Question about Craftsman 17.5 hp 42 in. Deck Lawn Tractor - CA Model
Where does the extension spring goes. I got one of the hook connected to the center idler bracket. but I don't know where the other end go to
2 Suggested Answers
SOURCE: Broken manual clutch cable
You can go to www.Searspartsdirect.com and put you units model number in and order the cable yourself. They can ship it right to your house and you can swap the cable yourself with just simple hand tools.
You can see the details on the idler attachment in the parts schematic when you are ordering your new cable.
Good luck and be careful!
Posted on Jul 19, 2010
Testimonial: "Instead of ordering a new cable I fixed the spring with broken hook by inserting a wood bushing in the spring, added a 3/8 in bolt and bracket to idle"
I changed the belts and a spring fell off the top pulley, where dos it go
Hi Cookie:
The spring will probably attach to the bracket that holds the idler pulley against the belt. With the engine off, have someone move the control levers. Watch to see which pulley moves back and forth. That one should have a hole in the mounting bracket that the spring will hook into, and the other end of the spring will hook into another hole or notch.
Patience...... You'll find it.
May 25, 2015 | Garden
Clutch cable installation
  • Put your mower in the lowest position and open the hood.
  • 2 Lift up the retainer spring that holds the clutch cable to the adjustment bracket. Pull the cable out of the bracket.
  • 3 Remove the clutch cable spring from the idler bracket. Pry the spring open with a pair of pliers if necessary.
  • 4 Hook a new clutch cable spring over the idler bracket and squeeze it closed.
  • 5 Slip the clutch cable under the retainer spring.
May 04, 2013 | Husqvarna Garden
Re~attaching spring on Maytag Dryer PYE2300AYW While replacing the belt the spring slipped off and I don't know where to attach it to, one end is on the idler, where does the other end go?
If I am not mistaken, your spring called a Idler spring should mount to the motor mount and the other end to the idler arm. But if you do not remove the drum from the dryer it will be hard to see how to re-install the spring. Remove the drum to make your task easier for your self.
Good Luck
Oct 11, 2011 | Maytag PYE2300AY Electric Dryer
609 yard machine tractor idler pulley spring broke
Here's a diagram, not a great copy, but it may help:
The spring hooks to the idler arm on the opposite end from where the pulley is mounted. The other end of the spring looks like it hooks to a raised tab on the deck, straight behind the left mower spindle. Hope this helps you, please rate my solution if so, thanks!
Jun 08, 2010 | Mtd Garden
Simplicity snowblower auger idler tension
CAN YOU CALL THE MAKER OF THAT UNIT
Jan 08, 2010 | Garden
Not sure how to replace the idler slide assembly. what i need to know is where to place it when i replace the belt.
I know it isn't much help but look for wear on the idler arm bracket, it will tell you which way it faces either up or down....then look for wear where the idler arm bracket hooks to the frame of the dryer....also you will look to where the spring attaches to the frame of the dryer when you attach it to the idler arm there will be a slight amount of wear where the spring attaches to the frame....
I will include these two websites for parts and further help:
http://www.partselect.com/
http://www.appliancepartspros.com/index.aspx
Both also have chat assistance 24/7.
Good luck,
I hope this helps
Nov 12, 2009 | Whirlpool LGR6611L Gas Dryer
We are having a problem getting the belt back on as it appears slack can you offer any suggestions. Zanussi Condensordryer Dual Temperature. TC7102W.
I will suggest that you put the belt on the motor first, then route it around the idler arm pulley, then place over the drum.
Look on the frame of the dryer for an indication of wear where the idler arm bracket fit, also there should be a spring attached to the idler arm bracket. Once you have the idler arm bracket in place, hook the spring to it and see where it will fit on the frame. There should be also an indication of wear where the spring fit...look very closely because the wear may be very minimal.
I will include two websites for further help, they have chat assistants 24/7.
Good Luck,
I hope this helps.
Nov 04, 2009 | Zanussi TD4100W Electric Dryer
I have a Maytag performa dryer and the idler pulley came off and i need to know where to attach the spring that it has back to.
Make sure the idler arm with pulley is in the right location and then hook the spring into the idler arm bracket, then look for where the spring might have been attached on the frame of the machine within the limits of a stretched spring.
I will also send you a website that may help you, they have schematics of dryers and it may give you some help.
http://www.partselect.com/ if not then try this one.
Good luck,
I hope this helps
Oct 13, 2009 | Maytag Dryers
Where does the manual clutch cable mower deck spring connect to on a Craftsman YS4500?
It should connect on top of the idler pulley on the idler arm. The bolt is extended and the spring hooks over it with a 'hairpin' or cotter key through the hole in the end to hold it on.
Oct 09, 2009 | Craftsman 21 Hp 42" Deck, Ys 4500 Lawn...
Spring not connected behind bobbin casing
It is most likely the feed dog return spring. A cam lifts the feed dogs up and the spring pulls them back down. It hooks to the feed dogs bracket and goes straight down to the machine frame, there should be a small hook or post for it. You may be able to sew slowly without it attached.
good luck!
Nov 24, 2008 | Brother XL-5130 Mechanical Sewing Machine
Craftsman 17.5 hp 42 in. Deck Lawn Tractor - CA Model Logo
18 people viewed this question
Top Craftsman Garden Experts
Dean Gruber
Roland W VanLue
Roland W VanLue
Dennis Key
Dennis Key
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
