Question about Boating
How to check variable speed switch on motorguide 109
  • 218 Answers
SOURCE: need new variable speed switch for dremel 395 type 1
Someone else recently asked the same question and got the following solution;
http://www.fixya.com/support/t1515699-variable_speed_switch_dremel_395_get
Posted on Jan 29, 2009
  • 3600 Answers
SOURCE: I HAVE A MOTORGUIDE MOTOR WITH THE FOLLOWING LABEL
I need the information off the tag motor frame volts amps and shaft type and I can tell you how to make it work. you didn't leave your e-mail address, also please rate. Thank you.
Posted on Aug 08, 2009
  • 5 Answers
SOURCE: can you change a motorguide 65lb thrust foot
Go to TROLLINGMOTORPARTS.COM AND YOU CAN A WIRING DIAGRAM.
Posted on Apr 30, 2010
SOURCE: My variable speed motorguide only
Would you mind letting me know how you made out? I have the same problem.
Thanks, Mike
carmic@wightman.ca
Posted on Aug 18, 2010
SOURCE: Replaced Motorguide Trolling motor switch ... same problem
Trolling motor runs on it's own when plugged in,speed adjuster won't control speed and 3 position switch doesn't perform either..please help. motorguide 74lb thrust.
Posted on Sep 16, 2011
Motorguide Pro 70 only 2 speeds out of 5
CHECK ROTARY SPEED SELECTOR SWITCH. $20 PART IF BAD.
Mar 29, 2012 | MotorGuide STANDARD MOTOR REPLACEMENT...
Motor will not run when handleis turned on
may be the switch inside the cover,variable speed switch
Sep 20, 2010 | MotorGuide STANDARD MOTOR REPLACEMENT...
Lost #1 and #2 speeds
Contacts inside switch may have become corroded.
May 12, 2010 | MotorGuide STANDARD MOTOR REPLACEMENT...
Can you change a motorguide 65lb thrust foot control model with fix speed settings to a variable speed
well a "Speed Controller" can usually be used on ANY DC/AC motor, depending on type, some motors just will not work, with a speed controller... Think of it a bit like a "Light Dimmer", with the "Bulb" being the "Motor"
Have a look below for info. www.stefanv.com/electronics/escprimer.html
Mar 05, 2010 | MotorGuide STANDARD MOTOR REPLACEMENT...
The variable speed will not go lower than approximately 30%
If you go any slower you might as well do it my hand. Going that slow is not allowed at any job site.
Aug 31, 2009 | MotorGuide Electrical Supplies
I HAVE A MOTORGUIDE MOTOR WITH THE FOLLOWING LABEL ON IT... "EP2.3HP" WITH SERIAL #SN 42663". LABEL ON TOP OF MOTOR IS "36 VOLT DIGITAL. VARIABLE SPEED". CANT FIND ANY INFO ON THIS MOTOR ANYWHERE? IT HAS...
Aug 08, 2009 | MotorGuide STANDARD MOTOR REPLACEMENT...
I have a Great White GWB50 Runs only at one speed Can only turn it off with toggle switch. Variable speed doesn't work. Do I need a circuit board. This happened after I replaced the mount and reattached...
I have one too. Although it could be the mother board - if it runs its the potentiometer. You can get one from Iboats or Mie Reel Repair the number is AP16802. If its the mother board they are switching to digital. I havent had to go there yet. Tight lines to ya. From South Texas Riviera.
May 19, 2009 | MotorGuide STANDARD MOTOR REPLACEMENT...
Jan 14, 2009 | MotorGuide STANDARD MOTOR REPLACEMENT...
Boating Logo
21 people viewed this question
Top Boating Experts
Steve
Steve
ray gallant
Andrew Taylor
Andrew Taylor
Are you a Boating Expert? Answer questions, earn points and help others
