Question about Ricoh Aficio SP C811DN-DL Printer
What do I do for an 442 error code?
What do I do to fix machine that comes up with an 442 error code?
The engine trouble light comes on I check it on my dianostic tool & I get a code 442. But I have no idea what that means, Can you help-?
Hello: 442 concern the evap system. It means you have a small leak. The most common item would be a gas cap that is not fully tight or the seal on the cap is dry and not sealing good. Try tightening the cap first, then get the code cleared and see if it comes back.
Aug 21, 2011 | 2002 Pontiac Grand Prix
Have error 442 with cisco client vpn 5.07 on windows 7 - 32 bit - any ideas?
Error 442 - Failed to enable virtual adapter.
No fix yet from Cisco. Try this work around.
Run cmd as Administrator and execute the following command:
reg add HKLM\System\CurrentControlSet\Services\Tcpip\Parameters /v ArpRetryCount /t REG_DWORD /d 0 /f
Mar 24, 2011 | Cisco Systems Cisco VPN Client
DTC # 01-PO442 and P1407 are the codes that come up possible solution help
PO-442 EVAP Control System Leak Detected (Small Leak)
You will need to put an EVAP Smoke Machine, on system to find leak
P1407--Should be EGR related.
Most likely need new EGR Valve
May 23, 2010 | 2001 Ford F150 Styleside SuperCrew
What do I need to check if code 442 comes up.
442 cose states that there is a small leak at the evap control system (near fuel tank)... smell gas?
Sep 28, 2009 | 2006 Pontiac G6
Can't get my car smoged. it has been at smog shop for 3 days hel
If you go to an Autozone or Advanced Auto they can give your car an engine diagnostic and they can also give you a printout of the codes and their meaning.
Jun 02, 2009 | 2003 Kia Spectra
Der Videotyp is not PAL - code 442-E-100
install the software in ntsc mode...it was my solution
User "aldof" said it in other post...
Thanks to him
Dec 02, 2008 | Panasonic Palmcorder SDR-H18 Camcorder
Laserjet 3330 is resulting in fax Comm Errors 327, 232, 442, 356, 421 Comm Error 327 is always with fax # 780.467.6516. i can not fax to this number and when i receive from it, it always prints a Fax...
232-A communication failure has occurred between the two machines.
327-*Reattempt the fax reception at a different time when telephone line conditions have improved. Call the telephone provider if line conditions fail to improve.
356-The remote user has pressed the Stop key, causing the session to be aborted.
442-An error occurred during transmission after one or more partial pages had been sent. The transmitting machine was unable to restart the control channel (handshaking) before sending more data. This error typically occurs when the receiving fax disconnects after receiving part of a page but can also occur if the receiving fax is using a fax format that is incompatible with the HP fax machine (usually during color faxing).
Aug 15, 2008 | HP Computers & Internet
Error codes 442 and 456 on 2003 Chrysler Town and Country
Could be the gas cap.  Do you fill the tank with the engine running?
Otherwise, check the hoses near the Evap canister.  I have 2003 T&C and had the small leak and large leak codes.  I looked at the evap cansiter and the hose coming from the fuel tank vapor line had a huge crack in it, to the point it had fallen off the evap caniser.  I trimmed the end of the hose and reconnected and voila, no codes.
The evap canister is on the driver's side of the van, underneath, slightly behind the drivers seat.
BTW, to clear the codes without an OBDII reader, remove the negative cable for 5-10 minutes (15 to be safe).  The computer resets and clears the codes, except for one that it sets saying loss of power to the memory.
Jul 22, 2008 | 2003 Chrysler Town & Country
Getting "service code 442" on startup
SC442 Transfer belt contact error The transfer belt contact sensor does not detect the movement of actuator at the sensor while the polygon motor rotates. • Dirty transfer belt contact sensor • Defective transfer belt contact motor • Disconnected connector of transfer belt contact sensor or motor • Disconnected cable 1. Replace the transfer belt contact sensor. 2. Replace the transfer belt contact motor
Apr 01, 2008 | Ricoh Aficio SP C410DN Laser Printer
Ricoh Aficio SP C811DN-DL Printer Logo
13 people viewed this question
Top Ricoh Office Equipment & Supplies Experts
OfficeServiceAjnc
OfficeServiceAjnc
fares
Level 1 Expert
SOURAV KAPOOR
Level 1 Expert
Are you a Ricoh Office Equipment and Supply Expert? Answer questions, earn points and help others
