Question about Pool & Spa
Why does kreepy krusier stuck on light - Pool & Spa
Creepy not working good suction it sticks to the bottom of the pool and wont move
If it is an actual Kreepy Krawler that Pulsates and you have good suction then you should look k side and see if something is stuck inside the diaphragm or if the diaphragm is torn then it has to be replaced.
Jan 01, 2015 | Pool & Spa
My kreepy krauly wont clean the deep end of the swimming pool.
Your situation is unusual in that most of the time these will stay in the deep end and not get to the shallow end. Make sure that your hose is the proper length and the hose weights are in the right positions
Up to 4 feet water, 1 weight at one foot away from Kreepy
4-7 feet water, add a second weight at 6 feet from Kreepy
7-12 feet water add a third weight at 10 feet from Kreepy.
It can take some trial and error to get the Kreepy to cover the whole pool. This includes adding or removing hose sections, and adjusting the pool return "eyeballs" to different directions.
Feb 21, 2014 | Universal Kreepy Krauly In-Ground Pool...
Kreepy krauly regulator valve won't close, it's always open so the cleaner doesn't move. There's plenty of suction,
It has debris stuck in it. Normally it is not too hard to clear it out. If you can't clear it, try to run the Kreepy without the regulator.
Aug 04, 2013 | Pentair Kreepy Krauly Inground Automatic...
Our kreepy has a beige paint like film all over it and it's not kreeping anymore. Nothing is stuck inside of it. Any ideas as to why it has this film/stopped working? I have it soaking in vinegar and...
sounds like something caused your water to precipitate scale. high pH or alkalinity coupled with an elevated calcium hardness may do that. make sure the footpad is in good shape, should have visible groves, if it's completely flat get a new footpad.
Aug 13, 2011 | Universal Kreepy Krauly In-Ground Pool...
My Kreepy has a Starfish seal on it. It is being used in a pebble tec pool. I bought it new less than a year ago. Here are my problems...The Kreepy is getting stuck by my stairs (they are more like...
If the cleaner is getting stuck on objects (steps, ladder, corners, benches, etc), you need to remove the dive float restrictor and install a wall climb adjuster. It is part number K12065. Anyone that sells Pentair products should have one. This will keep your pool cleaner from becoming stuck. It might also help with the seal problem, but that is most likely something caught in the flapper. Check to be sure that the pool cleaners getting proper flow and that the flapper is clear of debris.
Jul 09, 2011 | Universal Kreepy Krauly In-Ground Pool...
Kreepy cleans the deep end great. It cleans the walls and bottom but will not venture up the slant to the shallow end
There are several things that could cause these automatic pool cleaners to have this problem. First, check the return line water flor and redirect it if necessary. Also, make sure that the hose is long enough to cover the entire pool without difficulty. Also, check the hose balance to make sure that it is correct.
Jun 22, 2010 | Universal Kreepy Krauly In-Ground Pool...
Hi my kreepy krauly wont stay flat on the bottom of the pool???
Do you have any hose weights fitted to the kreepy hose? If you do,take it off and see if it makes a difference.Is this happening while the kreepy is operating?
Nov 21, 2009 | Universal Kreepy Krauly In-Ground Pool...
Pool & Spa Logo
23 people viewed this question
Top Pool & Spa Experts
Jay Finke
Jay Finke
Bill Jordan
David Spradling
David Spradling
Are you a Pool and Spa Expert? Answer questions, earn points and help others
