093-973 xerox 6015 - Office Equipment & Supplies
CRUM ID 093-926
That error signifies an unsupported black toner cartridge. Verify oem Xerox cartridge, try reseat cartridge. If not cartridge it will be the MCU Board, part number 960K60951.
http://www.iteminconline.com/960k60951_062k23373-960k60951-xerox-workcentre-wc6015-engine-controller-mcu.htm
Jan 31, 2016 | Xerox 6015/NI New Workcenter 6015/NI Laser...
My xerox 6015 will print documents that I have previously printed even tho I am not requesting it to be printed. Nothing is in the print queue to cancel. what is wrong with it?
I assuming you mean you get 2 prints when you only asked for one. Looks like the driver default settings are set to 2 copies.
If you can use the copy facility and print one copy that sort of eliminates the printer. The problem must be further up stream towards the computer sending the print.
You also. If he like to remove the print driver and reinstall it, the default must always be set to 1 copy.
Feb 21, 2015 | Xerox Workcentre 6015/Ni Color Laser...
How do you turn on wifi on a Xerox 6016 NI?
should be a menu options look for wifi and follow instructions, a summing it is wifi compliant
Jun 29, 2014 | Xerox Workcentre 6015/NI
Xerox workcentre 6015 ni error code 092-651
Printer CM205 b error code 092-651
Options My printer FUJI XEROX CM205b is showing an error code of 092-651 with a sub code of 2080000. I have no idea what this means or how to go about fixing it. this has been a great printer and would like to fix it if possible.
Thank you for the help.
Apr 12, 2014 | Xerox WORKCENTRE 6015/Ni Color
Xerox workcentre 6015 092-651 error
That error indicates a bad ADC sensor. Try cleaning the adc sensor which is on the rear of the transfer belt. If that doesn't work, replace transfer belt as sensor is not sold separately.
Sep 18, 2013 | Xerox WORKCENTRE 6015/Ni Color
124 people viewed this question
k24674
jasbo
jasbo
