Question about Sunbeam Kitchen Appliances - Others
Need a knob for oster hotplate do you know were I can get one?
Double burner model# CKSTBUDSOO STAINLESS STEEL d0uble burner. the knob that turns the big burner is broken
  • 116 Answers
SOURCE: GE monogram double oven display getting extremely hot
Usually the knob type controls uses the bulb for temperature regulation. There is usually only one adjustment available - otherwise the thermostat has to be replaced. - that dial with the temperature graduations on it. the whole unit - the bulb in the oven is connected to it.
Posted on Aug 31, 2008
SOURCE: Looking for Oster stainless Steel
This part is not available online. If you call customer service at 1-877-383-6399 they will send you a new part with instructions on how to install it for $13.00 including shipping.
Posted on Sep 17, 2008
SOURCE: Oster Toaster Oven Model # 6192-33
I had the same problem where the time knob broke. I filled in a claim form on the Oster Website and they answered within 3 days saying the timer knob was discontinued and no longer available. They proposed to replace the whole toaster-oven with another model 6073-33 which I received last week. I've to say that their customer service was amazing.
Posted on May 12, 2009
  • 9 Answers
SOURCE: I need to know how to remove the stainless steel burners and replace them.
Call Weber to receive free warrenty burners. Have model and serial number found inside one of the doors on your grill. I just received them in the mail about a week ago and just replaced my burners today. Here is what I did.
Remove the grates and burner heat deflectors. There are 4 screws on the knob panel, 2 on the left and 2 on the right. Remove the screws and pull back about a inch or two. I found it helpful to open all the doors a bit to rest the panel on them. The burners should remove easily once this is done. Replace the burner tubes and be sure tubes have holes facing up on the one side for correct heat distribution. When placing the knob panel back on, make sure that burner tubes go onto the gas control knob correctly. Replace screws on the knob panel.
****Get a wire brush about the size of a tooth brush to clean the starter, the thing that makes the spark to start the flame.****
Posted on Jun 26, 2009
  • 6 Answers
SOURCE: the strap is broken on casio watch
I had exactly the same problem with exactly the same model watch, and it happened to me twice. The AQ-160 is the important part of the model number as far as replacement parts are concerned. The first time, I took it to the shop where I bought the watch, and they replaced the band, but it cost me $50. The second time, I looked up the Web for the master agent for Casio in Australia, and they said I could buy the end piece, not the whole band, for $6. I found I could replace it quite easily myself by using a drawing pin to remove the spring pin that holds it together. A bit fiddly to reassemble but not too bad. In fact, I didn't wait for the new part to arrive, just used the unbroken end of the old band. So now I have a repaired band plus the old band and a new end piece, in case it ever happens again.
I really like this watch, but it is a pity the bands are so weak.
Posted on Mar 17, 2010
I have a es400 stainless steel stove. my right front burner stays on. please help .
You have a problem with the hotplate controller. The controller is faulty and requires replacing. The controller can be accessed by removing the panel behind the controllers.
Apr 01, 2011 | Frigidaire 30" Self-Cleaning Freestanding...
I am experiencing some problem with the controls on the cooktop. When turning the dial to the desired temp, sometimes the burner comes on, sometimes it does not. Some of the burners only engage when we...
I haven't heard of this problem before. If you do press down and the hotplate starts to work we know that the hotplates are okay. The only thing this could be is an internal problem inside the hotplate controller, possibly with the contacts. The controllers will need replacing.
Mar 04, 2011 | Whirlpool GJC3034 Electric Cooktop
Gas oven lights pilot straight away but takes a long time for main burner to work has it got a thermocouple and cuold this be at fault
Sorry to read about your problem, I hope this helps you out.
I will assume you have the gas. there is no thermocouple, your oven use electronic ignition.
you may have a bad liter or you need to clean the grills
Hotplate Top Enamel or Stainless Steel
Hot soapy water, soft cloth. Any stubborn stains remove gently with a nylon scourer.
Pan Supports, Wok Cradle (some models only)
Enamel coated Cast Iron or Stainless Steel
Cif Cream Cleaner- Faberge Lever and a nylon scourer.
Dishwasher.
Burner Caps Enamel
Cream cleaner, nylon scourer. Dishwasher
Burner Trim Rings (some models only) and Burner Head
Aluminium
Cif or other cream cleaner with a soft cloth. Be careful not to be over vigorous.
Griddle Plate (some models only)
Non-Stick Surface
Allow to cool. Wash in hot soapy water. Do not use abrasive cleaners/scourers. Dishwasher.
I tried to help you. Please help me and Rate/Vote on my response. We take the time to answer your question. take the time to rate us.Thanks and good luck
4 Thumbs - Very Helpful
3 Thumbs - Helpful
2 Thumbs - Somewhat Helpful
1 Thumb - Not Helpful
Dec 26, 2010 | Rangemaster Toledo 90 (Dual Fuel) Dual...
My right front burner does not work on low. it does not turn on until you turn the knob to about the medium setting
many burners have safety mechanism that shuts the flow of gas when it is cold. it is there to prevent the flow of gas in the case when the fire was put out by wind or split of water.
you didn't mention if after the fire is lighted, are you able to turn the knob back to low.
Nov 16, 2010 | Maytag Gemini 30" Self-Cleaning...
When I push down and turn the knob to "on", the knob pops back up causing the burner to turn off. Any ideas on how to fix this? Thank You
You might need to hold it down for a few seconds if the cook top has automatic flame detection. A bi metal strip (or some other form of thermostat) near the burner will need to heat up before the burner can lock on.
Jun 15, 2010 | Jenn-Air JEC9530BDS Stainless Steel ...
I have a gas range and I think the burners are turned too high, I can boil my food when I have the knobs turned to low. I would like to know how I can lower the flame. I pulled out the knobs and thought...
ther should be 2 sets of brass nozzles for the burners, make sure that the correct ones are installed, ie natural gas or propane. they have a different injector size for each.
Dec 01, 2009 | Maytag MGR5875QDS Stainless Steel Dual...
Apr 16, 2009 | Ducane 30400042 (LP)
White to stainless
Black, white and bisque seem to be the only colors available for the double convection oven. Might be possible to find the cooktop, but it's hard to know for sure without the model number.
In my experience, it's often not economical to switch to stainless steel as stainless steel panels can be extremely expensive (I've seen a freezer door on a side by side fridge sell for over $850... Just the freezer door!)
Mar 05, 2009 | Kenmore 24 in. 17482 / 17484 / 17489...
Sideburner for Thermos Stainless Steel Gas Grill (Mod # 461262006)
It sounds like the orifice is bad. An orifice is a small metal part that has a small hole in it. This regulates the gas coming out to the burner. It is at the tip of the pipe that brings gas to the burners, before the flame. I don't know what the hell the garggley noise is. Unless the bottle is upside down, and you are getting liquid, I don't know.
Mar 02, 2008 | Thermos Stainless Steel Gas Grill
Kitchen Appliances - Others Logo
Top Sunbeam Kitchen Appliances - Others Experts
Are you a Sunbeam Kitchen Appliances - Other Expert? Answer questions, earn points and help others
