Question about Frigidaire 7.0 CuFt Front Load Electric Dryer - FARE1011MW
How do i raise the top? - Frigidaire 7.0 CuFt Front Load Electric Dryer - FARE1011MW
  • Frigidaire Master
  • 5,323 Answers
See pics if its like this model
how do i raise the top? - 24437704-vy3qd1rc3oikbunb5kfp1hkm-3-0.jpg OR IF ITS THIS KIND?
Posted on May 15, 2015
2002 chrysler sebring convert. top can't be raised when down
Disconnect the Motor, Raise it manually.
You are going to have to repair / replace your motor
Apr 09, 2013 | Depo Auto Parts Chrysler Sebring...
Tip
How to fix mini Cooper convertible top after battery change
After a dead battery or a battery change the mini can "forget" the positions of the windows and flash an error code when attempting to raise or lower the top. The fix is to raise and lower the windows completely and then the top will raise and lower normally.
on Sep 11, 2010 | Mini Cooper Cars & Trucks
Top worked fine yesterday but today tried to let down only clicked
It is a hydraulic pump that applies pressure to the 2 hydraulic pistons to raise & lower the top. So, check for something obstructing movement first.
The convertible top:
  • is motor-driven.
  • requires parking brake engaged to complete circuit for operation.
  • is equipped with a back window glass (42006) . The back window glass is permanently attached to the folding top back window curtain (52500) and cannot be opened.
VISUAL INSPECTION CHART Mechanical Electrical
  • Damaged fluid reservoir.
  • Damaged folding top hydraulic cylinders .
  • Damaged folding top motor upper and lower hose .
  • Damaged convertible top regulator.
  • Parking brake not engaged.
  • Open power distribution box circuit breaker CONV TOP (30A), fuse junction panel Fuse 1 (15A).
  • Circuitry open/shorted.
  • Damaged convertible top switch.
  • Damaged raise/lower relay .
  • Damaged folding top hydraulic lift motor and plate kit .
  • Convertible Top Does Not Raise/Lower
  • Open circuit breaker or fuse.
  • Damaged folding top switch.
Jun 29, 2011 | 1998 Ford Mustang
Schwinn Impact MOS.....can the handle bars be raised? If so, do you loosen the small star nut on top, or the large nut at the base of the handle bars?
In order to raise the handle bars, you will need a hex key. Put it into the hex indentation at the top. Turn it left to loosen it. Then raise the handle bars to the desired height.
May 22, 2010 | Cycling
Maytag PYE2300 AZE electric dryer
Unplug the cord of the dryer before starting.
Raise top by placing a putty knife between top and front in the seam between the two about 2 inches in from each edge and lifting up at the same time. Raise top to full open position.
Look down inside the open top dryer at each side there will be a screw on each side a few inches down. Leaning against the front remove the two screw and pull the top forward a few inches and raise it from the supports at bottom then swing it aside protecting any wiring.
This will give you access to the underside of the dryer.
Reverse the disassembly process to reassemble the front and top being careful not to disconnect any wiring.
Sep 19, 2009 | Maytag Dryers
2005 PT convertible top won't raise - can top be manually raised?
Check your manual for the location of the top fuse.
Your car left the factory as a hardtop and was converted to a soft top by a Chrysler authorized company so the top fuse(s) may not be with the other fuses.
Karl at topgunwon.com
Jul 25, 2009 | 2000 Ford Mustang
1996 BMW E36 Convertible to stopped working.
Change switch first checking all contacts(wires to clips)
Jun 25, 2009 | BMW 318 Cars & Trucks
1999 Mustang convertible top won't raise....
There is a fuse No.20 (15amp) in the under dash fuse panel and a 25amp circuit breaker in the under hood fuse panel that controls the top.
Jun 16, 2009 | 1999 Ford Mustang Cobra
The convertible top will not go up or down, although it sounds as if it wants to. Is there a way to manually raise/lower the convertible top?
There are 2 hydrolic rams that raise and lower your roof. You can just disconect them from the top, then manualy raise and lower the top. But it sounds more like your fluid level is low. Open your trunk and find the pump pull the plug and fill the resiorvor.
Apr 27, 2009 | 1999 Chrysler Sebring
2008 Pontiac G6 Convertible retractable top won't work
2007 Pontiac G6 retractable top engine swithed off while raising, top continued to close in compartment right side upper forward pad looking thing popped and the compartment would not close, however the top will raise and go back in place, cannot leave top in compartment since the trunk lid will not close over the stored top..........
Apr 25, 2009 | 2008 Pontiac G6 Sedan
Frigidaire 7.0 CuFt Front Load Electric Dryer - FARE1011MW Logo
27 people viewed this question
Top Frigidaire Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
