Question about Garden
Extension spring I have a Craftsman PYT9000 lawn Tractor model- 247.28980 , that has a extension spring that goes under the mower . cant figure it out. the part number is 732-04624. I found where one of the
SOURCE: craftsman lawn mower
I had both my front wheels wobbly - so I cut shims from a tin can - wrapped the axle of the wheels with the shims and then inserted them back into the plastic bushes. It was a snug fit - but helped quite a lot.
Posted on May 27, 2008
  • 246 Answers
SOURCE: owners manual for a craftsman model 917255812 lawn tractor
Hello:
>>You can Use the Site Addys at this Site Addy; http://www.yetmans.mb.ca/antiques.html to Search and Locate New/Used Parts or for Manuals for this Unit.
Respectfully
John
Posted on Apr 21, 2009
  • 246 Answers
SOURCE: Replace V belt on mastercraft 38 inch 12 hp lawn tractor
Hello
The Breakdown of the Unit Usually Shows the Belt Routing.
>>To View a Breakdown of this Unit Go to this Site Addy, http://www.searspartsdirect.com/partsdirect/index.action?sid=PSHx20080114x00001 and Enter the Model Numbers and Click Search. From this Page you can View Diagrams and Parts Lists for you Equipment Using the "View Sub Components" Section Near the Bottom Left.
Please, Do Not Hesitate, If you Hit a Snag or this Does Not Correct the Problem, I am Here if You Require More Assistance.
Hope this Helps. Let me Know What Happens, Please. May the All Mighty Bless You and Yours. Be Safe and Be Happy. Thanks.
Good Luck
Respectfully
jbridger (John)
Posted on May 11, 2009
wadembly
  • 475 Answers
SOURCE: Craftsman lawn tractor model new battery drains quickly...
it could be the stator in the engine check the voltage with the volt meter when its running if its low check connections on battery & voltage if its below 12.5 volts then its the stator but the only thing is the engine should run with-out the battery so there is something else going on there is a fuse in the electrical system if theres a short that fuse will blow & engine will stall
Posted on Jun 08, 2009
bargainbin2
  • 123 Answers
SOURCE: 13.5 hp Craftsman lawn mower 5-speed
Here is a picture to help you place it on right. There are two deck designs pick yours.
Posted on Aug 29, 2009
I have a craftsman lawn tractor having problem with spring extn. 732046168. Tractor model 247288851. the spring is connected to idler bracket bracket assembly.
Howard, possibly the wrong spring # not matching as parts diagram in links below, do you have the old spring to sort of match it up or are you possibly putting it in the wrong retaining hole. Check the attached links,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
http www searspartsdirect com model part 247288851 0247 1509200 1106099p...
http://www.searspartsdirect.com/partsdirect/user-manuals/247288851-craftsman-tractor-manual
http://www.repairclinic.com/Shop-For-Parts/a21b317d1124318/Model-247288851-Craftsman-Lawn-Mower-Parts
No Need to see diagram of the springs that are on the deck of riding mower...
Jun 10, 2016 | Craftsman Garden
I have had this before. Most likely it is a broken or missing return spring which is pulling the pulley to stop position (this is part of what pulls against the engage lever when you pull it up to engage the deck). Also there might either be debris under the lever on the deck that the moving pulley is attached to or it could be bent. Remove the deck and check for the spring (if you have owners manual that will show exactly where it would be located. If you dont and cant find one, give me the model number from under the seat and I will see if I can find one). If the spring is there, try forcing that lever on the deck by hand to see if you can get it to release (keep yours and others fingers away as when it breaks free, the spring provides some good force.
Aug 05, 2014 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
How do i troubleshoot 42 inch craftsman lawn tractor on which the mower deck quit engageing
Most likeley is a spring on the top of the deck or the cable that goes from said spring to the lever. if you could provide the model number I can look up the manual and diagram and show you.
Jun 29, 2014 | Craftsman Garden
My Craftsman PYT9000 garden tractor starts and then dies
There is a fuel cut off solenoid located on the carburetor fuel bowl. This can fail sometimes and stop the fuel from entering the Carb. Also check for pinched fuel line, clogged fuel filter. Some models have a second reserve tank. Check for tank selection valve. Hope this helps.
Sep 14, 2013 | Craftsman PYT 9000 26 HP 48" Yard Tractor
Mfirefighter173@aol.comhave a craftsman 17 hp lawn tractor and dont know were to put the spring that engages the mower blades, had to take apart to put in new mandril and cant seem to find were to put this...
There are four pulleys on the deck. Two for the blades, one idler, and one tensioning. The two smaller ones are the idler and tensioning. The tensioning is the one on the right. The post coming out the top of the pulley is where the spring goes, it slides over the top and a clip goes throught the hole at the top of it to retain the spring.
I hope this helps.
Aug 18, 2011 | Craftsman 20 Hp 42" Deck Lawn Tractor
Replacing belt on lt1000 lawn tractor looking to fing where to hook spring to engage belt it popped off and cannot figure where wher to reattch it . is there a diagram on the layout Thank...
I do not have a diagram,but I do know where it goes.Look at the tension pulley.The arm it is mounted on move.That arm is where the spring belongs.First move the arm with your hand.pull it so that the blades are not engaged.Now the side of the arm away from the pulley and closest to the rear of the mower,is where the spring goes.There may be several holes,do not pull the spring too much,just get it in one of those holes.Then try the blades.If they do not engage,move the spring,to another hole.
May 20, 2011 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Spring is broken
There are many springs on a riding mower. Is it the clutch spring, the idler pulley spring, or maybe the blade brake springs. There are also springs on the brakes and even under the set. Please be more specific.
Aug 23, 2009 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
I need belt diagram for 42 in deck
You can go to the Sears website an download a free owners manual that shows what you need.
Apr 23, 2009 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Garden Logo
26 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
