Question about Malibu Intermatic Inc. ML121RT Low Voltage 121-Watt Power Pack with Timer
How to reset
Ml200rt how to reset
  • Malibu Master
  • 5,089 Answers
I have a malibu ml200rt that won't work can I replace with malibu ml 300 rtw. Thanks
Yes, you can replace the ML200RT with the ML300TW without a problem, and you will have an extra 100 watts for more lights if you want.
Nov 29, 2010 | Malibu ML300RTW - Low Voltage Power Pack...
After a power outage how to reset timer correctly
You posted under Intermatic or Malibu power packs:
Different brands and models re-set differently.
For full information on Intermatic/Malibu power packs showing links to Malibu and Intermatic manuals, plus troubleshooting, and trippers and tips:
http://waterheatertimer.org/Malibu-power-pack-stopped-working.html
Oct 23, 2010 | Malibu ML200RT - Low Voltage Power Pack...
Timer running very slow on my malibu ml200rt
You posted under Intermatic-malibu power packs.
There are no replacement clock motors.
Improvise by setting timer to override and plug power pack into cheap plug-in timer.
For information on Intermatic/Malibu power packs showing troubleshoot steps, replacement trippers, useful links, warranties and tips:
Apr 03, 2010 | Malibu ML200RT - Low Voltage Power Pack...
Where you connect the electrical cord from a fount into the timer
The Malibu ML200RT is intended to operate _12_ volt AC (low voltage) lighting _only_.
Assuming your fountain pump is 120 volts, the needed set up would be to supply 120 volt circuit to an Intermatic T101 timer (or similar timer), then connect a GFCI receptacle to the load side of the timer. You could then plug your fountain pump into the now timer controlled GFCI receptacle.
You can use the same 120 volt circuit that supplies the ML200RT transformer.
Mar 27, 2010 | Malibu ML200RT - Low Voltage Power Pack...
I have a ML200RT-the timer is stuck.
The solution is in the final gear before the timer - it is nylon on the metal casing - and has corroded - happens after winter if left unplugged or stationary.  It takes about 5 minutes to fix.
Carefully take apart the gear mechanism - remembering where the gears go.  When you take out the final gear - it is through a swaged area of metal - carefully rub the inside of this with emery cloth to remove corrosion etc.  Apply a heavy dab of grease or Vaseline.
Re-assemble and you're good to go.
Aug 26, 2009 | Malibu ML200RT - Low Voltage Power Pack...
Malibu ml200rt internal wiring schematics
If you have a meter you can test for 12 volts AC on the output of the transformer. They go to terminals
A & B
Jun 22, 2009 | Malibu ML200RT - Low Voltage Power Pack...
Malibu ML200RT low voltage power pack is not working
First check to make sure that you do not have more watts pulling than is recommended. If this is ok then pull both the red and black plastic pin from the timer and replace them then try. If neither of these solutions work you may have a problem at power source.
May 09, 2009 | Malibu ML200RT - Low Voltage Power Pack...
Malibu Intermatic Inc. ML121RT  Low Voltage 121-Watt Power Pack with Timer Logo
73 people viewed this question
Top Malibu Hardware & Accessories Experts
Gene Haynes
Scott Jelt
Scott Jelt
jdthefixer
Are you a Malibu Hardware and Accessory Expert? Answer questions, earn points and help others
