Question about Generic Xbox 360 Power Supply Cord Ac Adapter
Power cord light is green for couple sec then goes orange on xbox 360
When i turn on my xbox i'm getting 3 flashing red lights what does this mean
it means your xbox is overheating, you can send it back as they extended the warranty on it for this common fault unless you have modified it, in which case look up ring of death on youtube.
Jun 13, 2011 | Microsoft Xbox 360 Elite Console - Black
Power box light is blinking orange and sometime a steady red and console want come on.
Green Indicator Light:
The default indicator light is green. When the Xbox 360 power supply light is green it means that there are no problems with your power supply. However, if you are having problems and the power supply light is green, this means that the console is faulty and you need to contact Xbox 360 support.
Orange or Yellow Indicator Light
When the Xbox 360 power supply light is orange or yellow this means there is no problem with your console but the power supply can't supply it with power.
To remedy this problem, first try unplugging the Xbox 360 power supply from the console and unplug the power cord from the wall outlet. You'll also want to uplug the Xbox 360 power supply from the power cord.
Wait for about five minutes and then reconnect everything. You might also want to try plugging it into another wall outlet without an extension cord.
If you are still getting an orange or yellow indicator light, then something is at fault with the Xbox 360 power supply. If this is the case, contact the Xbox 360 customer support to get a new one.
Red Indicator Light:
If the xbox 360 power supply light is red, then there is something wrong with the power supply connection. If this is the case, try the same solution as listed above of unplugging the power supply from the console, unplugging the power cord from the wall outlet and unplugging the power supply from the power cord. Wait for about five minutes and then reconnect everything. You might also want to try plugging it into another wall outlet without an extension cord.
If the indicator lights are still red, then there is a fault with the power supply. If this is the case, contact customer support about getting a new one.
No Indicator Light:
If the XBox 360 power supply light is not illuminating at all, this usually means that the Xbox power supply is not connected to the wall outlet correctly. On the other hand, it might also be a fault with the power supply or the power cord.
Either way, try the same solution as listed above for the red indicator lights. If you still don't see any lights illuminated after unplugging and then reconnecting everything, you'll need to contact customer support about getting a new power supply.
Green and Orange Indicator Light:
If the indicator light is flashing green and orange, this may mean that the console does not detect the AV Pack.
Disconnect and then reconnect the Xbox AV Pack. Make sure the connections are firmly connected. Turn your Xbox back on.
If the indicator light is still flashing green and orange, try another AV pack if one is available.
If the indicator light is still flashing green and orange, you'll need to contact Miscrosoft Customer support.
Flashing Orange Indicator Light:
If your Xbox console's indicator light flashes orange, this means the internal components have overheated and the Xbox has automatically shut down to prevent damage.
Turn off the console and let it cool for at least 10 minutes.
To prevent the Xbox from overheating in the future, make sure that it's not placed in a closed cabinet or on carpet. It's best to get the Xbox elevated off the ground where the PSU can have maximum heat release.
You'll also want to make sure the Xbox is not located near a heat source like the back side of a television, computer, monitor, or other electrical device.
Aug 26, 2010 | Microsoft Xbox 360 Elite Console
My xbox had the 1 red ring (e74) but now has 3 red rings. We repaired the x clamps but now when we turn it on, the light on the power cord turns green but then goes back to orange even though it's on. We...
only known fix for the three rings is to send it in to microsoft for a new after they have examined it to make sure it has not been tampered with or other means of voiding the warranty
Mar 30, 2010 | Microsoft Xbox 360 Console
My 360 does not have power to console. the light
Have you tried removing all extra accessories?
Xbox.com states:
Mar 01, 2010 | Microsoft Xbox 360 Console
Xbox won't power up, orange light is on the power brick
Are you using a plug and play kit? if so disconnect it, mine does that sometimes, if thats not the case comment me,I would write them all down but I am getting a bit fed up with writing lots of solutions to problems and getting no response from the person I give the time to help.
Feb 13, 2010 | Microsoft Xbox 360 Console
What does it mean when the light on the battery is orange?
It should be orange when their is power to xbox, but the xbox is not on. when you turn xbox on the light should change to green if working correct.
Dec 18, 2009 | Microsoft Xbox 360 Console
Xbox 360 has orange light on the power brick,no power to console?
Mine has an orange light and works fine. i think that's standby mode. it turns green as soon as the 360 powers up. try replacing the power cord that goes from the 360 back to the power block. It may be faulty.
Nov 21, 2009 | Microsoft Xbox 360 Console
Xbox 360 won't turn on
I had this problem. Make sure the pins in the USB ports (2 on the front and 1 on the back of the console) aren't bent and there's nothing obstructing them. I unbent some of the metal inside these ports, and voila! I have a working xbox.
Oct 09, 2009 | Microsoft Xbox 360 Console
Xbix 360 keeps turning off and on
there is supposed to be a light indicator on the power supply unit, there is green, orange and red, (make sure that the console is turned on to check on these..)
if its green, it could be a loose power cord
-if its orange, check the connection, make sure they are properly connected
-if it is red, your power supply unit is bad, let it cooldown for a couple of hours, and then if its still red, replace it
-try to change outlet as well to make sure that you're not having issues with your outlet..
Jun 30, 2009 | Microsoft Xbox 360 Console
Power brick colour
Alright, lets fix this!
 Xbox 360 power supply light is orange or yellow.
Usually when the Xbox 360 power supply light is orange it's on standby so there is no problem with your Xbox 360 console but the power supply can't supply it with power !
First you have to try unplugging the Xbox 360 power supply from the console & unplugging the power cord from the wall outlet also unplug the Xbox 360 power supply from the power cord, wait for a minute then reconnect it all back , also try it on another wall outlet without any extension cords at all.
If it's still doing the same it will be definitely a fault with the Xbox 360 power supply.
So, in this case please contact Xbox 360 customer support to fulfill the Xbox 360 power supply.
Xbox 360 power supply light is red.
There is something wrong with the Xbox 360 power supply connection so try unplugging the Xbox 360 power supply from the console & unplugging the power cord from the wall outlet also unplug the Xbox 360 power supply from the power cord, wait for minute then reconnect it all back , also try it on another wall outlet without any extension cord at all.
If it's still red that would be for sure a fault with the Xbox 360 power supply .
So, then contact Xbox 360 customer support to fulfill your Xbox 360 power supply .
You can also find replacement power cords many places online. See if you can get your hands on another cord and try that to see if its the current power cord.
Hope this helps you out! Please don't forget to rate :)
Apr 10, 2009 | Microsoft Xbox 360 Console
Generic Xbox 360 Power Supply Cord Ac Adapter Logo
61 people viewed this question
Top Generic Video Game Consoles & Games Experts
James Wishart
Are you a Generic Video Game Console and Game Expert? Answer questions, earn points and help others
