Question about Guillemot Hercules DJ Console RMX Mixer
Reset firmware Firmware reset
I own an alesis dm6 mod. how upgrated firmware?
Click this to unload the latest firmware from the manufacturer!
DM6 Module - Firmware Update [v06]
DM6 Firmware Update Installer for Windows. Updated 04.26.2012
Fix'dYa
Aug 04, 2014 | Alesis DM6 Electronic Drum Set
Factory reset
I don't think it's possible to reset a Faderport in the traditional sense since the firmware is not an EPROM (Electrostatic-Programmable-Read-Only-Memory).
I think it's more likely that the driver on your PC or Mac has become corrupted and needs to be uninstalled and reinstalled.
To do this, we'll need to know more about your platform, especially the DAW. Are you using Studio One v2 or v3?
Aug 04, 2014 | PreSonus Firestudio Project + Faderport +...
Akai firmware
Hippo.com has a ton of free downloads
Jul 29, 2014 | Akai Professional Akai Pro MPK61 61-key...
Behringer deq2496 displays firmware data not found / what do I do
Go to http://www.behringer.com and update new drivers and firmware. If you lack the Firmware, the system will not open or recognize the device at all. Check with their technical service and tell them to walk you through the process of installing the new firmware.
Dec 19, 2013 | Behringer Ultracurve Pro DEQ2496 Digital...
Driverack pa plus sends this message WAITING FOR FLASH DOWNLOAD V. 0.109. i tried hard and soft reset but nothing happens, is there a solution?
The unit has been put into the mode to reload the operating system. You need to connect it up and load it with fresh download of the system. You can probably download the firmware from the manufacturer's site in their support section. There may be no other way to restore it. Be careful as any corruption during a flash download can be fatal requiring return to the manufacturer for reloading. Find the firmware for your unit here:
http://www.dbxpro.com/Software.php
Follow the directions for instalation TO THE LETTER !!! Read twice before doing !!!!
Jul 21, 2011 | DBX Professional Products DBX Driverack PA...
Is there any way to reset the H4 back to factory settings? I adjusted levels and everythings out of whack now.
Hello.
Do you havce the manual to the H4? If not, I will provide you with a link to the PDF manual online. In thoroughly scanning thfe manual, there is no general reset function (in the manual, that is). It would be advised to call Zoom (who are very easy to work with) and ask them if there is a factory reset procedure which is not in the manual.
The manual for the H4 is very comprehensive, and there are default settings for many areas of the recorder. You could use this manual to reset your adjustments manually.
Here is the link to the manual:
http://www.samsontech.com/products/relatedDocs/H4_manual.pdf
Thanks for using FixYa
Aug 15, 2009 | Zoom H4 Handy Recorder
Guillemot Hercules DJ Console RMX Mixer Logo
19 people viewed this question
Top Guillemot Music Experts
Michial Gueffroy
Vito Vacirca Jr.
Are you a Guillemot Music Expert? Answer questions, earn points and help others
