Question about Electrolux Vacuums
Have a 6500 epic electrolux canister vac shuts off if you restrict the hose new bag not completly
    Night Owl:
    An expert who has answered 10 or more questions between 12 midnight and 6am on the same day.
  • 72 Answers
Shake the bag if you've been cleaning up "fine" carpet freshener powder, drywall dust or anything extra fine as it clogs the pours of the bag and the machine stops thinking the bag is full. If this doesn't work, you'll have to have the control valve on top cleaned or replaced to correct the issue. Hope that helps!
Posted on Nov 24, 2014
  • 44 Answers
SOURCE: Repair manual for Electrolux EPIC 6500 SR
I don't have a manual for these but the trickiest thing about these units is taking them apart. If you have an Aerus/Electrolux dealer near you, it's not a bad investment to have them install the motor for you. You would probably receive a warranty with the work, and the things a long time. Great return on investment. But if you are determined to do it yourself, open the front of the canister and remove the bag. As you are looking at the front of the unit, there are two vinyl coverd strips that run the length of the unit. Pull forward on these strips and then pull out so that the vinyl seperates from the plastic underneath. Now grab the plastic strip with a pair of needle nose pliers and pull towards the front of the canister. These can be tough if the machine has never been opened up before, but pull as hard as you need to, to slide the strip out. Once both strips are out, turn the machine over, pull out on the sides of the bottom of the unit, and lift up. The bottom should come of relatively easily, and eveything will be exposed. Good Luck!!
Posted on Jan 01, 2009
  • 566 Answers
SOURCE: Electrolux #1521 Canister Vacuum won't stay closed
hi from uk your problem with the canister cover/door coming off whilst vaccing ? you have renewed bag ? ok but there is a filter/gauze also inside the canister where bag is fitted if you check inside you should see the filter at opposite end from where bag is secured it is usually fitted behind a slotted pull out plastic gate ? this filter/gauze is to allow air out of canister when vaccing and the filter traps any dust that may accumulate inside the canister case so the dust does not get blown out to atmosphere/rooms SO if this filter is clogged it will not allow vacced air to escape out of canister so result is build up of pressure within cylinder and eventually cover flips open ! so for now you can remove filter/gauze and wash then dry refit this will allow air to escape from canister but still retain dust particles from escaping as it is designed for however may i suggest you replace filter when convenient ? all above is on assuming that the latch on cover is working ok and not now damaged ? hope this helps best wishes
Posted on Mar 01, 2009
  • 4 Answers
SOURCE: Full Bag Shut-off Comes on With New Bag and No Hose
The control valve has gone bad. This is the dial that you move on the top of the vacuum that has little indents on it.
You cannot do anything to bypass this problem from outside the machine.
This is not a repair that you can make yourself. You should look in your local yellow pages for Aerus (new name for electrolux) under vacuum cleaners, or go to www.aerusonline.com and find your local dealer. It is not too expensive to have fixed, it is a common issue with later model electroux vacuums.
You can try a test to see if it the valve. Remove the bag from the vacuum, look at the back of the bag holder near the motor, in the upper right or left depending on your model. You will see a very small hole 1/16 or an inch or so. Put a piece of tape of some sort to close off the hole. Replace the bag, turn on the vacuum, if it is a bad valve, the tape will override the bag full action, and the vacuum will run.
It is not advisable to run the vacuum this way since it will overheat, damage the thermostat, and can destroy the motor. A motor will cost over $200.00, the valve can be replaced for a lot less….
Posted on Jul 30, 2009
  • 430 Answers
SOURCE: electrolux canister special edition problem
If this canister has a "bag full" light and auto shutoff, there is an internal diaphragm switch controlled by a dial on top of the vac. Set the dial for medium setting. Install a fresh bag and test again.
There is a pinhole in the throat of the vac which allows air to flow through a tube to the diaphragm. Check to see that it is not blocked with a grain of sand. There is a second pin hole in the corner of the bag chamber check there as well for blockage. If this vac is less than 20 years old the control valve for the diaphragm often cracks and needs to be replaced. You would access it by peeling ( like a banana) the soft rubber bumpers off the side of the vac and sliding the locking keys underneath the bumper out the front end of the vac when the bag door is open.Then gently popping the housing apart from FRONT to back. DO NOT try to pry the back housing off. Caution, this is normally performed on a cradle in a repair shop designed to hold all the components in place
Posted on Sep 07, 2009
  • 430 Answers
SOURCE: Electrolux model 2100 shuts off with slightest suction blockage
This is exactly the symptom you would expect from a defective bag control valve. The actual control valve sits under the dial on top of the vac and often cracks internally. It can be replaced in about 15 minutes by a good tech with genuine parts from AERUS Elctrolux dealer or repair center.
You can open the vac front to rear like a **** shell by sliding the bumpers out the front with the bag door open, however you must be careful not to disturb the wiring harness and to mark wiring locations. The body must be carefully realigned for closure. If it is not perfect you will not be able to slide the bumpers back in.
Posted on Dec 17, 2009
Epic 6500 Sr. Why does it keep turning on and off?
Electrolux Epic 6500 - Bag Full Indicator Bypass - YouTube
? 0:55
https://www.youtube.com/watch?v=YrMgoUAHcI4
Jun 23, 2013 - Uploaded by easilen
The rear pops off. There's a vac. ... Yeah, keep it. Undo Close ...Electrolux Epic 6500 - Bag Full Indicator ...
Questions and Answers for Electrolux Vacuum Unit
builtinvacuum.com/help/electrolux/qanda/main-central-unit.html
For Electrolux; Central Vacuum Attachment Kits and Hose and Tool Kits for Electrolux Attachment ... With a clean bag in, the unit starts up and immediately shuts off. If you hold ... From what I have read hear, it sounds like the motor is going. ... How can I fixmy electrolux epic 6500 SR vacuum? ..... It keeps cutting off and on.
Electrolux Epic 6500 SR Shuts off when power hose ...
Dec 28, 2015 | Electrolux Vacuums
Starts but turns off immediately. red symbol lights up
check your bag for fullness, if full, change it.
if not, try adjusting your grit control on the top of the canister to the largest setting.
if your vac still shuts off, you need to replace the control valve assembly.
Aug 07, 2015 | Electrolux Epic 6500 Vacuum
I have the electrolux epic 6500 sr. when i
As hooton8 stated i have the electrolux epic 6500 sr. as well and when i attempt to vacuum i turn it on and it turns off after about 3 seconds. new bag nothing stuck in tube. I turned dial to the right all the way. Works when hose is not connected..hose is clear.
Dec 05, 2009 | Electrolux Epic 6500 Vacuum
What does the warning light with question mark mean on the Electrolux Epic 6500 SR canister?
It means to check the bag. Your bag is either missing or misaligned and has slipped past the little clear sensor or bag lockout plunger in the corner of the bag chamber at the door.
Remove the bag turn on the vac and push this switch, the vac should start when the switch is depressed. If not the internal switch inside the vac is misaligned or damaged. Please post back to confirm how you make out
Oct 13, 2009 | Electrolux Epic 6500 Vacuum
What size/model bags do I need for my Electrolux Epic 6500 SR vacuum?
You need an Electrolux Cannister bag to fit pre 2001 Series cannisters. You can fin them at a VAC Service center or thru AERUS Electrolux. Buy only a 4 ply bag, nothing thinner.
Sep 08, 2009 | Electrolux Epic 6500 Vacuum
Vacuum won't stay on
When you open the canister you eill see a little rubber hole that senses when your bag is full. This must be clogged. If you have another vac try to vacume all the dusr from this hole and any other opening inside the vacume that you can reach. I hope this helps. Don't forget to rate this answer.
Feb 07, 2009 | Electrolux Epic 6500 Vacuum
Warning Light
Check the hose and wands for a clog. Usually that light means a full bag, but a clog or restriction will also cause it to come on.
Aug 18, 2008 | Electrolux Epic 6500 Vacuum
Epic 6500 vac stopping for no reason
Could have a problem with the cord or the motor.
Apr 20, 2008 | Electrolux Epic 6500 Vacuum
Vacuums Logo
59 people viewed this question
Top Electrolux Vacuums Experts
Chris Nomland
Chris Nomland
Are you an Electrolux Vacuum Expert? Answer questions, earn points and help others
