Question about Maxtor Personal Storage 3000LS (G01J060) 60 GB Hard Drive
Maxtor 300ls 40gb computer cant recognize
I have a maxtor 3000ls 40gb and i want to access it to recover the data inside. i plug in the USB to computer and the little arrow shows in the lower right hand corner and even says device found but i cannot see it in 'my computer' to access the files.. What is going on?
the lights in the formt dont work anymore but when i place my ear near device it does make noise as if working. Please Help,.
4 Suggested Answers
ctf1800
  • 4402 Answers
SOURCE: Maxtor 3000LS filled
Norton utility's or google for a file restore after format
Posted on Jan 09, 2008
  • 29 Answers
SOURCE: cannot install on my computer
Just go to their website and look under "support". Find you model and you can download the drivers for it. Maxtor has become Seagate but they still support Maxtor. Here is the website link you need. http://www.seagate.com/www/en-us/support/
Posted on Dec 07, 2009
  • 120 Answers
SOURCE: how to recover all the files from failed 40gb ide
It is very uncommon for a had drive to fail with out power surges or some other physical damage so I would suggest making sure all of the cables are connected properly and that the connectors on the back of the hard drive that tell it whether it is slave, cable select, or master are setup correctly, and if the hard drive has failed there really is no way to get information off of it, but my hopes are high that it has not failed. Good luck,
Posted on Jan 25, 2011
Cannot access my maxtor external hard drive. Whenever I plug into my laptop the icon doesnt show, but the F drive show up and when I tried to open, the computer says to format. What should I do?
click start control panel administrative tools computer management device manager scroll down universal serial bus controllers you could see a yellow question / exclamation mark? ! or a red X
you will need to update/reinstall drivers
right click to reinstall drivers
if you can see your usb but its not working
ports(com&lpt)right click update driver
sometimes the wires inside the cable will be damaged due to bending or stretching or placing heavy equipment upon the cable
just replace the cable of the hard disk, when you plugged the external disk drive you got that windows could recognize the USB device change the cable everything should work fine again
if you can see your usb drive but its not working
ports (com&lpt) right click update driver if this fails to fix the problem
check the USB leads that attach to the motherboard usually red white green black make sure they are securely seated and have no dust build up on them dust will cause static and a lot of unforeseen problems to a computer and its parts
if it still cant be detected or If the hard drive that has failed is the same one that you are trying to recover from might the reason that you are getting this error.
This could be an issue where the part of the hard drive you are trying to access is corrupt and not accessible which would explain the reason that it would let you access the other partition.
Now I have seen cases where Malware can break the link of a Hard Drive.
So let's try a couple of steps.
Let's go back in to "Disk Management"
Lets right click on the partition that you are not able to access and select "Change Drive Letter and Paths"
Now try selecting a new Drive Letter.
This will restore the path if it has been broken.
There are also Data Recovery programs that might be very helpful to recover your important information.
Downloads to Recover Your Files and Save Your Bacon and 10 Best Free Hard Drive Utilities.
Some addition links found on Google
http://www.datarecoveryreview.net/
http://www.easeus.com/resource/hard-disk-data-recovery.htm
or if its a usb external drive you might need a usb 3 card installed on your computer your computer might not have enough usb output
http://blog.premiumusb.com/2010/09/usb-2-0-vs-usb-3-0/
these can be purchased on Ebay cheap and easy to install
http://www.ebay.com.au/itm/PCI-e-PCI-Express-USB3-0-Card-new-NEC-720200AF1-chipset-/330608109325?pt=LH_DefaultDomain_0&hash=item4cf9c7670d
for roughly $9 or $10free postage
hope this helps
Oct 05, 2012 | Maxtor Computers & Internet
Hard Drive not accessible, now not recognised by computer
Do you have another computer you can plug it into? The problem could be with your USB. If it is, see what updates you installed and then removed that may have affected that. You can also go to the manufacturers web site and download the original firmware or updated firmware files.
Dec 12, 2009 | Maxtor Hard Drive
My maxtor external hard drive has stopped working. When I plug the power in the light only comes on temporarily therefore i can't use it. Have I lost all my saved data?
My maxtor external hard drive has stopped working.There is a chance that you can recover data using a USB to IDE or SATA Adapter Cable to recover your data they cost about $30 if you cant get hard drive to power with adapter chances are it has crashed there are places that can get data off hard drive but they are very pricey hope this helps.
Nov 28, 2009 | Maxtor Computers & Internet
Maxtor 4 mini usb 250 gb not recognized
Data Recovery Lab can recover data from faulty hard drives. They specialise in hard drive recovery, USB RAID data Recovery and laptop data recovery. For more information you can call 0207 516 1077 or visit www.datarecoverylab.co.uk.
  • No-data No Fee Data Recovery Service Guarantee
  • FREE data recovery analysis
  • Fast turnaround
Data Recovery Lab also provide FREE data recovery advice and consultation for all business and private customers in the UK.
Feb 18, 2009 | Maxtor OneTouch III Mini Edition 120GB...
Computers do not recognize Maxtor
This isn't a solution, but will give you more information about whether you can recover the data. If your computer recognizes the drive when you insert it, but doesn't assign it a letter, you can probably recover much of the data.
For XP: Click on "Start"-"Settings"-"Control Panel", and select "Administrative Tools". If you don't have that menu, there are other ways to get into the control panel, depending on how you've configured your OS.
Click on "Computer Management" (on the right window), then "Disk Management" (on the right again). This shows a picture of each of the hard drives on your system. The "Volume" shows the letter assigned. If you unplug the hard drive, and then plug it back it, you can easily tell which volume is being added or removed.
If you can right click on the volume, it may be a simple matter of running "checkdisk" to fix any errors (click properties, and see if that is an option in the "Tools" tab). If all the options are disabled, the drive has been corrupted. However, you may still be able to recover the data with a data recovery program (I have R-Studio, but there are a lot of others out there). If the drive doesn't show up at all, you'll probably need a professional.
Note: If you have a lot of drives, you may just need to free up a drive letter to be able to see the drive. You can right click, and if "Change drive letter/path" is enabled, try that.
Dec 04, 2008 | Maxtor OneTouch III Mini Edition 120GB...
Jan 08, 2008 | Maxtor Personal Storage 3000LS (G01J040)...
Maxtor external HD
my maxtor is pugged in to my pc,but i can acess it. how do i locate it ?
Jan 03, 2008 | Maxtor Personal Storage 3000LS (G01J060)...
Opening external drive case
Actual solution. The darker side panels pop off and they alone hold things together. Simply pry each side away at rear. That would be end with power and USB connections are.
Dec 10, 2007 | Maxtor Personal Storage 3000LS (G01J060)...
Maxtor Personal Storage 3000LS (G01J060) 60 GB Hard Drive Logo
103 people viewed this question
Top Maxtor Computers & Internet Experts
Arora Singh
Arora Singh
Computer Links
Phillip Whisenant
Phillip Whisenant
Are you a Maxtor Computer and Internet Expert? Answer questions, earn points and help others
