Question about Husqvarna Garden
Trigger not working on Husquvana 125BT blower since I replaced the broken lever
Took handle apart on my blower to replace the lever, but now the trigger does not speed, just runs on last slow speed used.
  • 666 Answers
SOURCE: Atwater Strong Lit-r-blo leaf blower parts
Find model no. then go to following site
partstree.com/parts/?lc=kohler_engines&mn+Atwater+Strong+1971+-+60179D
Posted on Apr 13, 2009
  • 251 Answers
SOURCE: husqvarna 125bt backpack leaf blower. I put
if you've ran it for any length of time you will need a new cylinder and piston/rings and cylinder gasket ,
take the muffler off and look for scoring /scorching on the piston
Posted on Oct 21, 2009
rwvanlue
  • 486 Answers
SOURCE: leaf blower starts and runns ok for few mins then
Target your inspection towards the 'spark arrestor screen' in the outlet of the muffler.
Overfuel or 'rich' condition
Basics to check:
1) Spark plug - brown or dark brown - OK
a) is it carbon or fuel fouled
b) is there spark
2) Muffler remove for inspection
a) exhaust screen clean or plugged
b) inspect cylinder wall/piston as the flywheel is slowly rotated
3) Check Air filter for fuel saturation
4) Allow engine to run for 5 minutes to excess fuel from muffler
5) Fuel mixture ratio: Make sure the oil mix is per your manufactures recommendations
6) If after the above the engine is still smoking and blubbering:
Adjust carb mixture screws to a 'less rich' setting
*NOTE: only move mixture screws 1/8 of a turn at a time,
and try operation before any more adjustment
Posted on Nov 13, 2009
Testimonial: " this solution sure did work ,, had to clean the screen and muffer out too , was a build up of carbon there. was very helpful "
  • 2926 Answers
SOURCE: I have a VAC ATTACK
The cruise lever may be hung up. Click here for a breakdown of the components.
http://www.homelite.com/service_support/order_parts
Use ut-08544
Posted on Dec 12, 2010
gar6310
  • 24 Answers
SOURCE: i have a Husqvarna 125BT blower. It runs fine but
GAP is the opening between terminals at the end of the spark plug ( on the threaded side of the spark plug) but spark plugs should come with the right gap from factory, as for your problem with to restart your blower it is ok just need to let cool down for 15 min or more.
Posted on Feb 03, 2011
How to replace broken trigger on a huskie 162 sg chain saw
Most Husky saws have a small pin to drive out to remove trigger. Often safety lever on top needs to be removed also. Sometimes tank/handle assembly needs to be removed to replace trigger.
Dec 27, 2016 | Garden
Blower speed will not adjust
The lever may have broken because the cable is stuck due to corrosion or a bent/damaged cable covering. Can you take off the air cleaner and work the throttle manually at the engine? You might have debris on the carb holding the throttle closed.
Also try removing the lever and work the cable end with your hand or a pair of pliers. The amount of force should be quite light. If the cable effort is too high the cable is likely in need of replacement.
May 16, 2014 | Husqvarna Backpack Blower 25cc, 140 Mph,...
My Hoover Two Tank carpet cleaner still dispenses cleaning fluid...but only if I keep my thumb down on the 'extra solution' trigger. The main (and much easier to use) trigger doesn't work anymore. I'm...
The main trigger might have broken. This is common if the trigger is pulled too hard. You can take the handle apart on most units and replace the trigger. Usually the broken spot is where the trigger pivots.
Oct 29, 2013 | Vacuums
Framing nailer won't fire nails
Usually safety foot is not making full contact to trigger mech. First test trigger valve. Remove nails, remove the trigger to expose the trigger firing pin. Connect air and test fire by pushing in the firing pin with your finger (dry fire onto wood or old coiled rubber hose, use very quick pushing action against trigger pin). If the gun works, replace parts and adjust the safety foot so that the lever below the trigger is pushed all the way up and lever depresses the trigger pin all the way in. Good luck
May 26, 2012 | Air Tools & Compressors
Broken pull rope on 125BT Backpack Blower
Most small engine shops and big box stores like home depot sell generic replacement starter rope. If you want the exact part from Husqvarna, there are 2 engine variations for the 125BT. The rope for the AC57 enigne is part# 531009567, the rope for the AC55 engine is part#531009653.
Jan 04, 2011 | Husqvarna Forest & Garden 125bt Backpack...
Have a 125BT and doesnt start i got new plugs for it but that didnt work i took plug out and cranked it but i didnt see any spark so im...1 Solution
Hello . To see if there's spark you have to touch the spark plug on the cylinder (metal) and pull the starter rope to see if there's spark.
If not you have a bad ignition coil that have to be replaced . The part # for the ignition coil is 531 00 96-01. Hope this help .
Aug 12, 2009 | Husqvarna Forest & Garden 125bt Backpack...
No pressure when pulling trigger, trigger sticks in handle body
if air sound comes out when you press trigger your pressure regulator pin is stuck-oil gun and attach hose repeate until pin frees or remove pin and clean with brake kleaN oil and replace
May 31, 2009 | Ingersoll Rand 236 1/2" Air Impact Wrench
Garden Logo
Top Husqvarna Garden Experts
Jim Parker
Jim Parker
Phil Walker
Phil Walker
Are you a Husqvarna Garden Expert? Answer questions, earn points and help others
