Question about Electrical Supplies
How can i get a sv150 sume-c-linhai engine for a challenge xtreme push lawn mower
  • 45 Answers
SOURCE: lawn mower wont start possibly flooded the engine
make sure you have a good clean and dry spark plug
Posted on Apr 29, 2009
nobby63
  • 10 Answers
SOURCE: lawn mower stalls when engine is hot
first thing is to check that plug is not fowling up when hot due to motor burning to much oil.
Posted on Jul 26, 2009
  • 9 Answers
SOURCE: lawn mower engine shuts off after about 15 secs of starting.
Possible solutions:
-Water or trash (or both) is in the gas tank which means you must empty all gas from the tank and refill with fresh gas. The carb. will need to have all old gas removed too. If this is the case you will want to empty your gas can too because it may be the source of the water/trash.
-Replace the priming bulb.
Posted on Jul 29, 2009
  • 110 Answers
SOURCE: lawn mower keeps dying
Remove gas cap. If mower now runs without stalling, your problem is the vent in the gas cap is blocked. Replace the cap. Common problem!
Posted on Sep 22, 2009
Edvais
  • 6 Answers
SOURCE: Can't push my self propelled lawn mower!
Remove the drive wheels and have a look at the gear teeth in them. If even slightly worn, they need replacing. If you run the mower with the wheels off, that end elevated with a block, see if the axle turns when you engage the drive. If it does, your transmission is fine. Wheels are a lot easier to change than a tranny.
Posted on Oct 01, 2009
What engine is employed on challenge xtreme 3.5 H.P. mower
most likely something chinese. you have it there? look for markings
Nov 23, 2017 | Garden
What's the valve gap set on a yard machine 139 ohv mtd push mower
3 to 5 thousandths of an inch on a cold engine.
Search Results
Lawn Mower Repair Valve Adjustment - YouTube
? 4:44
https://www.youtube.com/watch?v=NjzX-PUjKmo Mar 7, 2008 - Uploaded by IFIXIT4U
In this video I will show you how to adjust the valves on a Briggs OHV engine. The valves need to be ...
? 5:06
https://www.youtube.com/watch?v=j77Y5iwXTzg Mar 6, 2008 - Uploaded by IFIXIT4U
In this video I will show you how to adjust the valves on an overhead valve lawn mower engine. The valves ...
How to Adjust The Valves On An OHV Lawn Mower Engine ' Hunker
https://www.hunker.com > Home Hacks & Answers > Garden & Lawn > Lawn Mowers Sep 19, 2009 - How to Adjust The Valves On An OHV Lawn Mower Engine. By Lisa ... Many lawn mower engines use overhead valves. This means, the ... Turn the screwdriver to either increase or reduce the clearance between the setscrew and the top of the valve. Tighten ... Will Mothballs Keep Snakes Out of the Yard?
valve gap set on yard machine 139 ohv mtd push mower Google Search
Aug 14, 2017 | Mtd Garden
Speed of the lawn mower governor is missadjusted
The engine revs are turned down to make the machine noise compliant, increasing the revs will greatly increase the noise, the engine revs shouold not realy be increased, however a dealer with a suitable engine taco may do it for you, it is very important not too over speed the engine or it will self destruct,
Apr 11, 2013 | Tecumseh Lawn Boy Push Mowers Insight...
How to start challenge xtreme petrol lawnmower
This mower in nigh on impossible to start, having had a Briggs and Stratton previously the xtreme isn't fit for purpose. I bought brand new one 2 weeks ago and the only way it would start ( after 20 attempts, no exaggeration ) was to swap the spark plug with my old B&S. It's very prone to flooding, as it fails to start everytime y pull the cord with the throttle open it's pumping more fuel in. I'm taking it back tomorrow, managed to cut the grass twice and now refuses to start at all, Advise yu to avoid at all costs.
Apr 06, 2013 | Garden
Does a 23 horse kawasaki lawn engine have a timing chain? what would cause a bent push rod
a lot of the over head valve engines run into this carbon build up on the valve stem will bend a push rod
Jul 08, 2012 | kawasaki Fh680vgs24 23hp 23 Hp Lawn Mower...
How do i change wheel height on lawn mower
You do not change the wheel height, you change the cutter height,there should be an arm sticking up neart he rear wheel, you just push it to the side a little and push it either forward or backward.
Hope this helps
Apr 29, 2009 | Garden
Sovereign SLM 1500 lawn mower blades have stopped turning
The belts are available part number is SV150. Call ALM Manufacturing 01423 797208 for advice/stockists.
Apr 13, 2009 | Garden
Electrical Supplies Logo
22 people viewed this question
Top Electrical Supplies Experts
Craig Butler
Craig Butler
Steve
Gene Haynes
Are you an Electrical Supply Expert? Answer questions, earn points and help others
