Question about Troy Bilt Tiller/Edger 26cc, Model No. 21at144r766
Trouble shoot cranking a troy built edger - Troy Bilt Tiller/Edger 26cc, Model No. 21at144r766
4 Suggested Answers
  • 25 Answers
SOURCE: my troy built brand edger's motor dies when about to operate
Is the choke still on ? How about the condition of the spark plug ? Air filter and fuel filters clean ? Make sure the lower unit is lubed up and nothing is binding.
Posted on Jun 23, 2009
#1 Taper
  • 1041 Answers
SOURCE: looking for a owner's manual for a troy built
This link should get you where you need to be:
lawnandgarden.manualsonline.com/ex/product/headline/m/troybilt/d/edger/p/TBE515
Jim
Posted on Sep 17, 2010
  • 371 Answers
SOURCE: Why is oil coming out of the muffler when I try to crank a Troy Bilt 4.0 edger?
Dit it get overturned? Sit it upright, pull out the plug, spray carb cleaner inside, pull repeatedly to clear oil. Ground the coil wire while pulling or you will ignite the carb cleaner- POOF!
Posted on May 03, 2015
How to put on new belt
https://www.partstree.com/parts/troy-bilt/edgers/tb516ec-25a-516-966-troy-bilt-edger-2011/general-assembly/
Zoom into the diagram, remove (item 45) belt cover to expose the belt and pulleys. Take note of how the belt is routed.! you will need to follow the same route with the new belt. You may need to remove the Blade guard (item 40) if the belt doesn't fit over the head of the guard. There may also be a sprung idle tension pulley, which will take up the slack in the belt once replaced. Looks pretty straight forward.
Apr 19, 2016 | Troy-Bilt Troy-built Tb516ec 4-cycle Gas...
Starter rope is loose on lawn edger
remove the recoil housing and wrap the chord round the spool more to take up the slack
Feb 11, 2016 | Troy-Bilt Troy-built Tb516ec 4-cycle Gas...
Troy bilt troubleshooting
turn the whole assembly by hand to ensure motor itself is not binding or stuck .try pulling when motor is not in a compression stroke or remove spark plug if thier is no decomprssion mechanism. to enable easier pulling. next prepare to trouble shoot recoil assembly if motor is not siezed.
Jun 26, 2014 | Garden
Power washer wont pump
Call us when you can be at the washer so we can trouble shoot it with you over the phone.
http://www.ppe-pressure-washer-parts.com/troy-bilt-020416-1-pressure-washer-parts
Mar 20, 2014 | Troy-Bilt TROY-BUILT 91215 - TROY-BUILT...
Troy built Trimmer....tb575
Attached to this response are the front and back photos of the clutch assembly from a TB575SS trimmer motor.dave8459.jpgdave8459_0.jpg
May 20, 2010 | Troy Bilt Tb70ss Gas Trimmer
How to change the oil in my troy built pont where is the drain plug
Not sure what a pont is, or what motor you have, but on some of the Troy built small engines from Honda the geniuses designed the motor with no drain plug. You have to tilt or flip the engine over to drain oil out the filler
Feb 24, 2010 | Troy Garden
I have a Troy Built 6605 lawn tractor. The engine
check your belt might be off a pully or maby your spring is off
Nov 09, 2009 | Garden
My Troy Built weed eater wont keep string going.
troy built is pure trash ill never waste money on any of thier trash agin i have a weed eater 5 months old it wont even crank pure china trash
May 09, 2009 | Troy Bilt Tb70ss Gas Trimmer
Troy Bilt Tiller/Edger 26cc, Model No. 21at144r766 Logo
51 people viewed this question
Top Troy Garden Experts
Jim Parker
Jim Parker
Matt Olenzek
Matt Olenzek
DROPNDEAL
DROPNDEAL
Are you a Troy Garden Expert? Answer questions, earn points and help others
