Question about Dell Inspiron 531s Desktop Computer
Can't System Restrore Dell Inspiron 531.
When I turn on my computer a screen pops up. On this screen it gives me the option to "strike f1 to retry boot, f2 for setup utility." After I strike f1 the computer starts up normally. While it is starting up I strike f8 to repair my computer, BUT WAIT I do not have the repair my computer option. The options are in order as follows.
Safe Mode Safe Mode With Networking Safe Mode With Command Prompt
Enable Boot Logging Enable VGA Mode Last Known Good Configuration Directory Services Restore Mode Debugging Mode Disable Automatic Restart On System Failure
Start Windows Normally Reboot Return to OS Choices Menu
Please help me, I have tried everything, but nothing seems to work.
This can usally be sorted by inserting your Dell windows OS restore disc & choosing the repair option.
Posted on Jun 23, 2009
No bootable device detected
If you strike F1, the system retries as said in the comment. That does'nt solve anything. Rather strike F2 which allows to enter the setup menus of your computer.
In this area you should understand what you are doing. Any update of setupdata may prevent further restart. At least take note of values and changes. You exit setup via a question "update Y/N". Then the computer restarts.
Anyway, in the setup menu you may inspect the devices and see if you the system identifies the disk. If not it may come from a bad connection of hard disk (sata pins, ...) or from low level disk information (format information).
With setup menu you may get in the boot order menu, that allows for the selection of an alternate boot media. You may boot on an installation media, ( install DVD generally, like originall windows install DVD) in order to understand and repair the situation, or from a rescue system like UBCD. You may also try Ubuntu from the CD without installing, just to verify if you may see the disk in the configuration.
Regards
Jul 09, 2014 | HP Computers & Internet
When i start up my computer it says no bootable devices--strike f1 to retry boot, f2 for setup utility press f5 to run onboard diagnostics
Well I think the problem is that it can't find the hdd or it is not booting from it, to fix boot up your laptop as soon as you boot up the laptop start pressing f8 until a screen appears when the sceen appears select the hdd option (a few other options should pop up as well) and after you have done that sit back and wait. If that does not work you might have to take out the hard drive and then put it back in.
May 22, 2011 | Dell XPS M1330 Notebook
My Laptop is Dell Latitude D600 (A16) Everytime I tried to power up, Splash screen appears with blue bar and when going into next screen this message appears " No bootable devices--strike F1 to retry...
Check your BIOS, by pressing F2 and see if the hard drive is recognized. It should indicate the MFR next to the hard drive listing. If it's not there, then you might have a bad hard drive. If it is there, try re-installing the operating system with the set-up disk. You can also go to the Dell website, enter you service tag number, and get technical support for your particular laptop. It might have a recovery partition in the hard drive to recover to factory settings.
Oct 26, 2010 | Dell Latitude D600 Notebook
My Desktop Dell Optiplex GX200 computer says Alert! Cover was previously removed. Strike F1 to retry boot . F2 for setup utility. I never opened my computer and when I click F1 it doesn't do anything but...
If it is not keeping time then you need to replace the computers clock battery. The battery is a cr2032 battery usually.
follow the below link for instructions on how to do that.
http://support.dell.com/support/edocs/systems/opgx200/en/sm/index.htm
Sep 01, 2010 | Dell OptiPlex GX200 PC Desktop
Can't factory restore dell inspiron 531 (windows xp).
You might want to try going into setup and setting your boot drive options to DVD drive as your 1st, HD as 2nd and Floppy as 3rd. Put your windows disk in the DVD before boot and run the program from DVD.
Jun 23, 2009 | Dell Inspiron 531s Desktop Computer
Strike F1 key to continue, F2 to run the setup utility
Please let me know what is the make and the model of the pc that you are using.. Also, go to the bios, under boot menu, make sure that you have hard drive as the first boot option.. For further queries please get in touch..
May 28, 2009 | Computers & Internet
Dell latitude C610
From the Bios, load all the default settings and then check the bios SATA port settings. If it is set to AHCI, change it to IDE to boot from Hard Drive. This should solve the problem
Oct 01, 2008 | Dell Latitude D600 Notebook
Dimension 3100 Won't Boot
Make sure your HD Cables are all firmly plugged in, and that all drives are starting when you turn on the computer. You can tell with harddrives as they will slightly whine, and have a small, steady vibration to them. If they are all starting, and all cables are fully seated, check in your Setup utility that the drives themselves are Auto-Detect. If none of this fixes your issue, you may have to refer your computer to a computer repair shop.
Hope this helps!
-Backu
Jan 16, 2008 | Dell Dimension 3100 PC Desktop
1 beep and won't boot...Strike F1 to retry or F2 for setup utility
hi! i have a prob with my pc its an DELL GX OPTIPLEX 270. It doesn't work in the boot, it lunch me a message at the first screen (strike f1 to retry boot, f2 for utilities). I have try many solution but it doesn't work. So, plz if any one can help me to solve my pc.
i'm waiting for and thx.
Jun 13, 2007 | Dell OptiPlex GX110 PC Desktop
Dell Inspiron 531s Desktop Computer   Logo
410 people viewed this question
Alun Cox
mukhtar21 shaikh
mukhtar21 shaikh
