Question about DeLonghi Magnifica XS Espresso Maker
The internal sleeve of the frothier wand won't stay on.
The model is ECAM22110SB MAGNIFICA S
I have a Magnifica. The descale red flashing light won't reset after going through the descaling procceedure.
I have the same problem with my Delonghi Magnifica, so maybe there is a glitch in the machine..
Aug 20, 2011 | DeLonghi Magnifica 3300 Espresso Machine
The steamer arm has blown off. After it was reattached with a new pin it will not stay on and continues to leak.
You need a new o-ring that goes around the steam wand. Slide the o-ring over the wand and then insert the wand back into the sleeve. I kniow this sounds too simple to be the true fix, but it is!
Dec 18, 2010 | Gaggia Syncrony Logic 74884 Espresso...
I have lost the booklet and need to descale my Delonghi magnifica. I remember having to use the capuccino wand but that is all I remember
You can download the manual from the manufacturer's web site at
http://www.delonghiusa.com/downloadpdf.php?nid=20
Descaling instructions begin on page 16,
Jul 11, 2010 | DeLonghi Esclusivo Magnifica ESAM3300...
A peice(oring maybe) fell out of the steamwand while I was taking it apart. now the attachment will not stay on the wand it just falls off, can I get a new one?
Hi
There should be 2 removable pieces between the cap and the main body. There should be a plastic compression sleeve, and a rubber sleeve. They should look similar except one is hard and the other is soft. The best way to clean the steam tip is to loosen the cap and pull the bottom of, leaving the other pieces on the wand.
Nov 14, 2009 | Saeco Starbucks Sirena Espresso Machine
I need a replacement steam wand sleeve
I called them about the same problem, they can only sell the entire wand assembly, not the teeny washer that I lost. $35. If I knew what it looked like I wonder if I could find something at a hardware store.
Jun 06, 2009 | Saeco Starbucks Sirena Espresso Machine
DeLonghi EAM3400 Magnifica with broken steam spout
No offense to Irishwarrior but the answer to your question is yes, you can buy a replacement. Call Delonghi. The inner sleeve has a flat spot on the back that matches up with the steam wand. No glue, and o ring holds it in place, either the o ring is worn out or the hole in the bottom of the sleeve is partially clogged creating more pressure than the resistance of the o ring. A paper clip straightened out will "****" it out. If you need to replace the whole steam wand arm you would want to order a new "tap" valve. Delonghi can give you the # of an authorized service center where you can order one (Delonghi will not sell you "internal" parts)
Feb 28, 2009 | DeLonghi EAM3400 Espresso Machine
Need replacement steam wand sleeve
http://saecooutlet.com/ has parts and help for the sirena machine
Jan 22, 2009 | Saeco Starbucks Sirena Espresso Machine
Milk not frothing
Remove the black plastic outer sleeve of the Frothing Wand (some models have a metal outer sleeve). If done correctly, the “sleeve” has been removed, but the inner wand with red or black washer, is still connected to the machine.
2) The part of the sleeve assembly that you have removed is comprised of 2 pieces, the frothing sleeve and the center piece. The center piece can be seen if you look into the top of the wand.
3) Using a pencil (eraser end), or similar shaped object, push down on the center piece until an audible “click” is heard. The “click” means that the centerpiece is back into the proper position. When in the proper position, the center piece visibly sticks out the bottom of the sleeve about ¼-inch. It looks like a bird beak.
4) Now put the sleeve back on the machine and your machine should be ready to froth again.
As for the milk island, translaltion from the italian solution using google and drying all the parts works
Aug 29, 2008 | Saeco Talea Giro Espresso Machine
Barista athena
I have just had a similar problem. Water no longer moves through the steam wand when I try to prime it. Instead, water shoots through the shot handle (or screen if handle is not in).
One thing I did notice is that the dial for the steam wand unscrewed too far and basically popped out. I screwed it back in and the water did not ever come out of the wand again. I took the top lid plate off and unscrewed the wand dial and removed it. I put it back and noticed that there is a little metal spring switch underneath that I assume turns the wand pump on.
Attached to the dial is a plastic sleeve with a flat side. When the dial is turned, this sleeve should turn the switch on. I noticed though that the sleeve is creeping up the shaft towards the dial head which makes it miss the spring switch.
I don't know what kept the sleeve in place before. Probably a plastic stop that has been worn away from use. There is an allen screw in the sleeve, but tightening it doesn't seem to keep it in place. Perhaps inserting a spring in between the dial and the sleeve would work, but the sleeve cannot be taken off to do this. No other answers right now. My wife is not happy the lattes have dried up.
Aug 13, 2008 | Estro Barista Athena
DeLonghi Magnifica XS Espresso Maker Logo
Top DeLonghi Coffee Makers & Espresso Machines Experts
Henry  Thomas
Henry Thomas
Shehu Pro
Shehu Pro
Are you a DeLonghi Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
