I also discovered that if you press feature then #85 that will both turn on or turn off DND. That is what will work for a phone with no DND button.I also discovered that if you press feature then #85 that will both turn on or turn off DND. That is what will work for a phone with no DND button.
You can't post conmments that contain an email address.
Question is kind of Vague, so I'm assuming you are trying to turn off the Do Not Disturb (DND). In the standby mode, press the do not disturb button on the base. The DND indicator will light and DO NOT DISTURB shows in handset display. To cancel, press the do not disturb button again. Hope that helps.
Examine the base of the Uniden cordless phone. Locate the "DND" button on the main base of the phone.The DND button means do not disturb and it puts the phone in silent mode when pressed
Reactivate the ringer by pressing the "DND" button again. All the handsets will ring when someone calls you.
If you have not found an answer to this as yet just pick up intercom and enter 7100 at the phone. This will clear any DND. Now enter intercom 7105165. This will give a long tone and the DND/FWD lamp will flash showing Call forwarding active for VM.
Typically DND is turned on and off by pressing the FWD/DND button. There are three status conditions for this button indicated by the button light.
button light off: both features off(Forwarding and Do Not Disturb)
button light blinking red: Forwarding on
button light solid red: Do Not Disturb on
The functionality of this button can be customized by the phone system installer to work differently than outlined above. Station features can also be accessed through station programming using the LCD screen by pressing the button then either scrolling through the features using the LCD screen navigation keys or entering the specific program number as in 50 for FWD/DND programming.
Do Not Disturb (DND) DND allows you to mute the ringer on all handsets. In the standby mode (phone handset off and in cradle), press the do not disturb button on the base. The DND indicator will light and DO NOT DISTURB shows in handset display. To cancel, press the do not disturb button again.
Thanks for using FixYa - a Very Helpful rating is appreciated for answering your FREE question.
The do not disturb feature (DND) allows you to mute the ringer, the base, and any registered handsets at the same time. The phone must be in standby mode. Press and hold do not disturb on the base. You will hear a confirmation tone, and the DND LED illuminates. To cancel the DND feature, press do not disturb again. You can also mute the ringer tone while the phone is ringing by pressing do not disturb on the base. Activating the DND while the answering system is off will turn the answering system on automatically. The answering system setting will reset to the original setting when you cancel the DND. If you press answer on/off when the DND and the answering system is on, both of the DND and the answering system will turn off. To mute the ringer tone temporarily for each handset or the base, when the phone is ringing, press the MUTE soft key on the handset or the base. The ringer tone will return to the previous setting starting with the next incoming call.
DND Allows you to mute the ringer on all handsets.
In the standby mode press the do not disturb button on the base the DND indicator will light and DO NOT DISTURB shows in the handset display.
To cancel press the do not disturb button again.
Panasonic features are in the system, not the phone. If you have a TA series, from the phone, pick up the handset and press the FWD/DND button and dial 4#. (you may also dial 71 in place of pressing the button).
Cancel is 0# in place of 4#, but you also have CF to voice mail issues, where 1+VM EXT is all calls and 2 is BUSY/NA.
If you have a TD or TDA or TAW system, you get lucky, because the FWD/DND button works in 3 modes. For DND it's 7101 or *7101. The button will light with a solid red light and when you press it, it either flashes or goes off. The system gives you both FWD and DND settings.
Not sure how you set this feature but here is the solution:
To set DND you would have pressed your feature button, 60,and then feature button again (if you were forwarding to another extension you would have had to enter an extention after 60 and then the feature button. This sets your DND or call forward.
To eliminate press feature, 69 and then feature again this should cancel the call forawrd or do not disturb.
press the [world] setting button, then choose settings choose call preferences. change DO Not Disturb to NO press save (middle button) press back press exit
