Question about Kyocera Mita Office Equipment & Supplies
How can I fix error code C0620 for a Kyocera Mita KM2530
4 Suggested Answers
bolinlamar
  • 157 Answers
SOURCE: kyocera mita j11 error code
On most Kyocera Mita copiers a J-11 code indicates a possible paper jam when paper is being fed from drawer #1, but sometimes a J-11 will be indicated when the paper fails to feed from the drawer. Check the paper stops and paper guides in the drawer and make sure that they are flush against the paper, also cleaning the paper feed and pick-up rollers with a rag dampened with just plain water will help sometimes unless the rollers are completely worn out. If all this doesn't help you may have a paper feed clutch or lift motor that has failed.
Posted on Sep 18, 2009
SOURCE: How to fix Error code C6020
I have The Km C2520 with the same C6020 code. Is the solution the same?
Posted on Apr 24, 2010
SOURCE: how do you reset a C6000 error on a Kyocera Mita
it is a error on your heater unit. it sometimes comes with power fluctuation. you need to enter service mode, it is a dangerous place to be if you do not know about copiers and their settings and i advice you to rather get a trained tech to do it for you.
to reset this error, do the following, but please take care and DON'T fiddle around.
type in 10871087
the machine will display U000 and be in maint. mode
type in 163 (this is the code to reset the error)
press ok/print
on some models it ask for "execute", select it if neede
the machine will now restart and be ok
** if however the machine restart and the error occure again, there is a deeper problem that need to be attended by a trained tech
Posted on Jan 19, 2011
Error code c6020
you need to reset the fixing unit. go to mode and input 163 then start off then on.
Feb 28, 2014 | Kyocera Mita Office Equipment & Supplies
Kyocera mita km2530 paper misfeed jam00
This usually means that no paper has been fed from the paper cassette or the machine was turned off when you had a paper jam.
Remove the paper cassette from the machine and ensure that nothing is stopping the paper from feeding.Also look into where the machine locates in the copier to ensure that no paper is jammed behind the cassette.
The paper feed rollers may need cleaning or replacing.
Jan 03, 2012 | Kyocera Mita KM-2530 Laser Printer
How do you reset a C6000 error on a Kyocera Mita KM2530?
type in 10871087
press ok/print
Jan 06, 2011 | Kyocera Mita KM-2530 Laser Printer
Jan 26, 2010 | Kyocera Mita KM-1815 All-In-One Laser...
Kyocera mita j11 error code
Sep 18, 2009 | Kyocera Mita Office Equipment & Supplies
Our Kyocera KM2530 has previously been set up to scan to three separate pcs on the network. Nothing has changed yet it will now only scan to one. How can I fix this problem?
the ip address for the other two computers might have changed... you need to go into the scanner via the IP address of the scanner and change the IP address for the scan to pc folders destination list to the new one for both computers... or change the ip address to the pc name... pc name may work... but IP address will...
Jun 30, 2009 | Kyocera Mita KM-2530 Laser Printer
Error code 260 for a MITA DC 6090
its a problem in your cooling and drive system... consult kyocera for an explanation of this code...
Mar 15, 2009 | Kyocera Mita Kyocera-Mita SCANNER RACK...
138 people viewed this question
Top Kyocera Mita Office Equipment & Supplies Experts
Kyocera HP Expert
Henry Gertcher
Are you a Kyocera Mita Office Equipment and Supply Expert? Answer questions, earn points and help others
