Question about Music
Fender squier serial numbers CXS 090874990 YEAR MODEL SQUIER STRAT?
  • 5603 Answers
SOURCE: I have a Fender Squier Strat. The Whammy bar is
There are MANY tricks to remove a threaded piece like this:
1. With a Dremel tool and a cutoff carborumdum disc cut a shallow slot in the remaining piece and use a straight bladed screw driver to remove. This can only be done if the screw is above or flush with the surface.
2. Carefully drill a small hole in the piece fairly well centered. Use an "EasyOut" to remove the broken part.
3. Carefully drill several small shallow holes on the top of the broken part in a line so as to form a slot for a screwdriver.
4. Carefully drill a hole JUST the right size into the broken part and then drive an Allen wrench into the hole to turn the broken part. The hole has to be just the right size so the wrench can peal tiny pieces off to grab the broken part.. this is tricky to get the size just right.
5. Use a detist drill to cut a slot.
In all these use a penetrating oil or CRC226 to make it easier to turn.
Posted on Mar 09, 2010
albert_turne
SOURCE: Looking for year and value on a Fender
GET ID CALLER ON LG HBS 730
Posted on Apr 21, 2014
  • 37 Answers
The easiest remedy is to buy and install a used Squier tremolo (trem) block - they are very cheap and unscrewing the bridge is less work than trying to remove a broken threaded rod from a tight and barely accessible space. If you want to increase the sustain and have a more responsive tremolo, replace the small alloy block with a solid steel block or a brass block. They aren't that much but the sustain difference is worth every penny.
Posted on Feb 02, 2015
  • 37 Answers
That "Strat" is a "Tele", or at least the neck is. The Squier serial numbers have one or two letters followed by numbers; the first number is the year, as in CY9XXXX is a 1999 model.
Posted on Mar 03, 2015
fred_license
  • 350 Answers
SOURCE: What year and model is my fender squier sn.CCA-0020707453 model # 093-0300-149. Howmuch is it worth? Excellent condition.
Try this site, they have a lot of serial number info...
http://www.guitarrepairbench.com/guitar-dating/fender-serial-number.html
Typically a Squire guitar is worth around $100 less for a used one...
Hope this helps?
Posted on Mar 17, 2015
S919585 WHAT YEAR IS THIS SQUIER STRAT KOREAN? THANKS
That number does not match a Korean made guitar as is. If it had one more digit however it would be Korean made in 1989 or 1990.
It does match a Squier made at the Fuji-gen Plant (for Fender Japan), Japan in 1994 - 1995.
Mar 23, 2017 | Squier Music
Hi..my fender squier serial is s/n CY21210714....do you know the year and price of the guitar?
The "CY" means that is was build in China by Yako. However the first 2 numbers indicate year made,but 21 doesn't fit the form.Double check those first 2 numbers. Is it a Strat or Telecaster.Either way most Chinese Squires go for $130-$200 ish.
Aug 12, 2015 | Fender Music
Fender Squier Strat Serial #cxs 051209847
Made in China by Axl, 2005 it looks like.
Oct 13, 2014 | Fender Music
I have a Fender Squier Stratocaster Standard HSS. Serial number: ic071104059. i am trying to determine the year and specifications
It was made in 2007. If you call Fender directly they can sometimes id the exact model version from the serial number. The records they keep on Squier guitars is a bit sketchy, but sometimes they can help.
Oct 11, 2014 | Music
Fender strat s/n CY04098713 what year was it made and value
According to my Squier book it is Chinese Squier Strat made in 2004-2005.
Oct 04, 2014 | Music
I have a fender strat with serial number snic9055475 can you tell me if it is authentic or where it was made
It is an Indonesian made Squier from 1990. It's doubtful anyone would fake an Indonesian made Squier.
Sep 28, 2014 | Fender Music
According to my Squier book the IC prefix is Indonesia and the first two numbers are the year of production. So it seems to be a 2000 or 2001.
Aug 14, 2014 | Fender Musical Instruments Corporation...
Music Logo
43 people viewed this question
Top Music Experts
Michial Gueffroy
Vito Vacirca Jr.
Are you a Music Expert? Answer questions, earn points and help others
