Question about Whirlpool GJC3034 Electric Cooktop
What are the dimensions for the gjc3034 - Whirlpool GJC3034 Electric Cooktop
I am experiencing some problem with the controls on the cooktop. When turning the dial to the desired temp, sometimes the burner comes on, sometimes it does not. Some of the burners only engage when we...
I haven't heard of this problem before. If you do press down and the hotplate starts to work we know that the hotplates are okay. The only thing this could be is an internal problem inside the hotplate controller, possibly with the contacts. The controllers will need replacing.
Mar 04, 2011 | Whirlpool GJC3034 Electric Cooktop
My glass cooktop has cracked across the top left corner. It has created a triangle, about 1-1/4 inch on each side. Is this a flaw in the glass?
most of the time for this to happen something would have had to been dropped or excessive weight on the unit ... it is possible over time the unit had a unseen hairline crack and the heat has caused it to become worse... the glass for these units are ridiculous in cost but can be repaired...
several online sites sell parts.... a few reputable companies are
www.sears.com
www.apdepot.com
www.repairclinic.com
Jan 21, 2011 | Whirlpool GJC3034 Electric Cooktop
I have a Whirlpool Gold electric cooktop. It is
It sounds like the selector switch is shorted, the only way to fix that is to replace the switch
always unplug electricity before working on any electrical appliance
Sep 25, 2017 | Whirlpool GJC3034 Electric Cooktop
I HAVE A WHIRLPOOL ELECTRIC COOKTOP WITH A LARGE CRACK CAN I REPLACE JUST THE SURFACE IF SO WHERE CAN I GET ONE?
The glass can be replaced. Go to any appliance parts website and look up the model number for your cooktop. They should have a parts directory and then search for your cooktop glass. I warn you though - the glass is almost as expensive as a new unit!!
Mar 13, 2009 | Whirlpool GJC3034 Electric Cooktop
Fuses
These heating elements use limiters to control the temp range and here is a link that shows where they are http://www.pcappliancerepair.com/model-display.php Hope this helps...
Sep 11, 2008 | Whirlpool GJC3034 Electric Cooktop
Hot Surface Light stays on
Our success has been to heat the elements to hot for about 5 minutes. Then let cool to reset temp sensor.
Can cause the problem by turning a burner on for a short period of time
Dec 16, 2007 | Whirlpool GJC3034 Electric Cooktop
Whirlpool GJC3034 Electric Cooktop Logo
105 people viewed this question
Top Whirlpool Cooktops Experts
vince
Lakeland Appliance...
Are you a Whirlpool Cooktop Expert? Answer questions, earn points and help others
