6500creeldiagrams I need a diagram for an ambassador 6500C bait casting fishing reel,where might I be able to obtain one?
ngfam1
  • 639 Answers
SOURCE: ambassadeur big game 7000 fishung reel
your listed under washers???????????????????
Posted on Aug 31, 2008
SOURCE: Quantum Tour Edition 1170PT baitcasting fishing reel
Tighten the drag star to expose the black ratch ring. Press the ratchet ring down towards the star drag as you turn the handle backwards to unscrew it from the crank shaft.
Posted on Apr 16, 2009
garyhembree
  • 7 Answers
SOURCE: I need a manual for a pflueger echelon bait
type in" manual pdf " after a name of a product
Posted on Nov 06, 2009
  • 190 Answers
SOURCE: need manual for daiwa pt
I recommend you call Daiwa and ask them to send you one for it. Contact information is available at the following link:
Daiwa
Hope this helps
Regards,
DIYpro
Posted on Apr 28, 2011
ka4iup
  • 3957 Answers
SOURCE: Need a schematic for bait casting reel showing part
Google searchs using your manufacturer make and model and the words manual and parts manual. If one is available, you can find it in the search results.
Posted on Apr 02, 2015
Apr 02, 2015 | Fishing
How to buy a fishing reel
Depends on what type of fishing your doing. Out of the two the bait caster is the more challenging to do because you control the line going out. That is good for fishing banks, logged areas, spinner bait. If you just want to cast with bobber go with open or closed reel. Hope that helps.
Aug 21, 2014 | Fishing
How to fix Defiance 25LW that will not cast (or free spool)
Those reels are very simple, nothing too complex about them at all, sounds to me that the clutch gear is stuck not and not releasing when you try to engage it. I've had similar bait caster lock up like that when trying to cast heavier baits, what happens is the spool spins so fast that the inertia and vibration causes the reel to actually engage mid cast slamming the gears together. not good for the gears by the way. more that like the reel needs to be opened up and looked at to resolve the issue. www,darksidereelz.com for all your reel service needs
Jul 09, 2014 | Penn Defiance 25LW 66" Combo
Abu garcia silver max reel manual
those are your magnetic cast control. it is a magnetic braking system. i suggest setting it at "5" and dont adjust unless you are casting into the wind, if that is the case turn it up to towards maximum and keep your casts low to the water and use heavy baits. its a great tool to help eliminate backlash.
Apr 05, 2013 | Abu Garcia Pro Max Baitcast Reel
I need directions on how to reel in a fish
The key is to watch the "fish mood"... watch for a "Yellow Heart" on the top of the screen as you reel in, this means a fish is lured by your bait... When you see this, stop reeling with the "A" button and begin using the control pad... up or down will just bounce the bait... it's a little counter-intuitive to "real" fishing, but if you stop reeling when you see this "Yellow Heart" and simply wait for the fish to swim around your bait, then bounce the bait with the up or down control buttons, the fish will usually take the bait. Then simply reel them in being careful not to reel too fast... using the "A" button, don't let the meter go to high or too low... simply let off the "A" button if the meter gets to high or low... eventually you'll be able to reel them in by pressing and releasing the "A" button. Likewise with the "yellow heart", also watch for a "red exclamation", this indicates the fish is trying to bite the bait. Use the same method simply waiting for the fish. If you never see either of the two fish moods (yellow heart or red exclamation), then you'll need to either change direction of your throws, or change bait. I've conquered a few levels with this method after many hours of not even a bite.
Oct 18, 2009 | UFO Interactive Professional Fisherman's...
Washing Machines Logo
11 people viewed this question
Top Washing Machines Experts
