Question about HP Compaq nc6220 Notebook
I THINK IT IS OVER-HEATING
I think my nc6220 is over heating, I had not observed it before, but lately I feel it too hot . Could the the problem be just the fan needing replacement?
    Scholar:
  • 36 Answers
Hello
The computer is usually clogged with dust and other debris. See if the following instructions help.
compaq nc6220 disassembly instructions
http://static.tigerdirect.com/pdf/c00622160.pdf Compaq Manual
Goto page 107 and follow the instructions to page 108.
Goto page 118 and follow the instructions to page 121.
Goto page 126 and see below:
Be sure to have a duster can with a extender tube on hand now.
On Page 126 You will remove the fan. This and the next page are the purpose
of doing this work. Follow the fan removal instructions. Check that the fan
turns freely. Take the duster and the fan and carry it outside if it is very
dusty and clogged up. Now blow the dust and accumulated debris from the fan.
Set the fan aside.
On Page 127 You will only examine the heat sink, do NOT remove any screws here!!!
The heatsink is a copper or black colored assembly with heatpipes that curve to
the right into the cooling vanes. Look into the cooling vanes that are located
in the area where the fan was mounted. If there is blockage take you duster and
the extender tube. Insert the tube into the duster and try to hold the can
upright at all times. Now spray the gas into the cooling vanes with the tube
facing the side of the computer. This will be dusty. You may want to do it
outside if careful. Otherwise, wear a dust filter mask.
To re-assemble follow the instructions in reverse order.
If there was a blockage you will see a immediate improvement.
I hope that this helps.
Posted on Jun 23, 2009
  • 39 Answers
Once you cool the computer down turn it back on and listen for the fan running. If you cannot hear it you will need to replace it. Make sure you are using your laptop on a hard flat surface. Using your lap or a pillow is the most common cause of overheating. Don't keep using the computer if it continues to overheat like this, overheating will eventually ruin your hard drive and cause a mess of problems. If your fan does seen to be running ok, try running out and getting a cooling pad to use your laptop while it's on your lap, some of the new ones have fans in them which will give you an extra boost of help on keeping your computer running cool at all times.
  • 51 Answers
Don't worry your computer fan is not broken and does not need replacing. What you do need to do though is always keep the laptop on a hard surface so as to increase airflow and never block the vents up otherwise the laptop will heat up even more. You can buy a fan board such as this http://www.xpad4laptop.com/?gclid=COK92bOooZsCFdUB4wodjVZ7DQ This will cool your laptop down even more. Hope this helped. Please rate me if it did.
I now have a new problem,my wife has a 2006 Hyanda Elantra,it has been over heating ,and she says her heater does not get hot,I think them thermastate may be sticking,am i correct what should mi do?
it can be the thromstat,but have you check to see if both heater core hoses are getting hot. if only one is getting hot then you need a heater core
Dec 05, 2012 | GMC Yukon XL Cars & Trucks
I don't think the water is getting as hot as it used to in my Ariston dishwasher. Our hot water heater is set high enough, but when I tried one of the dishwasher cleaners, the plug did not disolve as...
Check your heating element..
A bad heating element causes many problems in dishwashers...
Dishwasher Problems The Heating Element not Working
How to Replace the Dishwasher Heating Element
Dishwasher Maintenance
heatman101
Asker's Testimonial " explanation very clear. will give it a go and seehow simple it was. thanks Ronnie " - ronnieshomes
Aug 28, 2011 | Ariston Technologies Dishwashers
Problem with heating element?
HI Put the dishwsher in the dry cycle and after a mineute or so feel the element if its hot its ok. If not you need a electrical meter to check it
If you need further help, I’m available over the phone at https://www.6ya.com/expert/dude_653d05454b389bba
Feb 27, 2010 | GE Dishwashers
1999 Jeep Grand Cherokee bad blender doors. Can I remove the blender doors completely as opposed to replacing them? If I just rip out the broken ones and leave them out what will happen?
I tried that but not my heating core is not getting hot just warm. i think they computer is turning it off because it still thinks the doors an closed. This is what im trying to figure out. I felt the heating hosing under the hood and they both feel hot going in and out of the heater. I am getting luke warm air which is better than the freezing air though
Jan 29, 2010 | 1999 Jeep Grand Cherokee
Engine heating up think it cuz of points or timing off. want to know how to fix
3 things can make a engine run hot
1 lean fuel mixture
2 late in spark timing
3 timing chian is stretched
1 check spark plug colour to determine if burning lean
2 advance timing, on points turn plate but eletronic need to change pick-coil loaction
3 adjust chain tensioner or major overhaul replace chain, would need to get a manual for this repair
Nov 17, 2009 | 1981 Yamaha XJ 650
Is not heating
i think when this happened to my sister it was the heating coil. her dryer caught on fire. don't run it unattended.
Aug 01, 2009 | Kenmore 700 6972 Dryer
I have had my dryer for about a year and a half and just recently it seems that the heating part went out cause the clothes doesn't feel warm or hot when i get them. How long should the heating part of the...
The fix is easier than you think, you need a new element, and some of them DO last up to 20 years.....if you treat then well. Don't forget to clean out you vent hose and the outside of the vent to...prevents fires!!
Jul 31, 2009 | Frigidaire Dryers
Heating, but no hot water on a vaillant turbomax 28 combi
the problem is the diverter valve unit, source a corgi engineer to fit new one, cost for valve approx 80 quid +fitting
Kindly
Richie
Dec 15, 2008 | Water Heaters
Heating problem
I can't solve your problem, but since so many people who own a highlander are have the same types of problems, it seems to me that Toyota should be checking into this problem.
What do you think?
I am going to call my dealer today.
May 22, 2008 | 2003 Toyota Highlander
HP Compaq nc6220 Notebook Logo
404 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Alun Cox
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
