Question about Honda 6370C - Parallel Power Kit For EU3000i
Generac 7550 EXL runs no power have another
Have another generac 7550 EXL runs no power have another working 7550 switched control and voltage regulator boards still no power. the boards out of the one that wasn't working work in the working one... brushes look good and clean.. have not excited yet.. unit was powering my fifth wheel ac, a small fan and rv refrig and suddenly i noticed the fan going half speed and then nothing...has 60 hours on this thing...any other suggestions before exciting
  • Craig Butler
    Craig Butler May 11, 2010
    Could be the voltage regulator. Diodes can fail. Maybe the generator itself too, but more likely to be a bad connection to the rotor from regulator or the reg. itself.
SOURCE: Honda CRV 2003 Heat/A.C. fan Fault
I lost the link for this thread, Thanks for posting ED. There was some great help on this problem at this site. the fault ended up being a thermal fuse in the fan speed control moduel (black box in the a/c ducting next to the fan) $3 fix!
http://www.hondasuv.com/members/showthread.php?t=24831&page=6
Posted on Jan 29, 2009
  • 83 Answers
SOURCE: do you excite generator while it is running ?
Yes! The generater must be running. Only apply voltage for one or two seconds when exciting then check for ac voltage with a meter. You can try again if no voltage. Note: if exciting the field does not work your problem may be something else.
Posted on Mar 30, 2009
SOURCE: Cruise control NOT WORKING
Check your rear brake peddle and see if the sensor for the cruise control is out of adjustment. I had the ame problem on my 1990 GL1500.
Posted on May 29, 2009
  • 154 Answers
SOURCE: generac rv altenator wiring
white is neutral black is hot and green is ground
Posted on Jun 14, 2009
  • 23 Answers
SOURCE: passanger window does not go down from driver power window switch
The control switch on the drivers door is bad if the window rolls down using the passenger switch
Posted on Jun 21, 2009
Testimonial: "not bad"
I need a rectifier or avr for generac 3500 xl genarator
Ebay and various places including the maker..
  • VOLTAGE-REGULATOR-3000-3500-WATT-GENERATOR-GENERATORS ... www.ebay.com/sch/sis.html?_nkw=VOLTAGE-REGULATOR-3000-3500-WATT... VOLTAGE-REGULATOR-3000-3500-WATT-GENERATOR ... New listing 3500 Watt Generator AVR Automatic ... 3500W Generator AVR Automatic Voltage Rectifier ...
  • 3500 W 3500 Watt Generator AVR Automatic Voltage Regulator ... https://sites.google.com/site/kltthtyz0i04cd/3500-w-3500-watt... Generac Guardian 22kW Standby Generator NG ... Previously Pay for Shop 3500 W 3500 Watt Generator AVR Automatic Voltage Regulator Rectifier 3.5KW Generator AVR ...
  • How to test your Electricity Generator's AVR, Brushes and ... www.youtube.com/watch?v=tC_LrrZcx38
    • BY GENERATOR GURU
    • 9 MIN
    • 454K VIEWS
    2011-10-21 · Video embedded · When your electricity Generator stops producing power, ... How to test your Electricity Generator's AVR, ... Generac iQ: The Quietest Generator ...
  • Generac Power Systems - Home www.generac.com Generac manufactures the widest range of power products in the marketplace including portable, RV, residential, commercial and industrial generators.
  • Generac Guardian Generator Voltage Regulator Rectifier ... www.ebay.com/sch/sis.html?_nkw=Generac+Guardian+Generator+Voltage... Generac Guardian Generator Voltage Regulator Rectifier ... Generac Guardian Generator Voltage Regulator Rectifier ... Generac Guardian Generator Voltage Regulator ...
  • Automatic Voltage Regulator (AVR) for Generators portable.generatorguide.net/avr.html How automatic voltage regulator (AVR) works in portable generators: ... here you can see a reverse engineered Generac regulator that uses SCRs and UJT.
  • Diagnosing A Generator That Has No Power Output. - YouTube Youtube
    • BY THEDIYGUYDOTNET
    • 3 MIN
    • 150K VIEWS
    2012-11-12 · Video embedded · Diagnosing A Generator That Has No Power Output. ... How to test your Electricity Generator's AVR, ... Generac Portable Generator ...
  • GENERATOR Diagram & Parts List for Model 3500xl Generac ... www.searspartsdirect.com > ... > 3500XL GENERAC Generator-Parts GENERATOR Diagram and Parts List for GENERAC Generator-Parts model # 3500XL ... Generator rectifier Part #: ... Generator voltage regulator Part #: ...
  • Jun 28, 2016 | Generac Electrical Supplies
    My 7550 exl runs to fast
    The generator needs high RPM to produce the right voltage.
    Sep 06, 2014 | Electrical Supplies
    Generac portable generator over voltage even with new control board and regulator
    is engine running at 3600 to 3700 rpm at full load. most small engines run at this speed.you can buy a small tach on ebay TINY TACH.. you have to know what the engine speed is
    Mar 04, 2013 | Electrical Supplies
    Need Users manual for Generac 4000 EXL generator
    Hi and welcome to FixYa, I am Kelly
    Below is a list of all the manuals an owner should have:
    For the 4000 EXL Your actual model number is 01645.
    Operators manual:
    http://www.generac-portables.com/document/index.cfm?doc=1645_0EN11CS_LO.pdf
    Wiring Diagram:
    http://www.generac-portables.com/document/index.cfm?doc=1645_0WDS_LO.pdf
    Parts List:
    http://www.generac-portables.com/document/index.cfm?doc=1645_0PARTSLISTCCS_LO.pdf
    Thanks for choosing FixYa,
    Kelly
    May 18, 2011 | Garden
    Generator was running and quit delivering voltage while running. Turned it off and then restarted and checked voltage with no load. no voltage...no smell...plenty of oil...seems like a breaker8000 exl...#...
    It very well may have been a breaker that opened up permanently.
    But, I bet that the generator was under heavy load for prolonged time, and one / both of the diodes in voltage regulator have opened up. You will have to disassemble the end housing of the alternator to get to these, and then test with multimeter to know for sure.
    Of course, your generator may have an electronic controller, and not use diodes / capacitor at all. Since don't have model #, can't be sure.
    If engine has dropped much under 1800 (4 pole alternator) or 3600 (2 pole alternator) RPMs, then alternator output would tank or be nonexistent.
    Dec 09, 2009 | Generac Electrical Supplies
    No power output from my generac 5000 power plus generator
    It is possible that your voltage regulator is shot but before purchasing the volt regulator try flashing the fields first and make sure the brushes and rings are clean.
    Apr 09, 2009 | Generac 100 Amp 120/240-Volt Transfer...
    Generac EPS-15 attempts to engage the starter while running
    I work on these everyday. You most likely have a bad rotor or stater if the starter engages while running and no output. The no out put is making the generator think its not running causing it to try and start. If its not that then its the control board or voltage regulator.
    Apr 07, 2009 | Generac 13,000 Watt / 13,000 Watt Home...
    No voltage output
    Apr 02, 2009 | Generac 5622 GP Series GP5000 6,250 Watt...
    Honda 6370C - Parallel Power Kit For  EU3000i Logo
    876 people viewed this question
    Top Honda Electrical Supplies Experts
    John Trevino
    Craig Butler
    Craig Butler
    Are you a Honda Electrical Supply Expert? Answer questions, earn points and help others
