Question about Eljer 141-0220-00 Toilet Tank White
How to remove an eljer toilet flapper? - Eljer 141-0220-00 Toilet Tank White
  • 512 Answers
SOURCE: Slow water leak past flapper seal.
Replace flapper, it is worn out.Turn off water valve. Flush toilet, remove flapper. Then replace flapper, adjust chain to same size as old one, then turn water back on.
Posted on Aug 19, 2009
SOURCE: Eljer Canterbury one piece remove flush valve
I had the same problem and contacted Eljer and they sent me the above instructions to make a tool to remove the flush valve.
Posted on Jan 07, 2010
radar001
  • 1051 Answers
SOURCE: My Eljer toilet does not always flush completely.
Not being a plumber by trade I don't want to bad mouth what your plumber had to say but there may be other things to consider.
If the toilet does not flush directly into the main drain there is the possibilty that the coupling between the main drain and the toilet drain is under-sized which could cause reduced water flow and your toilet not flushing completely.
Posted on Feb 26, 2010
  • 51 Answers
SOURCE: Toilet runs around 1 per hour.
I had the same problem with my new flapper. Instead of vasoline, use "plumbers' grease". You can buy it in a small tube at Lowes, HomeDepot, etc for about $4.00. I use the silcone based stuff and it never washes off. You will find other uses for this stuff. It is great!
Posted on Apr 21, 2010
  • 299 Answers
SOURCE: Occasionally after flushing ,water continues to
Make sure the flush valve is closing properly and that the water level is not set too high causing water to enter the overflow tube. If the flapper seat is damaged and cannot just be be cleaned, you can add a new seat right over the old one. Fluidmaster sells them for just a few dollars. Most hardware stores have them - Home Depot and Lowes stock them.
Posted on Feb 27, 2011
Flapper leaks
this is a case that dictates you replace the flapper.
Mar 06, 2011 | Eljer 141-0220-00 Toilet Tank White
Leaks from tank into bowl and when flush as it
Change the flapper with a generic one that will fit that toilet... the OEM flapper is **** and it does not allow for a good flush either...
heatman101
Aug 03, 2010 | Eljer Toilet Onepiece Canterbury ...
I have several eljer canterbury toilets with master fluid filler valves and the flapper seems to fluter when it fills and takes on water 2 times a night. i have tryed several types of flappers?...
Hi Guy they have a hole in the flapper with air pocket that casues them a problem, you can buy aa flapper wth a chain on it that has a float on the back of the flapper valve so you can adjust it to work right. my experince has been to put the float right up aagainst the back side of the flapper. they cost $3.99 at any hardware store.
Jun 17, 2010 | Eljer Toilet Onepiece Canterbury ...
I have one piece Eljer toilet, water tank is emptying. What do I do? It usually happens oner night.
flapper valve leaking check for build up or debris if clean check adjustment or replace flapper
Jun 10, 2010 | Eljer Toilet Onepiece Canterbury ...
I have to hold the lever of my Eljer one-piece toilet to flush it. How to adjust it?
lift off cover and shorten flapper to handle chain/rubber connection flapper not opening all the way
Apr 11, 2010 | Eljer Toilet Onepiece Canterbury ...
My Eljer toilet does not always flush completely. It is approximately 20 years old. I don't believe that it is a venting problem. I have dismounted, inspected and remounted the toilet and found nothing...
Feb 26, 2010 | Eljer & Elongated Toilet Bowl
Sep 09, 2009 | Eljer Toilet Onepiece Canterbury ...
Aug 19, 2009 | Eljer Toilet Onepiece Canterbury ...
Eljer century toilet splashes water up on toilet seat
You can try replacing the flapper with a timed flapper. You can purchase one at Home Depot and they are made by fluidmaster. Set the flapper on the shortest flush time thus reducing the flow of water. If this doesn't help, try to isolate the particular holes that are causing the greatest amount of splash. Using an epoxy glue (after the holes are completely dry) plug them up with the glue. This is a permanent fix so be careful.
Apr 10, 2009 | Eljer Toilet Twopiece Century 091820543
Eljer 141-0220-00 Toilet Tank White Logo
81 people viewed this question
Top Eljer Home Experts
john h
Mike
Donni Steen
Are you an Eljer Home Expert? Answer questions, earn points and help others
