Question about Samsung Galaxy Cell Phones
I dropped my galgaxy s3, it started randomly shutting down, then after awhile died and now it wont even charge.
    Scholar:
  • 77 Answers
The charge port might be damaged, I would recommend trying to charge the battery with another charger / phone, or try another battery.
The shutting down part, I will assume something either got loose or the power button might be cause the issue. Which means you might need to replace that, depending on the phone, it might need soldering.
The last idea I can come up with is water damage, you would have to open the phone to make sure, but I wouldn't recommend it unless you know what you're doing.
All in all I would say bring it to a repair store near you.
Posted on May 24, 2014
2 Suggested Answers
  • 26 Answers
SOURCE: my google g1 randomly shut off
its either your battery that needs to be replaced or your charger it's not working
Posted on Mar 12, 2010
Car wont start says system is shutting down to save battery
Charging system problem , probably . What make , model ,year vehicle ? engine size 2 Most all vehicles have computer controlled charging systems . Your best bet , take it to a qualified repair shop.
May 27, 2018 | Cars & Trucks
Starts and shuts off when I stop at stop sign or light.
dodge dakota idling and dying - CarGurus
www.cargurus.com > Questions > Dodge > Dakota
CarGurusApr 12, 2011 - dodge dakota idling and dying - My dakota will start then idle down and die. ... I have a 1992 dodge dakota that dies on me at stop signs and when I take my foot off the gas pedal. ... Had the same problem with my 98 Dakota.
Dodge Ram 1500 Questions - 1998 1500 5.2 Shuts Off ...
www.cargurus.com > Questions > Dodge > Ram 1500
CarGurusAug 29, 2011 - 1998 1500 5.2 Shuts Off Randomly - does anyone have an answer to the mysterious shutting ... 1998 1500 5.2 that shuts off randomly and if i wait a few seconds to minutes it will start again. ... does it do it when coming to a stop or when taking off from a stop or shifting from drive to .... Used Dodge Dakota".
Truck Shuts Off - 1998 Dodge Dakota - RepairPal
repairpal.com > Questions > Dodge > Dakota > 1998 Dodge Dakota
I have a 91 dodge dakota truck with a 318 motor, 249,000 miles, it will start up thenshut right off when I take my foot off the gas pedal, I had a tune up a month ...
2000 Dodge Dakota idle then dying problem FIXED - YouTube
? 4:05
https://www.youtube.com/watch?v=XRVQEdnei34
Mar 26, 2014 - Uploaded by AoDMADPenny
It would rev up then back down to about 200 rpm then just shut off. ... My Dakota dies during idling right after i start it up and then it wont start back up again. .... 1998 Dodge Durango No Start or No Bus or Randomly Stalls ...
Jan 06, 2016 | 1998 Dodge Dakota
91 primera sr18 Di,have fixed vacume leak's in inletmainfold,replaced the airflow meter,have got it running excellently but after it has been running for awhile,it randomly dies and wont start again f
I had a similar problem. Nissan sr18di engine. car would run fine and randomly engine would cut off and only start after 20 minutes. Changed distributer
fine since
Nov 09, 2011 | Cars & Trucks
Ok i have a 2001 chevy S10 pickup and for awhile now the battery volts drop while im driving if i turn my blinker on the needle gos up and down with every click iv checked the battery altinator and starter...
Make sure the alternater belt is the correct tension....If its been recently replaced, it may have been a size too big. Have you also had the regulator checked for output?
Regards Johngee10
Nov 06, 2010 | 1999 Mercury Sable
When driving the radio died then the car died wouldnt start again wont even turn over
It sounds like your alternator went bad. The alternator is responsible for keeping your battery charged and at full power. If it goes bad, your battery eventually drains and things start to shut down.
Get your alternator and battery tested, I'm sure you'll find the alternator has died.
Oct 19, 2010 | 1994 Nissan Altima
I have a 1994 flstf i was on the freeway could'nt get over 65 mph then it died sometimes it starts right up ride about a mile it dies then it cranks over but wont start untill it sits awhile
sounds like blocked fuel filter , dirt or water fuel sytem or in carb or even coils breaking down , it is known that coils test o.k which gives them an intitial charge but on side of duel coils fail when hot .and are hard to diagnose even with proper equiptment , i have test coils and this is the case.
sounds like fuel problem but keep in mind coil if persists .
hope this helps
Oct 09, 2010 | Harley Davidson FLSTF Fat boy Motorcycles
Nissan Sentra random stalls and wont start hot
Check out the catalytic converter, might be plugged up. I have seen some cars that will run fine, and like someone threw a switch the car acted like yours, no power, would not rev and died. Later when cold they would be OK for a while then just get worse and worse.
Jul 03, 2009 | 2001 Nissan Sentra
LG ENV2 shutting off
I just got mine a few weeks ago and it does the same exact thing (I didn't drop it, there is no water damage, I didn't understand the cause of it). I took it back to the Verizon store and I was told that the random shutting off like that is caused by having the phone outside being exposed to heat. He reset my phone back to factory settings and that did the trick for awhile (its hard for me to go to the pool and not have my phone exposed to the heat). There is no charge for them to reset the phone. Mine has started the random shutting off again back up
Jun 03, 2009 | LG enV VX9900 Cellular Phone
Car wont start-not a gig
it sounds as if you might have to replace the battery, if your battery is shot you can still get a boost and the car will run because the alternator produces electricity which should take car of the cars functions and top up the charge on the battery. if the battery is no longer taking the charge or not holding it as soon as you shut it off it will not have enough power to start the starter. A lot of automotive place will do a check on your battery if you take it to them.
please note that i'm not a mechanic and this is just based on my own experiance
Feb 12, 2009 | 1995 Pontiac Grand Prix
Pc wont stay on
check your power supply,earhing problem .proper voltafe .
clean your ram,processor and its position.
check that your bord dont touch the cabinet.
other wise i think your bords register or diode transistor are corrupt.
repair your motherbord chipset if above try are not succes
Apr 01, 2008 | Soltek SL-86SPE2 Motherboard
Cell Phones Logo
Top Samsung Cell Phones Experts
Ronny Bennett Sr.
Ronny Bennett Sr.
Fotis Papastamatiou
Are you a Samsung Cell Phone Expert? Answer questions, earn points and help others
