Question about Maytag Washing Machines
What does error code E01 F02 mean?
Maxima front loader
  • 1314 Answers
SOURCE: HE4t Elite F02 error code
its the error code for a long drain time most likely you need to check the filter in your pump for obstructions First if you have a wet vac pull the drain hose out of the drain spout and use the vac to pull the water out of the washer through the drain hose.If not you will need a pair of radiator hose clamps from the auto parts store. Pull the screws from the lower panel at the front of the washer and remove it.in side you will see a rubber hose coming down from the tub to the drain pump. Put the radiator hose clamp there if you didn't have a shop vac.On the front of the pump is a round part with a handle turn that and remove the pump filter .Clean any foreign objects out of the pump and look inside the pump to make sure no impeller blades are broken if any are you will have to replace the pump. put the filter back in and tighten it. If you had to use the hose clamp remove it now.reassemble and don't forget to give the tech his four boxes if this fixes it
Posted on Jan 25, 2008
SOURCE: Error Msg F02
Had the F02 error as well. Thanks to all great posts here, esp. colonel rick, catriver and bullfrog7. Use a Torx (star) screwdriver to get the three screws off the bottom of the front plate (I dropped a screw, so was glad I had a magnetic reach tool). I saw the trap, and began to unscrew, and water started pouring, so I immediately re-closed. THE WATER IS AN ISSUE, SO BE PREPARED. Big problem for me was I had the drawer unit beneath (water leaking through ... messy). Grabbed a few towels, but then took bullfrog7's idea of the shop vac. Sucked what I could out of the drum (had a load going before the error), Then I unscrewed the front screw from the trap, and slid the trap unit forward (be careful of the wiring harness unit). This enabled me to pour water from the trap into a mop bucket. I then used the vac to **** what I could from the drain pipe. Our trap had 3 baby socks and untold lint. Washed the trap, put it back together, and voila! No issues. If I can do this, you can too!
Posted on Aug 19, 2008
taran_2005
  • 10515 Answers
SOURCE: Tromm LG front loader error code
Already answered by an expert :-
This a common problem for all front loaders. Your washer will not drain or work 'cause your outlet filter is clogged or an unusually heavy load. The small door is on the left side front bottom of your washer. Remove the door with a putty knife or thin butter knife inserted in the middle top of the access panel door. Drain the water from the filter housing by pulling the tube out of the clip and unplugging, allow it to run into a bucket while the machine is in spin only mode. This mode is acheived when the washer is first powered on press the spin button until no spin is reached then run. Run in this mode until no water is draining from the tube in the bucket. Keep the tube as low as possible. When water has stopped coming out of the tube turn off the washer and unplug from the wall. This step is important because this resets the fault. Expect some water to come out when you open the filter housing by turning counterclockwise until you can pull the filter from its housing. Clean out your filter, return to housing turning clockwise until seated and recap the tube and place in the holder, refit the cover and plug back into the wall. Fixed. You may also need to lighten the load a bit but I always try full on load anyways. If it fails again just lighten, unplug wait >1 minute then replug and run.
Thanks.
Posted on Jun 17, 2009
  • 177 Answers
SOURCE: miele front loader washing machine W3275- error co...
hi,
this is a tachogenerator fault or the drive motor brushes are faulty. you will need a Miele service tech or a Miele service agent to look at this.
Posted on May 24, 2010
  • 1382 Answers
SOURCE: error code F02 on Whirlpool Duet front loader
Press PAUSE/CANCEL twice to clear the display.
* Check the drain hose and make sure it is not plugged or kinked.
* Check the electrical connections at the pump and make sure the pump is running.
* Check the drain pump filter for foreign objects.
* If the above does not correct the problem, replace the pump.
Thank you !!
Posted on Jun 22, 2010
Washer error F06 E01
The error codes F6 E1 for Maytag Maxima 6000 front load washer means that the MCU AND CCU are not communicating. You need to check the wiring and plugs to make sure they have a good connection.
Feb 10, 2015 | Maytag Washing Machines
On a whirlpool duet front loader dryer error code F 70 and F 02 appear what does F 02 mean?
F02 is a long drain error, you may have a clogged pump or a kinked/clogged drain hose
Nov 04, 2014 | Washing Machines
Water will not enter drum
not sure bout ur error code but would check the water inlet valve and the water pressure switch
Sep 28, 2014 | Maytag MHW6000XG Maxima High-Efficiency...
Error code f09 e01
Did you clean the tube that goes from the tub to the drain filter then the drain pump it is behind the front panel also make sure there is nothing in the drain pump stopping the impeller from turning.
Jan 29, 2014 | Maytag MHW6000XG Maxima High-Efficiency...
Getting E02 and F09 error codes on my Maytag Maxima MHW6000XW front load washer
Here is the manual. Hope it helps: http://www.applianceblog.com/mainforums/attachment.php?s=001fc13abc99c02a4aa812a23c01ac7e&attachmentid=13030&d=1381289434
Jan 05, 2014 | Maytag MHW6000XW - MaximaTM...
Bosch vision error code E01 on washer
error code e01 means the computer thinks the door is open even when it's closed you can repair this using this guide:
Bosch Front Load Washer Error E01
Aug 23, 2013 | Bosch WFVC5440UC Washer
Whirlpool front loader duet hd washer gets stuck in the wash cycle with the error code of F02. What is F02 mean?
Whirlpool Duet front-load washer F02 usually means it is taking over 8 minutes for the washer to sense that the rinse or wash water has drained, which either means that the drain/filter is clogged or the pressure switch/tube is clogged (causing both the washer to over-fill with water and not sensing that water has drained).
To clear out the drain/filter, tilt the washer backwards a little for easier to the kick-plate and support the front bottom with a wood block or similar, remove the front kick-plate's (3) retaining screws and swing the kick-plate up out of the way. The filter drain is behind the white knob in the center, be prepared with something to catch any remaining water and lots of towels to soak up any spills, and turn the knob counter-clockwise to remove the filter.
Jan 11, 2013 | Whirlpool Duet GHW9150P Front Load Washer
Maytag washer throwing fault code 21
An "F21" or "F02" error code is indicative of a slow draining cycle, normally caused by a clogged or kinked drain hose. If an "F21" or "F02" error code appears, check the drain hose on the back of your washer to ensure that it is not clogged or bent. Once the drain hose has been unblocked, the error code should disappear and the machine drain properly. However, if you have a high efficiency washing machine and the error code continues to appear, make sure you are using the correct detergent; because high efficiency machines use much less water than traditional washing machines, they require the use of a low sudsing detergent. Traditional detergents may produce too many suds, which can block the machine's drain hose and lead to slower draining cycles.
May 20, 2012 | Maytag Washing Machines
Washing Machines Logo
41 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
