Question about Light Outboard Motor Boat Bass Fishing Saltwater Base
How do i install this cable and is this what locks motor in up and down position
I have a 4o hp evinrude 1990 and the motor will not lock when i put in reverse the motor comes out of water . their is a cable that is called cable tilt assist. i do have elec cmc elec tilt and trim but also have a another cylinder that assist you when pulling up to mlock motor in up position but the motor will not lock in up position i think because that cable is broke whic hooks up to the levers up above to lock the motor in position in up or down position. does that cable that is broken control locking in the motor in up position and in the down position. and the model number is te-40-elesr and can anyone give me or send me in the right direction on line or where this cable hooks up at and how to install. thanks
    New Friend:
    Greenhorn:
    A rookie expert who has answered 20 questions on their first day.
  • 37 Answers
Your elec cmc elec tilt and trim will keep your motor from kicking up in reverse you must have a problem on the swivel bracket on the motor
Posted on Feb 14, 2016
  • 86 Answers
SOURCE: Motor spits and sputters
If it is old enough to have points then I would check them and make shure they are clean and gapped at .020. if that is noth the problem then it sounds like a fuel issue. Either a weak pump or a dirty carb.
Posted on Aug 06, 2009
  • 51186 Answers
SOURCE: 1991 EVINRUDE 25 HP 2CYL 2CYCLE IT RUNS ON BOTTOM
get a spark tester that has 2 leads and test spark .
Posted on Apr 26, 2010
  • 64 Answers
SOURCE: 40 hp force tilt moves up but want move down
First find the fuse box, replace any blown or incorrectly rated fuses. Inspect electrical connections at the switch and the tilt ram, repair if necessary and coat with lanolin for long protection. If it turns out to be a fuse you mite be wise to inspect the wiring for any green or black areas this can mean shorts.
I hope its easy to fix, Timo.
Posted on Apr 29, 2010
extreme7528
  • 108 Answers
SOURCE: 1964 5 1/2 hp evinrude kills at high speed
You should have a High Speed carb adjust and a Low Speed carb adjust. If it's running fine while idling, adjust the high speed setting. If you have two nobs, its the lower one. May be set wrong. If you don't have two nobs, remove the carburator and check the jets to make sure they are completely clean or better yet, order yourself a carb rebuild kit to take care of all of this. I just rebuilt my 1971 evinrude 4hp and the carb kit made the world of difference.
Posted on May 14, 2010
  • 677 Answers
SOURCE: Gear shifter locked in forward gear
If the gear lever is loose,it's the gear connection rod that you disconnect to do a g/box drop.If its not loose, drop the g/box off the leg and the first thing you find might be the problem.A loose bolt,a jammed shifter.It will probably be a connection problem than a g/box problemHope this helps
Posted on Jun 24, 2010
We replaced the water pump on a 1990 Evinrude 25 hp motor, but it isn't working. Can you help us?
It may look easy in the book but there are a few things that can go out. Such as the key/roll pin that drives the impeller can slip out on assembly. Water tube out of hole or damaged OR pieces of old impeller in it depending on why you needed to replace it. There are more but if you are not a trained tech it may be time to find one.
Nov 29, 2014 | Clymer Evinrude/Johnson 2-40 HP Outboards...
The manual tilt is locked in the up position, have been unable to lower the motor from a trailering position.
lift the engine to release weight !if siezed heat up and grease the joint till free !
Sep 04, 2013 | Seloc Marine Repair Manual...
How do i replace the water pump in a 2005 150 hp evinrude outboard motor
Take the cowling off. Also drop the foot. There wil be a stainless linkage rod that runs the length of the motor that you will have undo to drop the foot. The water impeller will be inside a stainless casing that you will have to disassemble.
Aug 17, 2012 | Boating
Thank you for your response , been going crazy here...got panel off enough to put hand in but don't know where to pull to unlock door.
Jaguar 2000-06 - Locks & Lock Systems
Power Door Locks - Removal & Installation
Door Lock Switch
Door Lock Diagnosis & Testing
  1. Visually inspect the following:
    Misaligned door(s), hood or luggage compartment lid Door latches Actuating rod Exterior door handle Interior door handle Door lock cylinder Cable Luggage compartment lid exterior release switch Fuse(s) Wiring harness Electrical connector Door lock actuator Remote transmitter batteries Vehicle battery Remote transmitter Door lock switch Front electronic module
  2. If an obvious cause for an observed or reported concern is found, correct the cause (if possible) before proceeding to the next step.
Door Lock Motor
Coupe And Convertible
  1. Turn ignition key to position II.
  2. Motor door glass to fully raised position.
  3. Turn ignition key to position O.
  4. Disconnect the negative battery cable.
  5. Remove door casing for access.
  6. Remove door water shedder.
  7. Position PVC secondary water shedder for access.
  8. Slacken and remove the door glass rear runner lower securing screws.
  9. Reposition door glass rear runner. Mark the position of the glass rear runner upper securing screw.
  10. Slacken and remove the upper securing screw and move the runner away from the glass.
  11. Disconnect door handle and lock barrel (driver door only) operating rods from latch links.
  12. Slacken and remove the three latch assembly securing screws and position latch for access.
  13. Remove latch motor harness multiplug from mounting bracket and disconnect multiplug.
  14. Release operating cable from door handle. Move inner door handle to the locked position. Remove operating cable outer abutment from support bracket. Disconnect cable inner from door inner handle.
  15. Remove lock motor assembly from door.
  16. To install, reverse removal procedure.
    Fig. Removing door lock actuator
Sedan
  1. Remove the door window glass
  2. Detach the interior door handle.
  3. Detach the actuator remote cable from the interior door handle.
  4. Remove the interior door handle.
  5. Detach the door window glass run.
  6. Remove the exterior door handle retaining screws.
  7. Remove the front door actuator retaining screws.
  8. Reposition the front door actuator and exterior handle.
  9. Remove the front door actuator and exterior handle.
  10. Disconnect the front door actuator remote cable.
  11. Detach the door lock cylinder connecting rod (1).
  12. Detach the exterior door handle connecting rod (2).
  13. Remove the front door actuator (3).
  14. To install, reverse removal procedure.
    Fig. Removing door lock motor-Sedan
Hope this helps.
Dec 31, 2010 | 2002 Jaguar X-Type
1997 Evinrude 50 HP SPL. I have removed all the bolts holding the lower rnd to the engine, it seems to be hanging up on the shify shaft, and I can't find a way to drop the unit. It drops down about...
Okay this is on total memory. The shift shaft for a lot of those engines goes right up through the pilot shaft and exits just in front of the block under the carburetor(s). You will see the **** linkage arm connected to this shaft sometimes it's double nutted. See if you can slide the lower unit back up to the housing and put a bolt in it to hold then undue the shift shaft linkage, Remove the bolt and drop the lower unit. Be careful of the water tubes and check make sure the rubber grommets are in place in the pump housing not on the tubes. Clean up the pump housing and install the new impeller kit.
Put the impeller down the shaft on top of the impeller plate, lightly grease the inside of the housing the impeller plate and impeller. Then lower the pump housing down to the impeller while turning the drive shaft clockwise lightly push down on the impeller housing. This will fold the impeller blades all in the correct position and provide lubrication to the pump until the water gets into the pump. To make life easier re-grease the drive shaft spline and the water tube grommets this will ad ease in reinstalling the lower unit. be careful to make sure you thread the drive shaft, water tubes and shift shaft all in at the same time. After installation you may find you need to adjust the **** linkage.
Dec 11, 2010 | Boating
1997 6 HP Evinrude outboard motor, ran it with out oil, locked up, need manual or help
You may have froze or locked up the motor when it went without oil. Have it checked by a trusted mechanic. Good Luck!!!
Sep 13, 2009 | Boating
1990 automatic 85,000 miles- Shifter will not stay in park and will start jumping ahead if parked on an incline. Also, when starting the car, the key stays in start position- starting the engine and...
Check the shift cable for proper adjustment. Remove the console, put shift selector in N (make sure wheels are blocked), remove lock pin from cable adjuster, check that the hole in the adjuster is perfectly in line with the hole in the shift cable. (there are 2 holes in the end of the shift cable positioned 90degrees apart to allow for 1/4 turn adjustments) If not perfectly aligned, loosen the lock nut on the shift cable and adjust as necessary. Tighten the lock nut and install the lock pin in the adjuster. If the lock pin feels like it's binding when being installed, it's still out of adjustment and must be adjusted again.
The key staying in the start position: try spraying wd-40 or similar lubricant into key hole, if condition is the same, you will need to change the key ignition assembly, as it is worn out,
Aug 04, 2009 | 1990 Honda Accord
Need wireing digram for 40hp evinrude boat with elc st
Check out the online info on this site, or on the search window type in 40 hp evinrude wiring diagram and go from there.
Jun 08, 2009 | Boating
Light Outboard Motor Boat Bass Fishing Saltwater  Base Logo
55 people viewed this question
Top Light Boating Experts
ray gallant
fordexpert
Ian Summerfield
Ian Summerfield
Are you a Light Boating Expert? Answer questions, earn points and help others
