Question about Panasonic KX-TG4500 Cordless Phone with 4 Handsets
How to hook up phone conections when using a cable modem
I have a cable modem that has to be hooked in with the base and a fax dsl line and i am not sure how to make the connections
2 Suggested Answers
  • 82 Answers
SOURCE: Do two handsets plug up to telephone line? If so how?
The main unit with answer machine has an inlet line where the phone line from the wall plugs into,which is located in the back of unit along with where the power cord gets attached. The second handset should have a stand/charger unit that should just plug into an outlet only to charge it. The two handsets run off the main answering machine/ unit. So as long as that is plugged in you should be able to use both handsets, because they both operate on the same frequency wave. Hope this helps you.
Posted on Apr 25, 2014
How do I hook up my fax machine with a cable modem connection only
If it is a DSL modem, use a DSL splitter / filter. The fax machine should be connected the tel port.
Sep 09, 2014 | Brother FAX-575 Personal Plain Paper Fax,...
Phone off hook message
A "Phone Off Hook" message is not an error. It simply indicates that a telephone receiver is off the hook (the handset is lifted) and the telephone line is open. This message would be expected in the following situations:
  • A modem on the phone line is accessing the Internet.
  • A phone connected to the HP fax (or the same phone line) is using the line, or the handset has been lifted.
  • A credit card machine is using the phone line.
  • Another electronic device is using the phone line.
  • The Start Fax button was pressed with no telephone number entered. Pressing Stop or Cancel should return the display to a ready state.
When the other device is no longer using the phone line, the display should revert to the normal message. Checking the phone line The most common reason for this message is when a dial-up modem is accessing the Internet on the same phone line. Just as two phone calls cannot come in at the same time, two devices cannot use the phone line at the same time. If a broadband modem (such as DSL or ISDN) is on the same phone line and the message appears all the time, please contact your Internet provider for assistance. Even if a dial tone is present when listening to the phone line, the HP product may detect the broadband data connection at the higher line frequencies. Broadband modems must have a line filter installed to work correctly. Contact the telephone company for assistance. Please follow the directions below to verify functionality.
  1. Verify that the phone cable going into the HP fax product from the wall jack is a two-conductor cable type, not four-conductor. A two-conductor cable, like the one that ships with the HP product, has two copper leads in the connector. The connectors are usually clear, making it possible to see how many copper leads are inside the cable. Replace a four-conductor cable with a two-conductor cable.
  2. Disconnect the phone cable from the back of the HP product and the message should clear. If the message does not clear, unplug the power cable from the back of the unit, wait 15 seconds, and then plug in the power cable. If the message persists, see the "Problem still exists" section below.
  3. Disconnect the phone cable from the HP product and connect it to a single line phone. Pick up the handset and listen for a dial tone. If no dial tone is present, replace the phone cable. If a dial tone is still not present, a problem exists with the phone system. Continue with the steps below if a dial tone is present.
  4. Plug the phone cable back into the HP product and hang up any phones with a lifted handset.
  5. Disconnect, one at a time, other phones and devices using the same phone line. Check the HP product display after disconnecting each phone or device. If the message clears after disconnecting a phone or device from the line, the problem is with that phone or device.
  6. If the message still exists after unplugging all other phones or devices, see the "Problem still exists" section below.
Problem still exists If the problem still exists after performing the steps above, the line interface unit (LIU), the part that the phone line plugs into, may be defective or the HP product may need to be serviced.
Jun 23, 2008 | HP Photosmart C6180 All-In-One InkJet...
What is dsl modem?
Yes it can. The DSL modem is hooked to the phone line or cable and a network cable comes out of it. You hook that cable to the WAN port on the rout
Aug 19, 2014 | NetGear N600 Wireless Dual Band Gigabit...
Hi, I need to connect my comSwitch 5500 to the Cable/internet/VOIP. Command Communications ComSwitch 5500 is a Telephone Line Sharing system- (automatic phone/Fax Switch) sold under the following...
I'm not one hundred percent sure on this, but it does look like you need a separate phone line since VOIP revolves around using your internet as a gateway for making phone calls. And since majority of VOIP uses ethernet connections, or wireless, there is no phone line to use.
Feb 28, 2011 | Computers & Internet
I have a hp officejet all-in-one and I can't get the fax function to work. I have comcast digital voice with a rca modem. The fax machine dials and the line goes dead. If I call the fax number on the...
Since you have a DSL ( Digital Subscribers Line ), the HP Fax printer works on Analogue Signals.
To make the GP Printer work on Digital line, First step you can do is to Reduce the Fax Speed from Fast/Medium to SLOW.
To Do so, Click on Setup button on printer front panel - Choose Fax Settings - Choose Fax Speed - Set it to Slow and try to fax
If this does not work, you will have to connect a DSL Filter ( this is a 2 way port - 1 port for Digital line and another for Analogue )
You will have to connect this Filter to DSL Phone line - in the IN port and from the Analugoue Port - Connect Phone cable to Printer Line 1 EXTN Port at back of Printer
Jul 02, 2010 | HP OfficeJet 6110 All-In-One InkJet...
My lexmark S405 willnot receive faxes. It is
Assuming "cable modem" as some kind of DSL modem using your phone line for internet. Both your modem and MFU should be connected to the wall by a filter-separator, usually supplied with your DSL modem. Check its presens and proper connection. Remove any other joints or splitters
Jun 14, 2010 | Lexmark X2470 All-In-One InkJet Printer
Just connected router to clear network modem and VoIP (wireless phone service), now when the phone ring, it disconnects me from the internet and the connection is lost until the phone call is complete.
Is your modem a DSL or cable modem?
If it is a DSL modem do you have a DSL filter on each phone line to the phones in your house?
The DSL modem does not need a DSL filter on the phone line.
Nov 09, 2009 | NetGear WGR614 Wireless Router
My DSL constantly loses sync after it has been on for awhile
If you have telephone devices (e.g phones, fax) sharing with your DSL line, be sure it has DSL filter on devices so it won't interfere with the internet connection. If every devices is properly filtered, disconnect all devices sharing with your DSL line and leave the modem connected to the phone socket with 3 meters phone cable and observe the connection. If the connection becomes stable, connect each devices so you will identify of these devices is using a faulty filter.
Jun 07, 2009 | Computers & Internet
Hooking up mx310 all in one
The phone line should plug directly into the Line plug on the DSL modem and the all-in-one should plug into the Phone plug next to it. If you need to split the line do it AFTER the line comes out of the Phone plug.
Feb 21, 2009 | Canon PIXMA MX310 All-In-One Printer
Yes i want to find out if a cable modem will work with your dsl phone internet service?
No.
A cable-modem connects with a coax-cable to the cable-company's network, but a DSL-modem connects with telephone-cable to the telephone-company's network.
Jan 27, 2009 | AT&T High Speed DSL Modem
Panasonic KX-TG4500 Cordless Phone with 4 Handsets Logo
26 people viewed this question
Top Panasonic Lands Phones Experts
guyvstewart
Are you a Panasonic Lands Phone Expert? Answer questions, earn points and help others
