Question about Maytag Dryers
It made a lot of noise, then the drum would not rotate. The belt had come off. So I put it back on and it cam off again. Maytag has 3 possible drum belt configurations I also need to know the configuration for this model MDET236AYW; Could there also be an issue with the idler pulley assy (tensioner pulley assy.)?
SOURCE: drum belt tension
I found a dryer manual on the web that showed how the drum belt wrapped around the pulleys.
Problem solved.
Posted on May 12, 2009
SOURCE: dryer belt routing on Maytag dryer model MDET236AYW
With the drum removed, loop the belt around the drive motor an run both strands of the belt under the tension pulley. You have to be carefull on getting the drum back in place while working the belt back on a LITTLE AT A TIME. Once installed verify the belt is not caught on anything and you should be good to go.
Mark
Posted on Aug 11, 2009
SOURCE: maytag dryer model MDET236AYW drum rubs against
Here
is a tip that I wrote about dryers and noises...
It will help
you determine what is happening there...
Dryer
Repair Squeaks,
Grinding, Clicking and Knocking Noise
heatman101
Asker's
Testimonial "That answer was very informative - thank you for
taking the time to educate me. " - teresa241964
Posted on Feb 21, 2011
Apr 06, 2015 | Maytag Dryers
Mar 06, 2017 | Maytag Dryers
Jun 19, 2013 | Maytag Dryers
Fig. Fig. 16: Rotate the belt tensioner and...
Fig. Fig. 17: ... remove the belt from around one of the pulleys to remove the belt
WARNING
Use caution when removing or installing the belt and make sure the tool does not slip from the drive belt tensioner or personal injury or damage to the belt tensioner and the belt may occur.
Aug 05, 2012 | 1997 Mercury Sable
Sep 21, 2011 | 2003 Chevrolet Impala
Mar 09, 2011 | Frigidaire FEX831CS Top Load Stacked...
Mar 04, 2011 | Maytag Dryers
Jan 14, 2011 | Maytag MDE8000 Dryer
May 22, 2010 | Washing Machines
Feb 16, 2010 | Maytag Neptune MDG5500AW Gas Dryer
22 people viewed this question
