Question about Miele Ovens
Power panel flashes time unable to hold reset
Time started auto and flash. Would not hold reset even after pressing the manual hand. Turned off at power board thinking would just turn on to use but then resumes flashing and oven won't hear,. Fluked time reset and oven functioned but soon reverted to same problem
vest6
  • 196 Answers
SOURCE: "Door Locked" flashing on GE Oven JTP15 - can't unlock
The problem may very well be in one of the micro switches on the self cleaning motor bracket. These switches control the electrical flow to the heating elements. In the owners manual there is/should be a chart that lists the unlock and safety combinations. This would be your best source of information.
Posted on Jan 26, 2008
  • 1462 Answers
SOURCE: neff oven won't work after a power cut
you need to reset clock - get your book out and it gives instructions
Posted on Oct 08, 2008
  • 4 Answers
SOURCE: Main oven won't turn on
I'm figuring you've probably resolved this, since you posted in November (and I've just joined the site today). However, I thought I'd post a solution just in case anyone else surfs in and finds the same problem.
We have the same sort of oven. After the power has been off, the oven won't work until you set the time on the clock. I think it's because of all the automatic timer features.
On ours, you have to press the two buttons with arrows on at the same time as turning the clock dial to change the time.
Good luck.
Posted on Jan 07, 2009
SOURCE: Baumatic Oven - Setting the Clock/timer after power has been off.
Hi, You press the second and third button in together, hold them in and use the + or - buttons to set the time.
Posted on Jan 03, 2010
SOURCE: Kleenmaid Scala Oven. My oven will not turn on.
I had exactly the same problem. I followed the directions to reset the clock. That is the cooking button and finish cooking button. They look like a caserole dish and a casserole dish with a cross through it. Hold them down at the same time and the + and - button to advance the time. Be aware I had to try this a few times before it worked. Hope this helps, Dean
Posted on May 14, 2010
BO6255SS - The clock turns on but we are unable to set it and therefore cannot turn it on. Can you help?
this is as much as the manual says
After your appliance is connected to your mains supply for the
first time, the numbers on the timer display will flash. Before
you can select a cooking function or set a temperature, you
must set the appliance into manual operation mode.
o To select manual operation mode, press the manual operation
button (9) on the control panel.
http://www.manualslib.com/manual/956107/Baumatic-Bo625ss.html?page=3#manual
Jun 02, 2016 | Baumatic Ovens
Beko built in double oven alarm after power outage
Switch oven on using the function knob (first knob on left hand side)then press and hold(for 3 to 5 seconds) the left top button right next to the display screen this should give you a chance to set the current time on the oven after setting the current time switch oven off at function knob and on agian problem should be solved
Jul 05, 2015 | Ovens
The ovens on my Indesit FIU20I cooker won't heat; the display is flashing and the manual says to reset the clock but I can't... apparently if the automatic cooking function has been selected you canno
Does the "manual" button not do anything in this state?
Have you tried this sequence?:
SETTING THE TIME OF DAY
Step 1 Make sure all oven controls are turned Off.
Step 2 Check the electricity supply to the cooker is turned on.
Step 3 When switched on the display will show 0.00 and the Auto symbol,
flashing intermittently.
Step 4 Press & hold in both the Cook Period & End Time buttons together.
Step 5 With the Cook Period & End Time buttons still held in, press either the "+"
or "-" buttons to set the correct time of day.
Step 6 Release all the buttons simultaneously.
Oct 30, 2014 | Ovens
My Blanco oven will not work. Display shows 0:00 'auto' flashing. Cooktop works fine. I have checked the manual but it was of no help. Model number is BF95W. Tried turning off/on at power. This did...
Hi You need to set your clock If it is a digital timer you usually have to press 2 of the buttons on the bottom and once you see a change in the clock (usually it stops flashing) press the up or down button to set the time once the time is set you may need to push the manual button sometimes this button is identified by a hand regards Geoff Stove Recyclers WA
May 29, 2011 | Ovens
How do you reset the clock on a Diplomat HJA 3300 oven? Would you by any chance have a pdf of the manual?
Press and hold the timer and casserole symbol buttons at the same time then press or - to set the time. If "auto" flashes you will have to cancel that programme.
Feb 25, 2011 | Ovens
Defy thermofan flashing 0.00 and auto. I've tried pressing key 4
Hi
Can somebody please help
Thanks Terry
Jun 01, 2010 | Ovens
Creda europa solar plus double oven
Hi, hold down the minute and cook button and at the same time hit either the plus or 1 button to set a time and then oven will work. each time the power is off this needs to be done. hope this helps
Dec 02, 2008 | Ovens
Smeg oven SA392EB cannot reset clock
Turn off at mains, turn on again. 0:00 will flash press the manual op key ( on mine button on right) use +/- keys to set the time. Don't use buttons with wavy lines as they are for setting auto cooking time.
Oct 31, 2008 | Smeg SE399X/5 Stainless Steel Electric...
Automatic button on lower oven
This is how I reset my U1420NOGB/FD7907 NEFF double electric oven that I inherited also without an instruction book.
There are 4 buttons in a row and then a timer knob that moves left and right.The first button is black,second has an arrow,,third has an arrow and fourth a hand symbol on it.Hold down together, the black button and the arrow button next to it.Without releasing either,twist the timer knob clockwise(to the right)until correct time is showing.Do not release the other buttons at all ,until time is ok.If you miss correct time keep going ,dont go backwards.When time is correct,,release black and arrow buttons and auto will stop flashng ,and oven work.If auto doesn,t stop flashing at this point press the button with hand symbol (manual)on it once.
Aug 27, 2008 | Ovens
Belling synergie. oven does not heat up. grill ok. think i need to set to manual but how???
if its flashing auto.
Press and hold the 2 buttons on the left hand - clock and cook time and then press the + button.
This then sets the time to allow manual and takes the auto off.
cheers
will
Dec 24, 2007 | Belling XOU592 / XOU593 Electric Double...
Ovens Logo
16 people viewed this question
Top Miele Ovens Experts
Paul Bade
Dan Webster
Dan Webster
John
Are you a Miele Oven Expert? Answer questions, earn points and help others
