Question about Dual Electronics XHDR6435
How to make a wire harness clip for a dual xhdr6435
Power button is stuck on
  • Try Shutting it down with the remote.
  • CAREFULLY Spray a little bit of WD40 around the button and press it several times to see if will unstuck.
  • Take it back to the store where you purchase the set from for exchange, or to a repair shop.
Here is a link to your receiver operating Manual.
Best of Luck,
JP
Dual XHDR6435 Installation Manual
Jul 14, 2015 | Dual Xhdr6435 Cd Receiver With Bluetooth &...
I installed a DUAL XHDR6435 to my 1991 Ford Explorer XL the radio works fine got sound and cd functions but the display is all out of whack everything that can light up on the display is on the display...
I Would try the reset button on the back off the cd player if there is one...If not shut it off and back on...U may have to tinker with the controls for a bit to get it conform to your liking....
Jan 26, 2014 | Dual Electronics XHDR6435
Why does the red light stay on when i cut the car off
Constant power and switched power wires are reversed.
Thanks!
Feb 24, 2012 | Dual Electronics XHDR6435
How to enable bluetooth on a XHDR6435 cd receiver by dual
You must purchase the BTM60 module (as it is Bluetooth ready, not Bluetooth capable) like this one at Amazon http://www.amazon.com/Dual-Bluetooth-Hands-Free-Module-Built-In/dp/B000PDR5O6
Sep 23, 2011 | Dual Electronics XHDR6435
My in dash head doesn't keep the presets for the auxiliary or the stations on the radio. Every time I shut the car off it resets itself. How do I fix this?
Make sure the yellow wire is going to a constant power source. Try to find a wire that is still hot when the key is off.
Jul 18, 2011 | Dual Electronics XHDR6435
XHDR6435 radio was working fine yesterday, now it will not turn on. the red led behind the faceplate flashed when i turn on the car, and cds will load and eject but the radio will not power up. i habe...
I just Spoke to tech support. This is what they said:
1. Key in the on position and the red power button lit, remove the face plate.
2. On the left bottom side press and hold the reset button, with a pen, for 10 seconds and let go. The red led on the right should flash.
3. Reinstall the face plate.
4. Push power. The unit should come back on.
Mine worked, and i was about to tear it out and return it. So try this first or even call tech support for Dual 1-866-382-5476.
Jun 14, 2011 | Dual Electronics XHDR6435
Where do i hook the blue wire up to on a dual xhdr6435 into the dash
Hi, the blue wire is used to turn on a separate amplifier or to raise the antenna. If you don't have a telescoping antenna or amplifier, just tape off the blue wire and leave it hanging behind the head unit. Please let me know if you have more questions, and thanks for using FixYa.
May 06, 2011 | Dual XDM6825 CD/MP3/WMA Player
Dual Electronics XHDR6435 Logo
Top Dual Electronics Car Audio & Video Experts
xxxxxx xxx
Matthew Spark
Matthew Spark
Are you a Dual Electronics Car Audio and Video Expert? Answer questions, earn points and help others
