Question about Garden
How can i get a sv150 sume-c-linhai engine for a challenge xtreme lawn mower ?
    Genius:
  • 1,406 Answers
CraigsList? EBay?
Posted on Jun 07, 2014
5 Suggested Answers
  • 45 Answers
SOURCE: lawn mower wont start possibly flooded the engine
make sure you have a good clean and dry spark plug
Posted on Apr 29, 2009
defadad
  • 351 Answers
SOURCE: how do i change wheel height on lawn mower
You do not change the wheel height, you change the cutter height,there should be an arm sticking up neart he rear wheel, you just push it to the side a little and push it either forward or backward.
Hope this helps
Posted on May 11, 2009
nobby63
  • 10 Answers
SOURCE: lawn mower stalls when engine is hot
first thing is to check that plug is not fowling up when hot due to motor burning to much oil.
Posted on Jul 26, 2009
  • 6468 Answers
SOURCE: how to add oil to snapper lawn mower
if there is no dip stick then look about a inch above the base of the engine for a plastic screw about 1/2'' in dia
Posted on May 29, 2012
How to replace plastic blades on a challenge mower
Dave, Remove plug wire, raise mower, or tilt on it's side to access blade. Remove center bolt holding blade on, noting the position so as not to install new blade upside down. Install new blade correctly and tighten blade bolt tight. Check the attached links,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
How to Change Lawn Mower Blade
Lawn Mower Repair How to Remove Lawn Mower Blades
What Direction Do Turn the Nut to Change Mower Blade
Jul 28, 2016 | Garden
Any advice on replacing the lower tube on a toro model 20197?
no its pretty straght forward just reminber how it goes back to gether
Jul 13, 2014 | Toro Power Lawn Mower
Where is the fuse box on gt 5000 craftsman lawn mower?
If you think your riding lawn mower has blown a fuse, trying to locate that fuse may be the most challenging step in replacing it. While different lawn mower manufacturers have located the fuse holder in different areas of the lawn mower, the best place to start looking is near the mower's battery, according to Sears.
Some manufacturers have made it easy to find the fuse holder. Simply lift the hood. The fuse holder is molded into the metal right inside the hood, near the battery. (See photo at Ref. 3, p. 53) If the battery is located beneath the seat, you may find the fuse holder located beneath the rear fender. Other manufacturers make it more challenging, placing the fuse inside an electrical box, located behind the mower's upper air baffle. (Ref. 4, p. 28) Fuses can also be located on or close to the edge of the mower's electrical panel, above the solenoid.
If you check these locations and still cannot find the fuse holder, check your operator's manual for a diagram of the electrical system, which should display the fuse's location. If you no longer have your manual, it may be available online through the manufacturer's website. Should you be unable to find a manual, call a local lawn mower dealership or lawn mower repair shop and ask for assistance in locating the fuse in your exact model.
Jun 27, 2014 | Craftsman 20 hp 42 in. Deck Lawn Tractor -...
Challenge Extreme 3.5hp lawn mower manual
Front center of motor, look for plug wire.
Jul 12, 2013 | Garden
How to start challenge xtreme petrol lawnmower
This mower in nigh on impossible to start, having had a Briggs and Stratton previously the xtreme isn't fit for purpose. I bought brand new one 2 weeks ago and the only way it would start ( after 20 attempts, no exaggeration ) was to swap the spark plug with my old B&S. It's very prone to flooding, as it fails to start everytime y pull the cord with the throttle open it's pumping more fuel in. I'm taking it back tomorrow, managed to cut the grass twice and now refuses to start at all, Advise yu to avoid at all costs.
Apr 06, 2013 | Garden
Belt jump off the drive pulley
I don't have this kind of mower. But I was faced with the same problem recently. I got my belt back on by taking a large wrench and affixing it to the bolt head holding the pulley which you want to slip the belt on. Hold the belt firmly against the pulley and turn the wrench and the belt in the grove will walk around the pulley until it slips in place.
Apr 02, 2010 | Briggs & Stratton Lawn-Boy Insight Series...
How do i change wheel height on lawn mower
Hope this helps
Apr 29, 2009 | Garden
Sovereign SLM 1500 lawn mower blades have stopped turning
The belts are available part number is SV150. Call ALM Manufacturing 01423 797208 for advice/stockists.
Apr 13, 2009 | Garden
Garden Logo
63 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
