
Push override and see if load operates.
Troubleshoot resources and manual:
http://waterheatertimer.org/How-to-troubleshoot-timers.html
http://waterheatertimer.org/Programmable.html#0141224
Aug 09, 2017 | Hardware & Accessories
Utilitech TM029 manual needed
Copy following link for TM029 aka LW60418/ 0141224:
Add a comment and describe timer in detail.
Gene
h
Sep 20, 2013 | Hardware & Accessories
I have installed a Utilitech timer switch #0141224 on one of three switches. The switches are all in a row but I only want the last (rightmost) switch changed out. Do I need a jumper from switch 2 to 3? ...
Apr 20, 2011 | Intermatic Inc. ST01C Digital In-Wall...
I can not get the timer to automatically turn off and on UTILITECH 7-DAY DIGITAL IN WALL TIMER
Utilitec sells two different 7-day timers.
Open following two links to identify timer, see manual, and read wiring instructions:
From description of problem, it sounds that timer programming is not correct.
Each event needs ON time and OFF time.
If ON time is set.but OFF time is not set, then timer will turn ON and never turn OFF.
ON and OFF times must match days with each other.
Also if programs overlap or conflict, timer will not operate as expected.
I think instructions for both timers say that programs can be reviewed by pressing PROG button.
Re-read manual carefully.
Write out parts of manual that are confusing.
Also take advantage of fixya phone service.
For a price, expert speaks with you over phone while you work on timer or any do-it-yourself project.
Dec 09, 2010 | Intermatic Inc. ST01C Digital In-Wall...
Intermatic Inc. ST01C Digital In-Wall Timer Logo
706 people viewed this question
Top Intermatic Hardware & Accessories Experts
Craig Butler
Craig Butler
Gene Haynes
Jay Finke
Jay Finke
Are you an Intermatic Hardware and Accessory Expert? Answer questions, earn points and help others
