Question about iRiver iFP-790 MP3 Player
Can iriver buttons be repaired - iRiver iFP-790 MP3 Player
System files missing
oooh thats a tough one. lets see, if it will still connect to the computer, the iriver tools that are used to update firmware should work. try to put it into restore mode by holding the right front button immediately after reset (use a pin or toothpick to hit the button on top) and plug it into your pc. hopefully those files are still intact. doing a refresh of the firmware should work. if not i believe there are repair tools for the h10 on irivers support page. http://www.iriverinc.com/lounge/loungeView.asp?selectPart=02&findWord=&sno=685&page=1&cateCode=02 this is a link to the page that has recovery tools and firmware update tools. Hope this helps!
Apr 13, 2010 | iRiver H10 MP3 Player
MODE/REC Button stopped working on iRiver IFP-790 digital audio player
I had the same problem. I got some electronic contact cleaner at Frys Electronics and sprayed a bit around the button, so that a little got inside. The button started working again instantly. If yu don't have contact cleaner you could first try a drop of denatured alcohol... I don't think it's as likely to work, but I also don't think it will hurt anything.
Arbie
Aug 04, 2008 | iRiver iFP-790 MP3 Player
IRiver Screen
You'd need to find someone with a dead one (dead for some other reason) you can then canibalise.
The LCD screen could be replaced you just need to find an appropriate alternative. eBay or web search would probably find one, But you'd need to find the spec of the original first.
Iriver don't repair but do they sell spares?
Jun 12, 2008 | iRiver PMP-120 Digital Media Player
IRiver hard drive problems
Try this: disconnect the player from the computer, turn it off, hold in the volume + button, and reconnect the player to the computer while holding the volume + button in. Keep holding the volume + button for an additional 5-50 seconds. Windows should eventually go into recovery mode and revive the player- it will pop up a window that says Found New Hardware Wizard.
Mar 30, 2008 | iRiver H10 MP3 Player
Where can I service my iriver mp3 player that is out of warranty
Forget it Pal you'll be happier with a new IPod. I looked for a repair shop and they wanted close to what an IPod cost.
Feb 02, 2008 | iRiver iFP-395T MP3 Player
Repair
update your iriver plus program. then in the tools menu there should be a firmware update button.
moz-screenshot.jpgmoz-screenshot-1.jpgi think it is in the tools dropdown submenu. try that.
Jan 19, 2008 | iRiver E10 Digital Media Player
REPAIR OF IRIVER H10 20G
Try rebooting the little hole next to the lock with a pen or something similar mine works everytime
Nov 16, 2007 | iRiver H10 MP3 Player
Iriver T20 not recognized
Try this: disconnect the player from the computer, turn it off Try this: disconnect the player from the computer, turn it off, hold in the volume + button, and reconnect the player to the computer while holding the volume + button in. Keep holding the volume + button for an additional 5-50 seconds. Windows should eventually go into recovery mode and revive the player- it will pop up a window that says Found New Hardware Wizard.
All the info/manuals/drivers/upgrades for the iRiver T20 can be found here:
http://www.iriver.com/product/p_detail.asp?pidx=71
Nov 16, 2007 | iRiver T20 MP3 Player
Used the wrong charger
you should check the battery voltage first before you get it repaired.
Jul 24, 2006 | iRiver iHP-140 MP3 Player
iRiver iFP-790 MP3 Player Logo
22 people viewed this question
Top iRiver Audio Players & Recorders Experts
Steven Wander
Steven Wander
Shawn DuRee
Are you an iRiver Audio Player and Recorder Expert? Answer questions, earn points and help others
