Question about Nikon D300 Body Only Digital Camera
The csm switch on d300 does not work - Nikon D300 Body Only Digital Camera
I'm looking for a watts CSM model that can reduce the flow from 50psi inlet to 6 gallons per hour outlet on a 1.5" water line. I looked at the CSM-61 model but i was not able to figure out the...
Watts has contact-us page:
http://www.watts.com/pages/contactUs.asp
Add a comment for more free help.
Also take advantage of fixya phone service.
For a price, expert speaks with you over phone while you work on plumbing or any do-it-yourself project.
Fixya is always less expensive than a service call.
Jan 26, 2011 | Watts Series CSM-61 M1 T 1", Flow...
The doors lock automatically on my daughter's '99 Cougar. This has happened to me when I left the keys in the ignition and closed the driver's door. After AAA came and unlocked the doors, I removed the...
shorted wiring in doors or shorted door lock actuator in door. A grounding of a wire makes them lock normally. SO, any bare wire touching metal will ground it and lock the doors.
Principles of Operations
The Door Switch Lock Function When a door lock switch is moved into the lock position or a door lock cylinder is rotated to the lock position, the door lock switch grounds the lock circuit input to the central security module (CSM). The CSM then provides 12 volts to one side of the door lock actuators contained in the door latch unit and simultaneously grounds the other side of the door lock actuators. This completes the door lock actuator circuit, causing the door lock actuators to rotate a cam assembly, which then locks the doors. The 12 volts that the CSM provides to the door lock actuators are provided to both door lock actuators from a single pin on the CSM electrical connector.
The Door Switch Unlock Function When a door lock switch is moved into the unlock position, the door lock switch grounds the unlock circuit input to the CSM. The CSM then provides 12 volts to the opposite side (relative to locking the door) of the door lock actuator(s) contained in the door latch unit and simultaneously grounds the other side of the door lock actuator(s). This completes the door lock actuator circuit, causing the door lock actuator(s) to rotate a cam assembly in the opposite direction, which the unlocks the door(s). The 12 volts which the CSM provides to the door lock actuator(s) are provided to each door lock actuator from the individual pins on the CSM electrical connector.
CSM Self-Test The CSM has a self-test which can be entered into by using a diagnostic tool. This self-test will monitor the following CSM door lock inputs:
  • Unlock switch (DTC B1311)
  • Lock switch (DTC B1300)
  • Exterior lock switch (DTC B1309)
  • Exterior unlock switch (DTC B1341)
Before running the self-test, the following conditions must be met:
  • The ignition switch must be in position II
  • The driver and passenger doors must be unlocked
  • The driver and passenger doors must be opened
  • The hood and liftgate must be closed
  • The set/reset switch, and liftgate release switch are not actuated
It is important to note that all of the diagnostic trouble codes (DTCs), with the exception of B1551 and B1553 can be retrieved with the self-test. DTCs B1551, and B1553 are continuous and will only be retrieved if the liftgate release is operated prior to retrieving the continuous DTCs.
Inspection and Verification
  1. NOTE: Make sure that the battery is fully charged before starting electrical diagnosis.
    NOTE: Prior to carrying out the CSM Self-Test, make sure that both the driver and passenger doors are open.
    Verify the customer concern.
  1. Visually inspect for obvious signs of mechanical and electrical damage.
Visual Inspection Chart Mechanical Electrical
  • Binding latch mechanisms
  • Binding linkage
  • Misaligned door
  • Central junction box (CJB) fuse(s)
  • Wiring harness
  • Electrical connector(s)
  • Door lock switch(es)
  • Door lock actuator(s)
Module Controlled Functions
The central security module (CSM) covers the following functions:
  • Central door locking
  • Double door locking
  • Anti - theft alarm incorporating
    • forced entry
    • radio theft
  • Radio frequency remote control of
    • central door locking
    • panic alarm
    • driver door unlock
    • liftgate unlock
For additional information, refer to Section 419-01A Anti - Theft - Active, Section 501-14A Handles, Locks, Latches and Mechanisms, and Section 501-14B Keyless Entry/Computer Operated Locks.
The CSM is in the passenger side kick panel I think.
Good luck
Jan 25, 2011 | 1999 Mercury Cougar
ACPI on ASUS A8N-VM CSM Motherboard not working.
Can you please indicate how you turn the motherboard on if the on/ off switch is not operating?
I take it that because of the keyboard problem at boot up you are unable to get into BIOS> If this is the case then it might be very difficult to diagnose what is going on. YOu need to be in BIOS setup to check the state of the hardware.
What setup have you used to program automatic sheduling of TV program recording. Is the computer active all the time?
Not sure why you think ACPI or cmos battery might be causing the problem.
Please post a few answers that might help me understand the problem a bit better.
Jan 17, 2010 | ASUS A8N-VM CSM (00610839133826)...
Hello!!! I am having trouble. This has happened one time before and I fixd it but I cant remember how in the heck I did it. Here is the prob...The doors will not lock or unlock by the buttons or the...
check the fuses to the CSM ( Central Security Module ) .
CJB ( aka Central Junction Box, cab fuse panel ) Fuse # 15 & 29
15 is the BPP ( Brake Pedal Position ) Switch, so that should be fine, unless you cannot get the truck out of park while running and the brake lamps don't work.
29 is the fuse to the CSM ( hot in start or run key positions ).
BJB ( aka Battery Junction Box, Engine Compartment fuse panel ) Fuse # 115 or 8. 115 is for the Supercrew body style and 8 is for the standard cab & SuperCab configuration.
This is for a build date after 2-OCT-2000 ( 2001 MY ).
Build date before 2-OCT-2000, the CSM is a RAP ( Remote Anti-theft Personality ), looks the same, same functions, but is not pin for pin compatible.
Fuses for this are CJB Fuse #8 and 15 and BJB Fuse #4.
With the CSM / RAP installed, the power door locks are controlled by the CSM/RAP, without the RKE ( Remote Keyless Entry ) installed, they are normal power door locks ( switch to the door lock direct ).
Worth a start checking the CSM / RAP fuse
Nov 18, 2009 | 2001 Ford F150 Styleside SuperCrew
Nikon D300 - Auto focus point won't move. Autofocus doesn't work.
The lock that's around the 4-way button that moves the AF point will stop it from moving. The AF switch (says C,S,M) on the body below the lens release button gets knocked to manual and turns off the AF
Oct 11, 2009 | Nikon D300 Digital Camera
Auto focus on my d300 does not work
There is a [MF - AF] switch on the camera body where the lens attaches to it.
Move the switch to the AF selection.
AF = AutoFocus
MF=ManualFocus
Sep 24, 2009 | Nikon D300 Digital Camera
D300 Floor Mixer faulty bowl guard switch
If you remove the bowl guard you will see a magnet that attaches on iy in a white housing.The scews come loose and prevent it from closing the switch.Also the switch which comes out of the top pedestal can be adjusted.Let me know.
Mar 29, 2009 | Hobart D300 Stand Mixer
I have an alpineIVA-D300 and I think the amplifier is bad. The screen works, radio goes to channels but I get no sounds.I have tested the speakers and they work
This may help. Alpine typically controls their internal amps one of two ways:
1) menu setting for external amp or defeat internal amp
or
2) top of the unit (with it removed) there maybe a series of switches by channel (front, back and sub) on the unit. My current alpine has the switches on top.
Jan 01, 2009 | Alpine IVA-D300 Car DVD Player
Nikon D300 Problem
try shooting in manual or aperture priority mode, make sure that the csm selector knob is set to S
Sep 11, 2008 | Nikon D300 Digital Camera
Alpine Avi-D300 Owner/Service Manual
Here's the link for the owners manual: http://vault.alpine-usa.com/products/documents/OM%20IVA-D300.PDF The wiring diagram is on page 70-71.
Aug 27, 2007 | Alpine IVA-D300 Car DVD Player
Nikon D300 Body Only Digital Camera Logo
55 people viewed this question
Top Nikon Cameras Experts
Jeff Marcus
Are you a Nikon Camera Expert? Answer questions, earn points and help others
