Question about GE Monogram Side by Side Refrigerator
Half the lights stopped working ? led?
SOURCE: need to find model # for ge monogram 42" side-by-side (1992?)
on the 42" Monograms the Model & serial nomenclature are usually located behind the top panel in the center section to the right of the compressor panel. Hope this helps....Bill
Posted on May 18, 2009
SOURCE: 42'' monogram getting very hot between doors and in unit above
This is typical for frost-free refridgerators/freezers. In order to keep ice from buiding up on the interior walls of the freezer section, the manufacturer installs electric defrosting elements and extra "warming" elements in the outer edges of the cabinet, normally around the door openings to help mitigate any frost/ice build up and surface condensation that typically occurs on the exterior surfaces as the doors are opened and closed frequently.
These edge warmers stay very warm to keep ice and condensation from accumulating and will become VERY very warm (hot) when the fridge/freezer is in the once a day defrost cycle.
Unless you have an energy saver switch (GE trademark) inside the fridge section, which you can turn off, there is no way to disable these added elements. If you find that you're getting ice building up in the freezer, you'll need to turn off the energy saver switch to resolve that issue.
Energy Saver switch "ON" means these elements are off, while having the ES switch "OFF" means those heaters are running all the time and costing you more in energy consumption
Posted on Jul 13, 2009
SOURCE: red door spring GE monogram fridge side door
Spring closure part # WR2X8916 from Sears Parts.
Posted on Aug 19, 2009
SOURCE: 42" Built-in Monogram Refrigerator just lost power.
Check the Compressor starter. This is a black box on the top of the compressor. See if it is getting any power, also with a flash light you will be able to see if it is burnt it looks like a BIG fuse. If it is popped you will need to replace it then all will work ok after that
Posted on Jan 03, 2010
What is the model number of your unit?
Posted on Nov 18, 2012
Jan 11, 2016 | LG 42LS5700 42 Inch 1080p 120Hz Smart TV...
Mar 06, 2014 | GE Monogram ZISS420NRSS 42" Built-In...
Apr 09, 2013 | GE Monogram ZISx420DR 42-inch Side by Side...
Nov 18, 2012 | GE Monogram ZISx420DR 42-inch Side by Side...
Jun 15, 2010 | GE Monogram ZISx420DR 42-inch Side by Side...
Jan 03, 2010 | GE Monogram ZISS420NRSS 42" Built-In...
Jun 29, 2009 | GE Monogram ZISS420NRSS 42" Built-In...
Jan 20, 2018 | GE Monogram ZISx420DR 42-inch Side by Side...
Jul 17, 2008 | GE Monogram ZISx420DR 42-inch Side by Side...
Jun 23, 2008 | GE Monogram ZISS420NRSS 42" Built-In...
